Thread Tools Rating: Thread Rating: 6 votes, 5.00 average. Display Modes
Old 05-10-2015, 10:46 PM #1
084RUNNAH's Avatar
084RUNNAH 084RUNNAH is offline
084RUNNAH is on a distinguished road
084RUNNAH's Avatar
5th Gen Calipers
Did my first brake job on my truck since buying her new. Since I joined this forum, never really contributed much and just roamed so now I can finally do it. I noticed many of us have the dreaded seized caliper issues and not wanting to deal with this problem again, decided to do some research and took the leap on buying 5th gen calipers, front rotors and pads.
Front and rear calipers are direct fit / bolt on.
Rotors fit without modifications
4th and 5th gen 4Runners share the same brake pads
Calipers are almost identical. Each pistons are 3mm larger
Rotors are 13.30". Only difference with the rotors are the fronts are thicker meaning less chances of rotor warping and better cooling
At the same time I replaced all 6 brake flex hoses with stainless steel extended lines and Dot 4 brake fluid
Now I just got to figure out how to upload multiple pictures
Other than that, brake power increased but the best is not having to deal with seized brake calipers.
5th Gen Calipers-image-jpg
2008 Toyota 4Runner Limited V6
| Spidertrax | OME 886 and Icon Overland Coils | Kenwood DNX9980HD | JL 8W3| HID | Full LED |
| S2000 headlight retrofit | URD Spec U Long Tube Headers | Borla Cat-Back Dual Exhaust | 5th Gen Brakes |
084RUNNAH is offline   Reply With QuoteReply With Quote
Old 05-10-2015, 10:50 PM #2
084RUNNAH's Avatar
084RUNNAH's Avatar
Another picture of the caliper. Not sure why my pictures are all sideways
Old 05-10-2015, 10:52 PM #3
084RUNNAH's Avatar
084RUNNAH's Avatar
Another view.... Sideways
Old 05-10-2015, 10:55 PM #4
084RUNNAH's Avatar
084RUNNAH's Avatar
Rear brake calipers
Old 05-10-2015, 10:56 PM #5
084RUNNAH's Avatar
084RUNNAH's Avatar
Rear calipers again
Old 05-10-2015, 10:58 PM #6
084RUNNAH's Avatar
084RUNNAH's Avatar
Parts used if anybody wanted the part numbers I used.
Enjoy!
Old 05-10-2015, 11:40 PM #7
yosh2000 yosh2000 is offline
yosh2000 is on a distinguished road
great post, thanks!
would you mind posting the PNs for all six (6) of the SS lines. seems most kits only come with four (4) of them. i have been wanting to all 6 SS lines for a while.
05 4runner SR5 4x4 v8 : Build thread - Hailed totaled
17 Tundra SR5 crewmax 4x4 v8
yosh2000 is offline   Reply With QuoteReply With Quote
Old 05-10-2015, 11:56 PM #8
gtb129 gtb129 is offline
Real Name: Greg
gtb129 is on a distinguished road
Real Name: Greg
What is the size difference in the calipers? Are we gonna be able to fit 16'' wheels or only 17''?
2003 T4R V8 4wd: Daystar lift- 285/75r16 MTs on 2002 Tacoma wheels; 4.5'' backspacing. Weathertech mats, lost the roof rack (plenty of future plans) build: http://www.toyota-4runner.org/4th-ge...on-thread.html
gtb129 is offline   Reply With QuoteReply With Quote
Old 05-10-2015, 11:57 PM #9
BlackWorksInc's Avatar
BlackWorksInc BlackWorksInc is offline
BlackWorksInc is a splendid one to behold BlackWorksInc is a splendid one to behold BlackWorksInc is a splendid one to behold BlackWorksInc is a splendid one to behold BlackWorksInc is a splendid one to behold BlackWorksInc is a splendid one to behold BlackWorksInc is a splendid one to behold BlackWorksInc is a splendid one to behold
I was under the impression that the 5th gen Calipers are the "Sport" Calipers on the 4th gens... Honestly never bothered to look, but how are they different?
BlackWorksInc is offline   Reply With QuoteReply With Quote
Old 05-11-2015, 12:04 AM #10
Real Name: Greg
Real Name: Greg
Edit: Thought you where replying to me
Old 05-11-2015, 07:45 AM #11
084RUNNAH's Avatar
084RUNNAH's Avatar
Only difference I noticed was the brake caliper piston which were 3mm larger resulting in increased braking power.
Caliper size was very close. Maybe a few mm bigger?
The biggest difference will be no more seized calipers. I haven't seen any 5th gen guys having issues with seized caliper issues since 2010.
I would say 17" wheels are minimum size to fit the brakes (Same as 4th generation sport and limited)
I will get back with the extended stainless steel brake lines part numbers I used later today
Old 05-11-2015, 10:53 AM #12
dmalis12 dmalis12 is offline
dmalis12 is on a distinguished road
Thanks for the writeup! I'm about to do mine and I need to do calipers because I think i have the common frozen caliper issue.
Are these a direct bolt up. Anything you needed to do for the install other than normal? Do the brake lines need to be done or will the old work? Also where did you get the caliper's from, part #?
I'm very interested in this because so many have had the 'frozen caliper' issue and this could be a good solution
2006 Limited V8
FJ coils all around - Bilstein 5100's set at 1.75 - Icon Rear 2.0 - Daystar 1.5 rear spacer - Customish' end links - - LED interior upgrade- GROM audio blutooth unit- weathertech floormats -Spidertraxx 1.25" Wheel Spacers Michelin LTX AT/2 275/65/18
dmalis12 is offline   Reply With QuoteReply With Quote
Old 05-11-2015, 12:51 PM #13
084RUNNAH's Avatar
084RUNNAH's Avatar
Yes they are a direct bolt up.
No special tools required.
Brake flex hoses are optional
Old 05-11-2015, 01:08 PM #14
084RUNNAH's Avatar
084RUNNAH's Avatar
Part numbers are here guys
From Rockauto
Calipers:
141.44587
141.44588
141.44287
141.44288
Rear Caliper Brake Flex Hose Stainless Steel Numbers:
950.44507
From All-Pro
Front Caliper Brake Flex Hose Stainless Steel Numbers:
5500FJT-AP-F x 2
Rear Axle Brake Flex Hose Stainless Steel Numbers:
5500FJ-AP x 2
Enjoy!
Old 05-11-2015, 01:42 PM #15
I'm assuming you had the optional Sport brakes on your Limited?
Wtb 3rd gen calipers K9guy Want to Buy/Trade 2 11-28-2014 11:20 PM
Calipers skiwindjunkie 4th Gen T4Rs 4 04-19-2010 12:55 AM
r&r calipers 97 t4r crowbar 3rd gen T4Rs 1 02-11-2010 08:39 PM
4th Gen Calipers mid9pitstop Problems & Warranty Issues 12 06-27-2009 09:48 PM
