Old 02-28-2015, 12:28 PM #1
hikenbike's Avatar
hikenbike hikenbike is offline
hikenbike is on a distinguished road
hikenbike's Avatar
Lost key replacement
I recently lost a key and fob set for my 07 and now I'm down to one set.
The dealer quoted me $40 for the new key, $115 for the new fob, and $125 for reprogramming.
Does that sound normal/standard or outrageous?
Thanks.
2019 Subaru Outback Limited 3.6 - Silver (replaced 2016 Trail Premium w/KDSS)
2007 V8 Sport 4Runner - Magnetic Gray
"A pessimist sees the difficulty in every opportunity; an optimist sees the opportunity in every difficulty" - Winston Churchill
hikenbike is offline   Reply With QuoteReply With Quote
Old 02-28-2015, 12:38 PM #2
4gin007's Avatar
4gin007 4gin007 is offline
4gin007 is on a distinguished road
4gin007's Avatar
I believe you can buy both from amazon or ebay and I know you can program them yourself at home. The directions are on this forum. I need to get a new key and fob myself. But to answer your question Im not sure if that dealer quote is right on or not. Seems steep to me because I understand the directions to program the key and fob yourself is pretty easy.
Edit: If you buy online make sure you match up the HYQ number on the back of your fob
2005 galactic gray, level8 mk6, 285 70r 17, 1" body lift, ome 885, 895, 5100 on all corners, LR uca, 4xinnovation sliders
4gin007 is offline   Reply With QuoteReply With Quote
Old 02-28-2015, 01:15 PM #3
fdbyrne fdbyrne is offline
fdbyrne is on a distinguished road
There is a thread on here somewhere about how to program the truck to recognize the new key. It involves inserting and removing the good key a certain number of times and opening then closing the driver's door a certain number of times. It sounds completely crazy but I can verify that it works. I was surprised.
Update: Here is the thread I was referring to.
How to make spare chipped keys
2004 SR5 4x4 V6 - With New Head Gaskets
fdbyrne is offline   Reply With QuoteReply With Quote
Old 02-28-2015, 01:22 PM #4
Martinjmpr's Avatar
Martinjmpr Martinjmpr is offline
Martinjmpr will become famous soon enough
Martinjmpr's Avatar
Ripoff!
$125 to program?
I think that's called the "sucker fee."
You can program both the remote and the key yourself in 5 minutes. Also I'll bet if you shop around you can find a fob for less than $100 on eBay.
There are instructions on this board on how to do the reprogramming and they work great.
Martin AKA Zapp Branigan - No longer a 4runner owner!
Martinjmpr is offline   Reply With QuoteReply With Quote
Old 02-28-2015, 02:16 PM #5
hikenbike's Avatar
hikenbike's Avatar
Thanks guys. Was just thinking......do I really need another fob? I don't really use it for anything. If I have a newly programmed key (or two) I should be good, correct?
Old 02-28-2015, 02:18 PM #6
I only have one fob and it's never bothered me.
Old 02-28-2015, 02:21 PM #7
BlackWorksInc's Avatar
BlackWorksInc BlackWorksInc is offline
BlackWorksInc is a splendid one to behold BlackWorksInc is a splendid one to behold BlackWorksInc is a splendid one to behold BlackWorksInc is a splendid one to behold BlackWorksInc is a splendid one to behold BlackWorksInc is a splendid one to behold BlackWorksInc is a splendid one to behold BlackWorksInc is a splendid one to behold
That's about right for dealer pricing. Genuine Toyota fobs will be in the $50-120 range depending where you find them.
I would recommend spending the money on the key as they will VIN cut the key vs. copying your worn out key at the hardware store.
BlackWorksInc is offline   Reply With QuoteReply With Quote
Old 02-28-2015, 02:22 PM #8
Martinjmpr's Avatar
Martinjmpr's Avatar
Same here. Owned my 4runner since June 2012 and I've thought about getting another fob but it hasn't been an issue so it's unlikely that I'd spend the time or money.
I guess there are probably some vehicles nowadays where you need the fob in order to drive the car but the 4th gen isn't one of those. You can still use the key to unlock the doors and start the vehicle so even if your fob goes kaput it's not like it will leave you stranded. It's a convenience more than anything else.
Old 02-28-2015, 02:35 PM #9
hikenbike's Avatar
hikenbike's Avatar
Makes complete sense. I'll go get that and then try the programming myself.
Old 03-01-2015, 12:11 AM #10
KOTOC-79 KOTOC-79 is offline
KOTOC-79 is on a distinguished road
I picked up a Toyota blank for $12.50 and 2 fobs for $37.50 on eBay. Ace hardware cut the key for me ($2)and I followed a you tube vid to program the key and fobs . It was pretty easy.
KOTOC-79 is offline   Reply With QuoteReply With Quote
Old 03-01-2015, 02:00 AM #11
Just to point out that if you're going to make a new key for any vehicle, you are doing yourself a disservice if you don't at least buy one and have it cut by a dealer or locksmith (though I don't know how many actually have the tooling for VIN cutting.) Especially for used/high mileage vehicles.
The reason being that you're cutting your brand new key to your old, worn out key which means if your original key is only a few thousands from causing ignition issues, your new key is already pre-worn and wear out just as easily. More often than not when a customer complaints that they can't start the car or unlock the doors its the key that has worn out not the locks.
When you have the dealer cut the key; they'll run the vehicle VIN through Toyota's Database after getting authorization and then get a Key Code to cut the new key as it would be at the factory so it's nice and fresh. Afterwards you can use that key as your Master to copy from. Its a bit expensive upfront, but it pays for itself when you think about it; programming can always be done outside of the dealership through various venues.
Old 03-01-2015, 02:30 AM #12
YotaRunnerV8 YotaRunnerV8 is offline
YotaRunnerV8 is on a distinguished road
I just did this a couple days ago. I ended up buying a chipped key on Amazon for $8 shipped. Then took that key to my local Toyota dealership. The first dealership wanted $85 just cut the key from my VIN! After picking my jaw up off the damn counter, I called another dealership who offered to do it for $20. Took my business to them, programmed the new cut key at home, and now I have a perfectly cut master key for less than $30.
YotaRunnerV8 is offline   Reply With QuoteReply With Quote
Old 03-01-2015, 11:50 AM #13
awdjunkies's Avatar
awdjunkies awdjunkies is offline
awdjunkies is on a distinguished road
awdjunkies's Avatar
Remember though that, if you do it at home or anywhere else OTHER than the dealership, you need to have the black/original key in order to program it yourself, as the gray/auxiliary/glove box key will not work if you are trying to program a new key.
'04 GGM 4Runner SE-V8 4x4/XREAS/Auto Dim-Compass rear view/homelink/RSCA curtain system/Pioneer deh-x8500bs/Grabber AT2/Gibson CBE/HCF Delete/Gobi Ladder/yellow HID Fogs.. awdjunkies build thread
Shout out to Stuck_CAPS For this GEM: http://www.toyota-4runner.org/4th-ge...iy-videos.html
awdjunkies is offline   Reply With QuoteReply With Quote
Old 03-01-2015, 01:59 PM #14
hikenbike's Avatar
hikenbike's Avatar
Went to the dealer yesterday and got a VIN cut key for $43. Just went out and programmed it according to the procedure learned here and it worked flawlessly in 2 minutes.
Thanks all!
Old 10-02-2017, 04:07 PM #15
RedRumt4r RedRumt4r is offline
RedRumt4r is on a distinguished road
Does anyone know where I can get a key fob with a switch blade key built in?
RedRumt4r is offline   Reply With QuoteReply With Quote
In memory of those lost and those who have lost SV_Dude Off Topic 5 09-11-2013 09:58 PM
lost my job 4Evr4RunN3R Off Topic 41 02-06-2009 11:45 PM
Lost GPS Nav reckless101 4th Gen T4Rs 4 02-01-2009 06:46 PM
Get lost much??? sharp4runr Off Topic 4 01-09-2007 12:26 PM
I'm Lost Roozyt Off Topic 12 04-06-2006 08:07 PM
