Thread Tools Rating: Thread Rating: 7 votes, 5.00 average. Display Modes
Old 05-23-2015, 04:41 PM #46
Marde Marde is offline
Marde is on a distinguished road
@46runner
I do not have my own pics but here are some at another thread.
Pics at post-18 and post-23 of this thread
Advice-Drop the Pan or Dealer Flush?
The pics show an external cooler. I do not have an external cooler on my (friends) 4R. My cooler is integrated into the radiator. My trans cooler lines are connected onto the radiator and can be seen on the drivers-side of the radiator. Look in-between the radiator and the car battery and you will find them.
Before doing anything, get the engine hot, then do the flush.
My plan is to disconnect the cooler line (the top-one) on the radiator and extend this hose with some raw tubing, and place this hose into an empty bucket, -the bucket will be tick-marked so I can see and measure the amount of fluid that comes out when I start the engine.
Connect some raw tubing onto the (top-one) cooler nipple and add a very large funnel. Keep funnel filled with new fluid. Start car and old fluid comes out (goes into the bucket) while new fluid goes into the cooler via the funnel. Keep funnel filled with new fluid.
Turn off the engine when you see the trans fluid coming out changes color from old-dark to new-red color.
Compare "measured amounts" of how much came-out verses how much went in. Remove the overflow/level checking plug and check that some fluid comes out, to ensure it is properly filled.
Marde is offline   Reply With QuoteReply With Quote
Old 05-23-2015, 07:27 PM #47
ZiaMan ZiaMan is offline
ZiaMan is on a distinguished road
Originally Posted by 46runner View Post
Marde, Ziaman, or anyone else. If you can post a pic of the trans cooler and identify the hose to be used, that would be great. It certainly sounds a bit easier to access than going underneath. Thx!
Originally Posted by Marde View Post
@46runner
I do have the external transmission cooler in addition to the transmission lines in the radiator. My transmission lines attach to the radiator on the passenger side. I will take pics in the next week or so and post them up with notes.
2008 Nautical Blue GX470
Bilstein 6112/5160
ZiaMan is offline   Reply With QuoteReply With Quote
Old 06-22-2015, 07:06 PM #48
03limited2WD 03limited2WD is offline
03limited2WD is on a distinguished road
Excellent write up. Just for posterity sake, anyone who is curious about using fully synthetic ATF made from an ester base, rather than mineral oil base:
Redline D4 is designed to replace Toyota Type 4 ATF (T4)
Redline D6 for a Toyota that uses WS Fluid (World Standard ATF)
Iv'e been running D4 for years in my 2003 4-speed, with no ill consequences.
03limited2WD is offline   Reply With QuoteReply With Quote
Old 06-24-2015, 09:38 AM #49
fdbyrne fdbyrne is offline
fdbyrne is on a distinguished road
Thank you for the writeup. I did mine last night. Mine was a bit easier since I have a transmission dipstick under the hood. Even then, I'm pretty sure that I overfilled it slightly. I'll check again when I get home.
I also took the opportunity to replace the metal transmission fluid cooler lines under the radiator. They were pretty badly corroded.
It shifted pretty smooth before, but seems even better now.
Any potential problem with having it overfilled for a couple of days?
2004 SR5 4x4 V6 - With New Head Gaskets
fdbyrne is offline   Reply With QuoteReply With Quote
Old 06-24-2015, 09:53 AM #50
acronin2 acronin2 is offline
Real Name: Lance
acronin2 is on a distinguished road
Real Name: Lance
Do you have Part #s for the metal trans fluid cooler lines? I am planning on doing the ATF exchange soon. What is the procedure for replacing the lines?
2004 Sport Titanium Metallic, Black WeatherTech Mats, J.A.'s Map Light Mod, 2014 Scion Pioneer Bespoke touchscreen w/ Back Up Camera, Arc Audio xdi805 amp, Handsfree phone/bluetooth steering wheel controls, 06-09 OEM LED tail lights, Interior LED Swap, Gentex 177 AutoDimming Mirror w/ Amber Compass, Sunvisor GPS mod, Avitol 4003 Remote Start w/ factory keyfob, J.A.'s DRL Mod, Back Window Up Hack, OEM 115v AC inverter install, Smokers Kit
acronin2 is offline   Reply With QuoteReply With Quote
Old 06-24-2015, 10:14 AM #51
Actually, yes. I can't promise that it's the same part for all years, though. For my 2004 SR5 V6 4x4, the part was 32907-60070. My dealer gives me shop prices because I'm always in there and the shop price for the lines was $71.50.
As for the procedure to replace them, it's very straight forward. Just unbolt the old set of lines from the frame, disconnect all 4 rubber hoses (I marked all my hoses to make sure I attached them all to the right nipple), reconnect the rubber lines to the new metal lines, bolt the metal lines to the frame.
I broke off one of the two bolts that held the old set of lines in place. I had to drill it out and retap the holes. I'd recommend replacing the bolts while you do it since the new part doesn't come with them and the bolts themselves will be in about as good of shape as the lines that need to be replaced. They are M8 bolts with 1.25 thread pitch. They cost me $.69 each at the local Ace Hardware for the hardened ones.
Also, the spring clips that hold the rubber hoses to the metal lines were completely shot. I had a hard time getting them off because the tabs that you compress to release the spring tension just broke off. I replaced all 4 with new hose clamps.
Old 06-24-2015, 07:15 PM #52
Real Name: Lance
Real Name: Lance
Thanks for the response. I will have to take a look to see how bad mine are but I am assuming they could use replacing with 125,000 miles on the OD. I have an 04' SE (w/ dipstick) so the part number above should fit. Just to confirm the part number 32907-60070 comes with two metal lines (one for inlet tube and the other for outlet tube)? TIA
Old 06-24-2015, 07:20 PM #53
Yes. Both tubes are welded to a bracket that bolts to a crossmember under the radiator.
Old 06-24-2015, 07:30 PM #54
Real Name: Lance
Real Name: Lance
Lats question (I hope), how much fluid did you lose while replacing the lines? Did you catch the fluid in a pan or container so you could add the same amount back in? Or is the amount of fluid negligible?
Old 06-24-2015, 07:44 PM #55
I drained my pan first and got 5 quarts. It just kept coming. I then pulled the lines while the drain plug was still out of the pan. Very little fluid came out of the lines. I used a catch pan just to keep from making a mess. I doubt there was 1/4 quart lost during the line replacement.
Old 06-25-2015, 09:14 AM #56
NuclearN8's Avatar
NuclearN8 NuclearN8 is offline
NuclearN8 is on a distinguished road
NuclearN8's Avatar
Thanks for getting back here and for the correction! I was really hoping I had you wrong, and the system flows as I was guessing earlier. Now back to my Dr Frankenstein plans of how I will do the flush on the 4R....
Cheers!
This is correct, it's the same for all Toyotas... Transmission fluid always enters the top of the oem integral radiator coolers and exits the bottom to flow back to the transmission.
This is opposite to any auxiliary cooler that would be installed. For example if installed on it's side, all aux cooler manufacturers tell you to make the bottom port of the aux cooler the inlet and top the outlet. So if installing an aux trans cooler (after the oem integral cooler in the flowpath) the line from the bottom of the radiator (outlet) should go into the bottom port of the aux trans cooler to serve as the inlet, then top port of aux cooler should be conneted to the transmission hard lines to feed back to the transmission.
NuclearN8 is offline   Reply With QuoteReply With Quote
Old 06-25-2015, 11:13 AM #57
NuclearN8's Avatar
NuclearN8's Avatar
Originally Posted by mkjh View Post
Did you notice any difference after doing it? Did it shift smoother or anything?
the vehicle shifts smoother with new fluid, yes. Adding an aux cooler simply keeps temps lower (all other things being equal, which in turn increases time period between required fluid flushes) in mountainous areas and/or when trailering. Generally speaking on flat land (unless you live in the middle east or routinely see temps above 120F) an aux trans cooler is not needed as the transmission is hardly working on flat land... having cruise control on over mountains, towing and accelerating like you just stole the vehicle, are all actions that put heaviest strain on a transmission and therefore cause temperatures to rise the fastest.
Old 06-25-2015, 11:29 AM #58
Do you know how effective the external cooler actually is? I'm curious how much cooling it actually does.
I've been pondering this for the last couple of days ever since I did my fluid exchange. My thinking is that the main radiator that is used to cool the fluid is huge. Lots of surface area and a huge fan in front. How much difference would a much smaller but dedicated inline radiator do?
I'm sure that it couldn't hurt, but are we talking about 5% better cooling? 10%? 50%?
I'm not being argumentative or anything. I genuinely want to know.
Old 07-13-2015, 06:41 AM #59
Real Name: Lance
Real Name: Lance
I have couple more questions for anyone that has used this method. FYI I am doing this on 04 V6 with dipstick (T-IV fluid)
1. Would there be any benefit to jacking up the front end for the initial draining of the transmission pan in order to try to get the most ATF out?
2. Should I get the engine up to operating temp before pulling the transmission pan drain plug?
Thanks in advance
Old 07-15-2015, 06:49 AM #60
46runner's Avatar
46runner 46runner is offline
46runner has a spectacular aura about 46runner has a spectacular aura about
46runner's Avatar
Thanks in advance
1. Not necessary and little benefit in my opinion
2. Best to drain cold, when all of the ATF is at the bottom of the pan.
46runner is offline   Reply With QuoteReply With Quote
Toyota Vehicle Exchange Jeffrey_VB General Discussions 12 05-31-2014 09:52 PM
Southwest gear exchange gen3Ken Southwest 0 10-16-2012 06:48 AM
Possible to exchange gears between 98 Limited & 98 SR5? CarolinaCowboy 3rd gen T4Rs 18 09-15-2010 05:45 PM
Revolution Money Exchange bstboy Off Topic 0 02-03-2008 05:31 PM
Speed Trap Exchange bryancos Off Topic 5 01-25-2008 02:43 AM
