02-17-2020, 02:59 AM
#301
Originally Posted by rokr1292
I'm back, with pictures of the new housings with LED strips:
LED Strip housings from AKKON
the turn signals are still the same as OEM for the most part (reflector assembly looks like the oem shape) but the "reflector" part is blacked out, not chrome, which isn't great. but the "diffuser" that is normally in front of the signal bulb is also removed.
I was surprised that they included bulbs, but the included bulbs are not good. one of the blinkers was frosted-looking out of the box, and the high/low bulbs are fairly dim-looking. I've already changed back to my other bulbs after cleaning seals.
I personally think that LED signal bulbs are essential in these, due to the reflector situation.
Besides that, the amber reflectors are only reflectors, no light passes through in a meaningful way.
The housings themselves fit better than my old pair, no more rubbing on part of the hood/fender, which I'm very happy about. Inspecting the seals before installing, and comparing to my other pair, these do seem better-sealed as well.
overall I like them so far, but I would prefer if something else was done with the turn signals. maybe also include an amber strip in the housing and do without the bulb socket altogether, or at least not black out that reflector/remove that diffuser.
Are the turn signals really that bad? Any recommendations for LED turn signal lights to replace the turn signal bulbs this came with?
1999 Black SR5 5-speed 4WD Rear e-locker
Suspension: Toytec 3" Ultimate Lift, JBA STD High Caster Upper A-arms, Eimkieth PCK
Wheels/Tires: Method 305 NV Bronze (16x8 | 0/4.5"), Goodyear Duratracs 285/75-16, 1.25" Spidertrax Wheel Spacers
Others: SRQ Fabrications Flush Grille, TJM T17 Front Bumper, Magnuson Supercharger, URD 7th Injector, Rock Gray Avery vinyl wrap, TG Sliders
03-21-2020, 04:11 PM
#303
So it seems like mostly negative reviews on these Amazon/eBay lights. Has anyone gone through and ran a fresh bead of sealant around the lens before installing with better results? Or, is the fogging coming from bad fitment with the bulbs?
03-21-2020, 04:29 PM
#304
Originally Posted by rooneyy
I wanted to contribute to this topic. I purchased a set of blacked out headlights on ebay as well. Item is HERE
ALBUM
It looks wonderful all blacked out and really changes the front end. I originally took apart my OEM headlights to paint them black but the housing has since been cracking and major hazing. I decided to give these a shot.
While I can't comment on the longevity of these, the light output is decent with a decent cut off (i'll try to get pictures), they seem pretty good for the money.
BE AWARE! Area circled in red in one of the pictures melted on the inner side. The amber turn signal/DRL bulb melted on the inside, breaking the bulb. I fixed this buy using a rotary tool to sand down the area's that where melted and touching the bulb. After doing so, I bought a new bulb and all is well.
Looks great, question? what kit did you used for you amber grill lights?
2005 T4R Silver SR5 V6 4wd with Mods.
06-30-2020, 08:17 PM
#305
Real Name: Ryan
Real Name: Ryan
ALBUM
So as much as I loved these DTMoto blacked out housing headlights when I got them, it took 8 months for the clear sealant they use on them to start peeling and look like crap (they said it was delamination lol) and one is letting moisture in now because of it. They said warranty is only 60 days, so now trying to figure out how to fix this without buying a new set. Kind of pissed about this because they looked so great!
07-09-2020, 10:13 AM
#306
I'm back, with pictures of the new housings with LED strips: LED Strip housings from AKKON - Album on Imgur
A couple things of note:
The strips are SOLELY DRL as configured. not blinkers or hazards. it might be possible to rewire them that way, but I'm not willing to cut apart a brand new set.
How is the light output of the projector and what's the cutoff line like?
My OEM housing are starting to leak and am considering picking up a set of these and doing a retrofit of some Morimoto Bixenon projectors depending on how the included projector is in these headlights.
'09 V8 Limited | Dobinsons Lift | Front: 3" - C59-302 + GS59-220 | Rear: 2.5" - C59-675V + GS59-701 | Tires | Ridge Grappler 275/65/18XL | Wheels | Method Standard Machined Finish 18x9 -12 offset | SPC UCAs | DT Long Tubes | GSport 2.5" Cats | DT Y-Pipe | Magnaflow Cat Back | 2.5" Vibrant Ultra Quiet Resonator
09-14-2020, 03:28 PM
#307
ALBUM
I am having the same issue with the melting in the blinker bulb socket. I purchased the Sypder headlights and it happened to both driver and passenger sides. Can you specially tell me what I need to shave down?
09-19-2020, 12:46 AM
#308
So, is it safe to say that all of these aftermarket headlights let water/condensation in at some point?
2007 V8 Limited / Toytec & Bilstein 3 inch lift
09-30-2021, 05:41 PM
#309
ALBUM
Hey man I was wondering if you could speak on how these have been the past few months you’ve had them. Any moisture issues?
09-30-2021, 06:26 PM
#310
Unfortunately, yes. That's why they're so inexpensive.
09-30-2021, 06:33 PM
#311
Do you know of any that don’t have any problems? Really want the black out look
09-30-2021, 07:08 PM
#312
You will find some people that will tell you that they've had zero problems with their aftermarket lights. Unfortunately, in the grand scheme of things, they're likely a disturbingly small percentage. (And I'd discount any reviews from people with lights that are less than 2-3 years old.)
As I said in my previous post, there's a reason the aftermarket lights are so cheap and OEM lights are so expensive. You truly do get what you pay for.
09-30-2021, 09:52 PM
#313
You could buy them and before install seal them up really good with an aftermarket sealant.
09-30-2021, 10:35 PM
#314
Yeah that’s a good idea, any sealant recommendations?
10-01-2021, 08:50 AM
#315
We've had over 50 inches of rain, temperatures from minus 36 to 100 above since I've installed the black LED's shown above and I have no moisture issues at all.
Just caulk the top and sides of the seam before installing.
Thread Tools |
Display Modes |
Rate This Thread |
Linear Mode
