Old 04-07-2015, 05:50 PM #1
Lewis&Clark Lewis&Clark is offline
Real Name: Dan
Lewis&Clark is on a distinguished road
Real Name: Dan
Disconnecting sway bars
Going offroading in Hollister with a friend of mine who's done it a lot. I've not, this is my first REAL foray off the grid.
He suggested I get sway bar disconnects. How important are these on a T4R? He's coming from a Jeep Cherokee and doesn't know the 4R's at all. His Jeep only has one sway bar up front.
What would the impact be on sway bar disconnects in terms of day-to-day on-road driving?
2008 4Runner V8 Limited ("Lewis"), all factory options.
Lewis&Clark is offline   Reply With QuoteReply With Quote
Old 04-07-2015, 06:41 PM #2
Darwalk's Avatar
Darwalk Darwalk is offline
Real Name: Darrin
Darwalk is on a distinguished road
Darwalk's Avatar
Real Name: Darrin
If you have stock suspension (even minus xreas) I wouldn't be removing the sway bar links at all. The suspension is too soft in my opinion, and you would see some pretty good roll from the front. The 4R only has 1 sway bar in front as well, but disconnecting the links would be too close to all of the moving parts. I only removed my sway bar on my last 4R after I installed an Icon lift, and wouldn't do it unless I had some stiff components.
2006 T4R Sport Edition- The Work Car
2010 Lexus IS-C- The Play Car
Darwalk is offline   Reply With QuoteReply With Quote
Old 04-07-2015, 09:55 PM #3
t-man t-man is offline
Real Name: Tony
t-man is on a distinguished road
Real Name: Tony
I removed mine after installing the 5100's and ended up putting the rear back on. It wasn't bad, but after my body lift and putting the 35's on it leaned pretty good. The front is long gone with no regrets though. It limits that IFS to much.
2005 Toyota 4Runner, Sport Edition, V8, K&N filter, Doug Thorley headers, custom dual exhaust, Bilstein 5100 W/ Tacoma TRD coils in front, FJ Cruiser coils, Daystar 1.5" spacer W/ Doetsch Tech 8000 10" shocks in rear, 2.5" 4crawler Body Lift, removed Sway-Bars, removed mud flaps, removed running boards, chopped body mount, 315/70-R17 Hankook Dynapro MT
Build thread: http://www.toyota-4runner.org/4th-ge...ld-thread.html
t-man is offline   Reply With QuoteReply With Quote
Old 04-07-2015, 10:40 PM #4
CXS CXS is offline
Real Name: Chris
CXS will become famous soon enough
CXS CXS is offline
Real Name: Chris
I ran w/o mine too with my OME suspension but travel trailer season is here so I have them back on.
Chris - '07 SR5
‘05 Limited - sold
CXS is offline   Reply With QuoteReply With Quote
Old 04-07-2015, 10:59 PM #5
Troymclure's Avatar
Troymclure Troymclure is offline
Real Name: Jake
Troymclure is on a distinguished road
Troymclure's Avatar
Real Name: Jake
I run no front either. Definitely improves front end flex as well as on road comfort, but at the cost of body roll. Doesnt bother me too much since the ride is so much smoother both on and off road
Troymclure is offline   Reply With QuoteReply With Quote
Old 04-07-2015, 11:37 PM #6
Real Name: Dan
Real Name: Dan
What's the effect caused by towing a trailer with no sway bars?
Old 04-08-2015, 12:06 AM #7
BlackWorksInc's Avatar
BlackWorksInc BlackWorksInc is offline
BlackWorksInc is a splendid one to behold BlackWorksInc is a splendid one to behold BlackWorksInc is a splendid one to behold BlackWorksInc is a splendid one to behold BlackWorksInc is a splendid one to behold BlackWorksInc is a splendid one to behold BlackWorksInc is a splendid one to behold BlackWorksInc is a splendid one to behold
First off you can't just slap on Disconnects like you can a Jeep, our sway bars are so tightly bent around the frame that you risk having the sway bar dig into the CV axle or springs during flex.
If you're running a factory suspension set-up I wouldn't bother with taking off the sway bar at this point since with the factory suspension you probably won't gain much more articulation. Some guys like to do it for a bit more articulation when they put a lift kit on, but in my opinion the body roll is far too excessive for how I drive on the street (damn thing wallows like a Domestic truck without the sway bar) vs. how well the vehicle performs off-road with the OLW 2.5" lift I am running and their sway bar relocation brackets.
If you feel like reading up a bit, I did prototype a disconnecting sway bar design that for the most part worked (some stacking tolerances and minor mis-calculations rendered the prototype un-usable, but the proof of concept and overall design functioned perfectly.) I meant to correct the measurements and make a second prototype for the 4Runner, but a lot of things got in the way of it and at this point the project is on the back burner.
4th Gen Disconnecting Sway Bar Set-Up
BlackWorksInc is offline   Reply With QuoteReply With Quote
Old 04-08-2015, 12:19 AM #8
RaceTRaCk RaceTRaCk is offline
Real Name: B
RaceTRaCk is on a distinguished road
Real Name: B
I run without sway bars as well. It leans quite a bit on the highway but I've learned to adjust my driving (also running stiff ome 886 coils). I go wheeling enough to merit not having them on, helps the IFS flex a lot more.
2004 4Runner SE V8 : YUKON: ARB: 35s: TOYTEC
RaceTRaCk is offline   Reply With QuoteReply With Quote
Old 04-08-2015, 09:27 AM #9
Real Name: Tony
Real Name: Tony
More weight, pushes the truck around. When towing you want all the stability you can get. One of the reasons I put my rear back on, I need a trailer for work to haul my tools and equipment. When it's a play rig only I'll take it back off.
Old 04-08-2015, 10:47 AM #10
CXS CXS is offline
Real Name: Chris
CXS CXS is offline
Real Name: Chris
t-man nailed it, I just put them back on and the difference is significant. Much more stable especially in windy conditions.
Chris - '07 SR5
‘05 Limited - sold
Old 04-08-2015, 11:52 AM #11
Real Name: Dan
Real Name: Dan
Thank you both.
Old 04-08-2015, 11:52 PM #12
chiahead52 chiahead52 is offline
chiahead52 is on a distinguished road
can someone explain how removing the front sway bar improves handling both on road and offroad? I see how it would help off road but not on road handling. Thanks
chiahead52 is offline   Reply With QuoteReply With Quote
Old 04-09-2015, 12:15 AM #13
Eh, on-road it depends on how your suspension is set-up. For the most part it doesn't really help you out though.
Old 04-09-2015, 08:17 AM #14
Real Name: Tony
Real Name: Tony
Ya, what blackworksinc said. Offroad it helps that your suspension is more free to move independently, but on road it will lean more and not be as nimble in corners. Takes some getting used to. It does help with hitting potholes though. 😀
Old 04-09-2015, 01:13 PM #15
Troymclure's Avatar
Real Name: Jake
Troymclure's Avatar
Real Name: Jake
Yeah I wouldnt say it handles better in terms of cornering, but with stiff front coilovers like I have, it helps allow each wheel to move up and down over bumps independently which really makes the ride smoother down the highway. The same thing applies offroad
Disconnecting sway bars - front? and/or rear? Mr. B 3rd gen T4Rs 65 01-11-2017 03:26 PM
4th Gen Disconnecting Sway Bar Set-Up BlackWorksInc 4th Gen T4Rs 45 03-26-2016 12:43 AM
No sway bars you say? Bskelton 4th Gen T4Rs 15 11-28-2012 05:02 PM
Sway bars? rossmkh 3rd gen T4Rs 3 06-16-2012 02:14 PM
sway bars ocrunner Classic T4Rs 8 10-04-2010 08:43 PM
