Originally Posted by thenuka
Hi all,
Major fan of the forum, being looking at all of your fancy builds.
I got the truck used in April 2014, got the timing belt, and all fluids changed then. It was running quite well until a month ago. Noticed a lack of breaking or double breaking when coming to a stop. Upon further investigation, we saw leaked fluid by the rear driver side brakes. It wasn't sprayed all around so I was hopeful it's a brake leak.
Took it to the mechanic and was told I am wrong. It is the infamous axle leak! I thought this was only for 3rd gens but I guess s**t happens...they are recommending to replace just the seal and leaving it up to me to replace both seals or just one. These guys are reputable and have two former Toyota master techs so I trust them.
Questions I'd like help with
- what could've caused it? They checked the breather and it's not blocked.
- replace both rear seals or just one? 2 hr vs 4.5 hr job.
- why aren't they replacing the bearings? They mentioned just replacing the seals would be sufficient
- replace brake pads as well or can I just wash off the oil with a solvent?
Thanks a bunch everyone!
I believe it uses a sealed bearing, much like a front wheel bearing. the seal is separate, and mounts in the housing.
as to why its leaking.. parts fail. it may just be a bad seal.
I would have the bearing inspected closely, if its bad, that could take out a seal also.
as far as to do both sides or not, that's totally up to you, as they are completely independent from each other. if the other side is tight, and not leaking, you might be able to hold off on replacing it for now.
1985 pickup
: EFI 331/4r70W-Dana 300-42 TSL SXII's/raceline beadlocks-30spl longs-5.29's-spools-sky Hi steer-OBA/4g tank-10.5k RR winch-dual blue tops-200 amp alt-flatbed.
1985 4runner sr5
: 22RE/5spd-6" pro-comp suspension-37 BFG at's-5.29 gears-Badlands Basher bumper-8.5k RR winch.
2006 4runner v8 limited
: stock.
Build Thread YouTube Channel
