05-26-2015, 09:22 AM
#46
Just did the 5th Gen brake upgrade this weekend. Everything went smooth and the brakes feel great. Didn't have a frozen solid piston on the old but they were rusty and now it feels like I have less drag from the brakes. I bought all the same part numbers as in the first page of this post. The calipers from Rock auto came with all the hardware (pins and springs). Highly recommend this if anyone is replacing calipers anyway.
2006 Limited V8 FJ coils all around - Bilstein 5100's set at 1.75 - Icon Rear 2.0 - Daystar 1.5 rear spacer - Customish' end links - - LED interior upgrade- GROM audio blutooth unit- weathertech floormats -Spidertraxx 1.25" Wheel Spacers Michelin LTX AT/2 275/65/18
05-26-2015, 11:44 PM
#47
Just picked up a 2004 SR5 w the 4.7 and 17" wheels-there's some pulsating/pulling going on so this upgrade may be my first mod. Has anyone tried to install the 5th gen parts on a 4th gen with the smaller brake rotors yet? If so, did they fit?
05-27-2015, 06:36 AM
#48
Looks like its time to drive up to rock river in madison WI a little over an hour a way and test the waters with this.
4th gen sr5 and I just got the dreaded piston lock on the drivers side now LOL but heck for the bigger brakes and bigger rotors and better stopping it maybe worth biting the core charge LOL
05-27-2015, 10:18 AM
#49
I sent my originals back, I'll post back once i receive the credit for the core charge. They prob won't even notice the difference, They look identical in size shape. Here's hoping...
05-27-2015, 11:02 AM
#50
I believe that you will need to either cut or bend the front dust shields.
If brute force doesn't work, you're not using enough of it.
Current: 2013 Land Cruiser
Gone: 2003 4Runner V8 Limited 4WD
05-27-2015, 04:31 PM
#51
Will the Front and Rear 5th Gen Calipers fit with the OEM 4th Gen brake lines?
Or do they need to be replaced as well to fit the new calipers??
05-27-2015, 10:03 PM
#52
I don't know man they might figure it out when they have an explosion of 5th gen 4runner calipers brakes and rotors once they send in the old core and they receive the 4th gen back cause a inventory issue
05-29-2015, 07:08 AM
#53
i did my front calipers last night using 5th gen. Bolt on and go, no issues. I have 17" wheels and large rotors already(limited) I used a new set of 4th gen brake pads i already had laying on the shelf. They fit perfectly.
The old setup had 2 shims between piston and pad, a solid one and a slotted one. I did leave out the slotted spacer, but put the solid one back in. I did that because the brake pads already had 1 shim attached to the back of the pad, where the toyota pads that came out did not. So,,,still 2 shims in there. The slotted shims I left out had a coating on them. Hope I made correct decision,,,,will find out i guess.
1998 limited v6 382,000+ miles on everyday driver,,,sold it
2005 limited v6 i keep this one clean.
05-29-2015, 09:21 AM
#54
They bot on and go to stock 4th Gen brake lines?
05-29-2015, 10:42 AM
#55
What is the size difference in the calipers? Are we gonna be able to fit 16'' wheels or only 17''?
05-29-2015, 10:50 AM
#56
what pads are you guys going with?
2009 Trail Edition
2006 Sport Edition - SOLD
05-31-2015, 08:09 PM
#57
Any word on this yet?
05-31-2015, 10:37 PM
#58
I finally had time to send my cores back in on Friday so I'll let you guys know what happens
2008 Toyota 4Runner Limited V6
| Spidertrax | OME 886 and Icon Overland Coils | Kenwood DNX9980HD | JL 8W3| HID | Full LED |
| S2000 headlight retrofit | URD Spec U Long Tube Headers | Borla Cat-Back Dual Exhaust | 5th Gen Brakes |
06-01-2015, 01:01 PM
#59
Still shipping. I will update once I hear back
06-01-2015, 01:46 PM
#60
Real Name: Nick
Real Name: Nick
Did you end up buying at NAPA? If so, which year did you ask for, and which casting number?
2017 Chevrolet Silverado 1500 LT Z71
2011 Audi A4 2.0T Quattro
2005 4Runner SE V6 4WD (Sold)
2004 Volvo S60R (Sold)
1999 Jeep Cherokee Sport (Sold)
Thread |
Thread Starter |
Forum |
Replies |
Last Post |
Wtb 3rd gen calipers
K9guy |
Want to Buy/Trade |
2 |
11-28-2014 11:20 PM |
Calipers
skiwindjunkie |
4th Gen T4Rs |
4 |
04-19-2010 12:55 AM |
r&r calipers 97 t4r
crowbar |
3rd gen T4Rs |
1 |
02-11-2010 08:39 PM |
4th Gen Calipers
mid9pitstop |
Problems & Warranty Issues |
12 |
06-27-2009 09:48 PM |
