02-26-2018, 10:59 AM
Clicking from underneath glovebox only
For the last several months i have been dealing with a clicking coming from what sounds like underneath my glovebox on the passenger side. It sounds almost identical to a leaf being hit by the fan. This the rate of "clicking" varies with the fan speed. I have changed the cabin filter and to the best of my ability verified that there is nothing that i can feel stuck anywhere its supposed to be. I thought this may be from the AC servo motor but upon reading about it more, it sounds like in that instance the noise stops when using defrost only but in my car the noise remains constant regardless of which vents are being used. Also regardless of whether the AC is on or the heat is on or if the recirculate is on.
What else could it be coming from?
2006 limited v8 4wd
Toytec/ebiach 3” coilover lift with 1/2” top plate spacers, Jba high caster UCA’s, blistein 5100 rear shocks with toytec superflex hd springs, Cooper st max 255/80/17 with mb 352 in 17x9 -12 mm offset, auxbeam light bar in front bumper, custom retrofit headlights, SS brake lines, 5th gen brakes, custom rear storage box
02-26-2018, 11:05 AM
Have you tried cycling the temp from full low to full high several times?
I experienced the same exact thing, I thought for sure it was a leaf stuck somewhere but it was indeed the servo, cycling the temp from HI to LO a few times fixed it for now.
'99 SR5, 2007 Sport
02-26-2018, 11:18 AM
Ive cycled it about 5 times today and it made it quieter but just barely.
Tried cycling it on all the different vent settings
2006 limited v8 4wd
02-26-2018, 12:19 PM
My cabin filter started rattling the last time I checked it and it has sort of a random click sound at certain air speeds. Could be that.
02-26-2018, 12:57 PM
It's an issue with the re-circulating air actuator. Have you tried to turn off the re-circulating air option to see if it stops? This is a known issue with the 4th gen 4runners. Mine does it as well as my dad's. There's a little white trigger behind the glove box and the clicking noise usually means the motor is going out or already gone out. The higher the fan speed the louder it'll get. I've learned to just live with the noise
02-26-2018, 06:35 PM
Happens with cabin filter removed....
2006 limited v8 4wd
02-26-2018, 06:37 PM
Re-circulate button doesn’t make a difference but now upon listening I can no longer hear the actuator going when I turn re-circulate on or off and I used to be able to hear a minute split second whir as it kicked on or off
2006 limited v8 4wd
02-27-2018, 08:08 PM
OP, with the Limited, you've actually got 4 servos under the dash with the potential to go bad and click or grind. If you got to somewhere like Partznet, you can find the parts diagram. You've got air mix servos for passenger/driver sides that control the mix of cooled/heated air to maintain set temp. There's a mode servo that routes air to dash/floor/windshield/etc. And finally, there's a servo for the recird door.
In my case, it appeared to be the passenger side air mix that started clicking first. Makes sense given the air mix doors probably get the most movement. Right before my dash replacement came in, it started grinding like the gears were completely gone. From time to time, I also got some clicking from my driver's side servo.
In the end, I first attempted to replace them myself, but the passenger side appears unreachable without removing the blower motor. So, I handed my new servos over to Toyota while my dash pad was being replaced under warranty. They still charged me $300ish...claiming the dash removal only chopped off a couple of hours of the shop time to reach the passenger servo. %!@#$ highway robbery...anyway. Good luck.
2003-2022: '03 Limited V8 4x4 - Galactic Gray Mica
2022-Present: '21 Nightshade 4x4 - Magnetic Gray Metallic
02-28-2018, 12:25 PM
I believe in my case I have isolated the sound to coming from the blower motor
I unplugged the blower and the noise stopped
I removed the whole blower assembly and if I spin it quick enough I can hear an occasional click
I’ll be disassembling the blower unit today sometime and worst case scenario I can order a replacement for $50 on rockauto
2006 limited v8 4wd
11-30-2018, 12:20 PM
2 servos replaced. Notes here DIY: Replace Servo Sub-Assy
Black 2004 Toyota 4Runner SR5 V8 (born again Aug 2014)
DIY: spark plugs, servos for vent and airmix, fender splash shield, seafoam, rear axle seal & parking brake, exhaust muffler tailpipe, rear brakes, hood struts, a/c recharge, front brakes, front struts, rear shocks, ATF exchange, smartphone holder.
01-09-2019, 12:44 PM
Thanks for the info guys. My 2007 V8 just started doing something similar! Ill going to chase it this weekend.
01-15-2023, 06:24 PM
Real Name: Hoodlm
Real Name: Hoodlm
Fixed Heat and Clicking Noise Under Dash
This thread isn't too old so I thought I'd share my experience via video. I just fixed mine yesterday. Works great now. After reading through this and not finding any vids on how to fix it, I recorded my work. Hope this helps! 2000 3rd Gen 4Runner Heater Not Blowing Hot Air - YouTube
2000 4Runner Limited, 2" ToyTec Body Lift, 255/85R16 Maxxis Big Horns, 3" Lift Bilstein 5100s front and rear, OME 891 rear springs, 4x Innovations Rock Sliders, Silencer MOD, Deckplate MOD, PlastiDip Guru, Total Chaos UCAs, ToyTec Adjustable Rear Lower Links and Panhard, Tundra Brake Upgrade
My Build Thread
01-18-2023, 09:40 AM
Nice video hoodlm
Just an update, the servo still isn't chirping 5 years later after "fixing" using the HI and LO trick.
I also started having a problem with the blend door making a horrible sound (its trying to open when its already full open) which I "fixed" by never using the recirculate button.
'99 SR5, 2007 Sport
