Old 01-08-2021, 11:02 AM #421
Proudy202 Proudy202 is offline
Proudy202 is on a distinguished road
Hi Guys,
Just signed up as I'm hopefully getting a new to me 4runner this weekend.
2007 V6 Limited, with 130k in Silver and by the sounds of it clean (being up in New England rust is always a concern, if it's as clean as the dealer says I'll be buying!) It's completely standard and I already have a set of TRD Pros sat in my cart waiting to buy!
What I'm stuck on is do I get a set of tires to fit standard ride height for now (265/70 17 will fit right?) and upgrade later once I lift, or hold off and fit new larger tires, wheels and lift all at once...I'm planning to do 285/70 17s and a 2.5-3" lift but that won't be for 6months or so!
Also any guidance on the lift would be great, I'm stuck between the 5100s/OME or the 6112/5160 combo it's a daily that will at most a handful of times a year see any serious offroad, me and the girlfriend are planning plenty of camping trips next year though so it may do a fair amount of overlanding..
Thanks guys
Can't wait to get it!! Its been too long since I've had a car I can play with!
Proudy202 is offline   Reply With QuoteReply With Quote
Old 01-08-2021, 12:12 PM #422
techno's Avatar
techno techno is offline
techno is a jewel in the rough techno is a jewel in the rough techno is a jewel in the rough
techno's Avatar
Originally Posted by Proudy202 View Post
Hi
Tires - Stick with 265/70-17 for now. You'll probably have to move the front fender liners a little tho.
Lift - I would go with a full OME setup. I've done the 5100/OME and full OME. The Bilsteins are nothing special in my experience and are not tuned to the coils like the OME are. When you start adding weight for camping and overlanding, you'll appreciate the OME ride a lot more.
techno is offline   Reply With QuoteReply With Quote
Old 03-04-2021, 03:18 PM #423
BigErn McCracken BigErn McCracken is offline
BigErn McCracken is on a distinguished road
Originally Posted by aelarson View Post
2008 V8 Limited - No lift, rolling on stock sized Duratrac's (265/65/17).
Your 4Runner looks great. I'm brand new to this thread as of today. I have an 05 4Runner SR5 and just put on new TRD pro wheels and bumped up to a 265 70 17 Falken Wildpeak AT3 tires. Love the look but they are rubbing like crazy. I'd like to avoid spending too much money on a lift or doing fender liner trimming, etc...I haven't been able to find many pics of the TRD pro wheels on the factory tire size tires (265 65 17). I can either swap mine out for 265 65's or spend a bunch of money fixing the issue. Are you glad you stayed with the 265 65 17's and assuming you don't have any rub with those? Any info is greatly appreciated!
Edit: Mainly a daily driver in CO without much offroading, so looking for aesthetics and snow driving.
BigErn McCracken is offline   Reply With QuoteReply With Quote
Old 03-04-2021, 03:35 PM #424
montijo505's Avatar
montijo505's Avatar
It’s super easy to trim the inner front bumper and no one will notice. Then just move the line forward a bit or hear it up with a heat gun and bend it some.
Old 03-04-2021, 06:02 PM #425
aelarson's Avatar
aelarson aelarson is offline
Real Name: Andrew
aelarson will become famous soon enough
aelarson's Avatar
Real Name: Andrew
Thank you! I can imagine that you are rubbing. My stock sized Duratracs are about as close as you can get to rubbing without fender liner modification. Luckily they do not rub and I have yet to be in a situation where they do. I lightly offroad (gravel roads, fire lanes, logging roads, etc.) and I have not had a single issue. My 4Runner is my daily so I did not want to compromise the stock fuel economy, ride, etc. with a lift and big tires, as much as I love the look (been there, done that). If you aren't getting off the beaten path, I'd highly recommend the setup. Not super flashy by any means, but it works great for daily life.
08' Limited V8 (2020-Current)
17' TRD Pro (Sold: 2017-2020) - Update/Mod/Build/Adventure Thread
08' Urban Runner (Sold: 2010-2017)
aelarson is offline   Reply With QuoteReply With Quote
Old 03-04-2021, 07:24 PM #426
y=mx+b's Avatar
y=mx+b y=mx+b is offline
y=mx+b has much to be proud of y=mx+b has much to be proud of y=mx+b has much to be proud of y=mx+b has much to be proud of y=mx+b has much to be proud of y=mx+b has much to be proud of y=mx+b has much to be proud of y=mx+b has much to be proud of y=mx+b has much to be proud of
y=mx+b's Avatar
Like Montijo Said, start by stretching fender liner and see where that gets you. Then trim bumper cover if needed. Heres some pics from when I stretched mine, slightly different wheel size, but same concept:
Before and After
Stock Hole Position vs New Hole. I only used one clip. I know some people drill the bumper cover, but I'm still a weenie and didn't want to mess it up. I know its on the bottom, like I said, I'm a weenie. Drilling the liner worked just as well
And this is the driver side from the bottom
The passenger side is very similar, although it has 3 clips between the liner and bumper vs the 2 on the driver side. I used 2/3 clips on this side
y=mx+b is offline   Reply With QuoteReply With Quote
Old 03-05-2021, 01:12 PM #427
That is really helpful, much appreciated! One last question...You have the TRD Pro 17x7 wheels on with those Duratrac AT 265 65 17 tires with no issue? One tire site says the rim width range is 7.5-9.5" and another one states 7-9.5". Since the TRD Pros are 7" wheels just confirming that works. Hows the road noise on those?
Old 03-05-2021, 02:17 PM #428
aelarson's Avatar
Real Name: Andrew
aelarson's Avatar
Real Name: Andrew
No problem! Stock tire size on this wheel works just fine. You'll see a lot of guys run 285's on the TRD wheels with no issues. No issues mounting or balancing either.
Road noise is moderate. They aren't quiet, but not super loud either. Very livable for daily life.
Just a side note, these are my favorite tires I've ever run. They are right up there with KO2's in my opinion. The Duratracs absolutely crush snowy roads (packed or loose snow).
Old 03-05-2021, 03:40 PM #429
Thanks again! You've made my decision much easier. Going to go back to the shop and swap out my Falkens for stock size Duratrac or KO2's and save some money for stereo and other upgrades.
Old 03-05-2021, 08:34 PM #430
indianacheryjones's Avatar
indianacheryjones indianacheryjones is offline
indianacheryjones is on a distinguished road
Finally looking good!
Huge thanks to @Crikeymike at Exit Offroad for all help in getting me set up with the lift. Really like the way the truck sits! The wheels add a nice touch too lol.
2003 SR5 V8 | Dobinson's C59-296/GS59-220 Front & Dobinson's C59-599/GS59-705 Rear | Bridgestone Dueler AT Revo 3 265/70/17 | Toyota TRD Pro Wheels
indianacheryjones is offline   Reply With QuoteReply With Quote
Old 03-08-2021, 10:33 AM #431
Crikeymike's Avatar
Crikeymike Crikeymike is offline
Crikeymike has much to be proud of Crikeymike has much to be proud of Crikeymike has much to be proud of Crikeymike has much to be proud of Crikeymike has much to be proud of Crikeymike has much to be proud of Crikeymike has much to be proud of Crikeymike has much to be proud of
Crikeymike's Avatar
Nice!!! Man, that thing looks new again!!!
Exit Offroad - Specialist in Dobinsons Suspension & Accessories
Dobinsons | RCI | Powerbrake | Long Range Tanks | Timbren | Overland Vehicle Systems
Youtube Channel | Email Directly
Been in the offroad industry since 1998. Born & raised in Australia - currently in Jax Beach, FL. 2014 4runner Trail, 3/2" Dobinsons MRA Suspension, Shrockworks bumper and sliders, M8000 w/ Treaty Oak winch line, LFD Roof Rails, Dobinsons 2m Awning, RCI skids
Crikeymike is offline   Reply With QuoteReply With Quote
Old 03-10-2021, 08:02 PM #432
Lizard10 Lizard10 is offline
Lizard10 is on a distinguished road
So stoked to have found a set of the 2021 TRD Pro 4Runner wheels. Love the center caps and how they’ve evolved vs previous years. Now to get some tires and get these bolted on!!!
The 4th gen TRD PRO wheel picture thread-af8a4ebb-ea52-4f3d-b8e5-6a2703c8ec3f-jpg
Lizard10 is offline   Reply With QuoteReply With Quote
Old 03-24-2021, 07:34 PM #433
BrianSully12 BrianSully12 is offline
BrianSully12 is on a distinguished road
Oh baby
The 4th gen TRD PRO wheel picture thread-trd-jpg
BrianSully12 is offline   Reply With QuoteReply With Quote
Old 01-13-2022, 06:57 PM #434
rayoo rayoo is offline
rayoo is on a distinguished road
Originally Posted by Nahrah View Post
Bilstein 5100's, Ome 884/895e springs, SPC UCA and 285/70/17 Falken Wildpeak AT3w on TRD Pro Matte Gray wheel
Looks awesome. I also have SPC UCAs and am considering doing the TRD wheel upgrade.
The SPC UCAs sit really close to the tires as is. Did you have any trouble with the SPC UCAs and the wheels being so close?
rayoo is offline   Reply With QuoteReply With Quote
Old 01-13-2022, 10:28 PM #435
Nahrah's Avatar
Nahrah Nahrah is offline
Nahrah will become famous soon enough Nahrah will become famous soon enough
Nahrah's Avatar
No I didn’t have any issues.
Current - 21 TRD ORP, Method 316 on 285/75/17 Toyo MT, Bilstein 5100’s OME 885/889, Spc UCA
Old(still in the family) - 07 Sr5 V6 2wd, Bilstein 5100's, Ome 884/895e, TRD ORP wheels, SPC UCA and CBI front skid plate.
Nahrah is offline   Reply With QuoteReply With Quote
2nd Gen T4R Picture Gallery RuSty420 Classic T4Rs 2270 12-07-2023 05:29 PM
5th Gen 4R Was There Picture Thread phillyd2 5th gen T4Rs 70 11-24-2021 05:39 PM
wyanrard's 2003 SR5 V6 build thread/picture thread wyanrard 4th Gen T4Rs 56 02-04-2017 01:03 PM
picture thread Jade Engines / Suspension / Wheels / Tires / Audio / Accessories 4 01-12-2014 09:00 PM
Before and After Picture Thread josh220 General Discussions 9 04-28-2008 09:17 PM
