Old 03-20-2015, 02:54 PM #1
indaclear indaclear is offline
indaclear is on a distinguished road
Pulling timing chain cover 05 v6 4runner
I am going to pull the timing chain cover to reseal the gasket surrounding it. Is there any maintenance I should perform while I have the cover off? Anything I should check while I'm in there?
Thanks in advance
indaclear is offline   Reply With QuoteReply With Quote
Old 03-21-2015, 01:08 AM #2
ILRunner98 ILRunner98 is offline
ILRunner98 is on a distinguished road
There is one o-ring that will need to be replaced that comes off with the timing cover. Its for the oil pump. How many miles?
ILRunner98 is offline   Reply With QuoteReply With Quote
Old 03-22-2015, 07:49 PM #3
170k
Old 03-22-2015, 08:43 PM #4
fdbyrne fdbyrne is offline
fdbyrne is on a distinguished road
I think that he was asking about the mileage to find out whether or not it would be worth while to replace the timing chain and or tensioners while you're in there.
At 170k I'd definitely check both but you probably won't need to replace either unless you just want to while you're in there for peace of mind.
2004 SR5 4x4 V6 - With New Head Gaskets
fdbyrne is offline   Reply With QuoteReply With Quote
Old 03-22-2015, 09:51 PM #5
what about the water pump? should I swap that while I'm in there too?
Old 03-22-2015, 10:43 PM #6
The water pump on the V6 doesn't require the timing cover to be removed and it's a pretty easy job. There wouldn't be any benefit to adding the water pump replacement to this job unless you know for a fact that it's leaking or otherwise defective. That's only my opinion of course.
2005 4runner , oil leak , timing chain
Cracked Timing Chain Cover UteRunner Classic T4Rs 3 11-29-2014 07:26 PM
2010 limited 4x4 timing chain cover oil leak two-fingers 5th gen T4Rs 6 08-05-2014 09:20 PM
Timing chain cover bolts the_dingman Classic T4Rs 1 04-16-2010 04:29 PM
Timing chain cover Mtneer001 4th Gen T4Rs 0 09-17-2008 04:06 PM
2004 V6 4runner - Timing chain? PTPT2002 Maintenance/Detailing 1 02-11-2004 01:07 PM
