04-19-2015, 01:51 PM
Help! Door actuator repair gone wrong. Can't open door at all.
So I thought I'd change the rear driver's side door actuator bc it was out. Got a new actuator. Changed it out. Went to test it, but the door wouldn't open right. It would lock and unlock with the remote, etc, but was still acting locked from the outside when I tried the external handle.
I assumed I had the child lock activated somehow. I switched the child lock lever from outside with the door open and shut the door. AND...now I can't open the door at all! I hit the remote unlock and the lock switches open and closed now (yay) but the door can't be opened still from inside or outside now.
I'm stuck here and need some advice. I'm afraid I'll have to take the door off or something but not sure I can do that since the door is in a locked position. Anyone made this terrible mistake and have advice? The new actuator seems to work well in that it switches lock and unlock, but I must have had something turned internally and so it's not actually locking or unlocking inside. Before I screwed up and switched the child lock, I could still open the door from inside the backseat, just not from outside the car, but now that's not an option. Help?!
04-19-2015, 03:04 PM
Been doing some more head scratching, and since I was able to open the door from inside before switching the child lock, I think a locksmith should be able to get me back in. Of course that just means I'll be back to the drawing board trying to figure out why I can't open the door from outside after the new actuator install, but that seems like a potential fix once I get it all apart again...ugh
04-19-2015, 09:53 PM
Its likely you didn't instal it correctly. If you hear the actuator working, it must be the outside handle is not attached properly. Oh, and a locksmith likely cannot help they are geared toward keys, not motors and wiring. I would suggest taking a look at it again and find what you missed.
-Pete
07 Shadow Mica V6 Sport
Audio: Eclipse AVN 6620| Alpine PDX 4.150 & 1.600 | CDT HD62 x2 & Fiberglassed 12'' & Lots of Soundproofing
Lighting: 4300K HID, 3000k HID Fogs, LED Interior, Krager HID Driving Lights
Outside: Daystar 2.5/1.5, 285/60R18 Toyo OC AT | T&H High Bull Bar
04-20-2015, 02:25 PM
Trouble is I can't get the door open to take another look...unless the locksmith can get in. I called the dealership and they have a locksmith there so looks like I might be paying dearly for this little project...bummer
04-20-2015, 03:18 PM
Real Name: Chris
Real Name: Chris
You can't pop the door panel off and jimmy it from the inside?
2003 Sport Edition V8 4X4
TRD Taco coils Bilstein 5100 fronts,
MetalTech LT stage 2 kit w/ HD coils/Icon 2.0 shocks
2006+ Headlights 6000K HID
Level 8 MK6 LT285/70-17 Cooper ATP. Flowmaster 50 series
04-20-2015, 03:20 PM
Real Name: Chris
Real Name: Chris
I know it'll be close with the seats and all, but I think I'd remove the seats and try to get that panel off before I'd pay a locksmith to come and try it.
04-20-2015, 03:33 PM
yep, the door panel will have to come off. maybe even cut off and replaced.
but, it sounds like the exterior door handle linkage didn't get hooked up. the interior WAS working, until you disabled it by activating the child safety lock.
its slightly possible a good LS could snag the door handle mechanism and get it popped open....
perhaps put the window down and remove all the trim so you can see down inside. maybe you can get at it with a long screw driver...
if not, remove that inner panel however you can.
1985 pickup : EFI 331/4r70W-Dana 300-42 TSL SXII's/raceline beadlocks-30spl longs-5.29's-spools-sky Hi steer-OBA/4g tank-10.5k RR winch-dual blue tops-200 amp alt-flatbed.
1985 4runner sr5 : 22RE/5spd-6" pro-comp suspension-37 BFG at's-5.29 gears-Badlands Basher bumper-8.5k RR winch.
2006 4runner v8 limited : stock. Build Thread YouTube Channel
04-20-2015, 05:09 PM
Man I'm hoping to not have to cut the inner panel out, because there is no way to get the panel off with the door closed (no way that would also leave the panel re-usable). It's not really a seating issue. The seat is out of the way and there's still not enough room to pop the panel off from inside.
Honestly even if I took a sawzall to the panel and was able to look at where the lock assembly is, it would be a struggle to 'figure out' how to unlock it. Gonna take it to the dealer and lubricate myself...
I guess if their locksmith can't get in, I'll try to find a different one, and if that doesn't work...the sawzall...
04-20-2015, 05:14 PM
Ay, Bummer. Good luck. Hope it isn't too bad!
2022 LUNAR ROCK TRAIL SPECIAL EDITION
2010 MAGNETIC GREY SR5 PREMIUM
2004 V6 WHITE 4RUNNER SPORT
1995 V6 3.0 BLACK 4RUNNER 4X4 (Retired)
4th & 5th Gen UCA Install Thread
04-20-2015, 05:23 PM
Real Name: Chris
Real Name: Chris
I just looked in mine. With the seat out, I'm pretty sure the panel could be removed. It looks like the edges tuck in behind the door seal, but it should come out with a little persuasion.
04-20-2015, 05:33 PM
I don't think its a matter of unlocking it. its getting the latch open. once the panel is off you would be able to see the rod that goes between the handle, and the latch. pulling that would open the door.
04-20-2015, 06:13 PM
Ah. Yeah that makes perfect sense. I may end up trying that. The panel sure was easier to take off when I could get the door open lol
04-20-2015, 06:15 PM
I couldn't get it last night but was getting frustrated and didn't want to break anything. Sounds worth another shot.
04-20-2015, 08:11 PM
I had my front passenger lock completely fail with the door closed. You can get the panel off, it just takes time and frustration. The plastic will bend (and hopefully not break). I started at the top where the panel is hooked over the lip. Put down the window.
This is related to the front door but here is a thread you can look at as well.
2004 4Runner SR5 SR5 - V6, 4X4, Moonroof , JBL, Leather, Stratosphere Mica
Installed Mods: Spoiler, HIR bulbs, Kenwood DNX6960 Nav, Back Window Up with Remote Mod, Rear Camera, LED Tails, Key Reminder Disable, OEM Automatic Headlights, Rear USB Ports, Seat Heaters, Aftermarket Third Row, Heated Side View Mirror
Locations: VA
04-22-2015, 03:00 PM
That is super helpful. I know my actuator let me unlock the door from inside before I flipped the child lock, so I guess the next question will be...once I'm inside the panel, what will I need to do exactly to get the door open? Is there a way to flip the child lock on the actuator with the door still closed IF I can snake my hand in and grab the actuator? This will be a very blind grab but I'm hopeful.
Probably going to have to take the panel off the other side of the car that actually opens and mess with trying to flip that actuator out of child lock when I can see it a little better. Then go back and feel around in the dark for a switch.
It was suggested to me by a locksmith that just prying a coat hanger into the space and trying to snag the child lock might work too. Anyone ever tried that?
Also thanks so much for your link. I did a fair amount of digging around before posting and never came across yours. Super helpful.
