07 2Wd V6, Im in the process of changing the 3rd member. I got the 4 bolts holding the driveshaft to the third member out and the whole shaft is loose already. I can move it forward and back out of the rear of tranny pretty freely where the slip yoke is.
The problem is that if I slide the DS forward into the slip yoke of the tranny, it stops just short of allowing me to clear the studs of the rear diff flange to let the thing drop. I can wiggle the the u-joint flange all round and it will clear one or two of the studs but not all 4 of them so that it can drop down.
If i try to hold the Ujoint "even" with the flange as i slide it all forward, I need only about another 1/8 of an inch to clear the studs.
Is there some kind of trick to this???? WTF, this should be simple right?
Please help as I'm stuck now and need to get this third member swapped before the day is over
