Thread Tools Rating: Thread Rating: 6 votes, 5.00 average. Display Modes
Old 09-10-2015, 02:32 AM #151
verman84's Avatar
verman84 verman84 is offline
verman84 is on a distinguished road
verman84's Avatar
Centric has been great. Everything looked really good out of the box and has performed perfectly for 5k miles. Non contact parts of the rotor were painted to prevent corrosion.
I went with centric calipers and rotors, Napa premium pads.
I changed all pads, rotors and calipers. Fronts and rears.
If you order from rock auto, keep your tags and original boxes matched to each part when you send them back to get your full refund. Also choose the option to print the shipping tags from rock auto as they have a deal with FedEx and it's much cheaper than shipping yourself. I paid $24 total (12 each) with the rock auto shipping labels to ship 2 heavy boxes, 2 rear calipers from Chicago to California and 2 front calipers from Chicago to Arizona. I got my full refund back for all 4 calipers no questions asked.
Best investment in my truck yet. I recently drove cross country through the western mountains and I was so happy I did so before that trip. Brakes perform perfectly.
2008 SR5 v6 4x4 - Galactic Gray, Bilstein 5100, Nitto Terra Grappler G2 265/70/17
verman84 is offline   Reply With QuoteReply With Quote
Old 09-10-2015, 09:47 AM #152
M1911 M1911 is offline
M1911 is on a distinguished road
Originally Posted by bubbazr2 View Post
Is everyone just changing out their front brakes or are the rears known to seize up too?
I've had rear calipers seize multiple times on my '03 V8 Limited.
If brute force doesn't work, you're not using enough of it.
Current: 2013 Land Cruiser
Gone: 2003 4Runner V8 Limited 4WD
M1911 is offline   Reply With QuoteReply With Quote
Old 09-12-2015, 03:40 PM #153
bubbazr2 bubbazr2 is offline
bubbazr2 is on a distinguished road
What is everyone using to make bleeding the brakes easy? Speedbleeders? Im trying to get all the parts together for the swap.
bubbazr2 is offline   Reply With QuoteReply With Quote
Old 09-12-2015, 08:07 PM #154
emoore924 emoore924 is offline
emoore924 is on a distinguished road
I just upconverted my 2005 sr5 v8 to 2010 Centric calipers all around and 2010 rotors on the front. I *tried* to upgrade the rotors in the rear but was told the rotors were not hub-centric and would not work. The new rear calipers *did* work with the old rear rotors.
All parts were 2010 t4r Centric parts ordered from Rock Auto according to the part # information I found here on the website.
Not sure whether anyone else has experienced this but just an FYI...
Brakes work fine. Still bedding them in...
emoore924 is offline   Reply With QuoteReply With Quote
Old 09-12-2015, 10:48 PM #155
JeffMerr's Avatar
JeffMerr JeffMerr is offline
JeffMerr is on a distinguished road
JeffMerr's Avatar
Strange, replaced my rear rotors with 5th gen just fine.
2009 Trail Edition
2006 Sport Edition - SOLD
JeffMerr is offline   Reply With QuoteReply With Quote
Old 09-13-2015, 01:26 AM #156
verman84's Avatar
verman84's Avatar
Same here. I'm pretty sure the 4th and 5th rears are the same size. I had no issues when I did the conversion.
Old 09-13-2015, 01:29 PM #157
Yes, I believe they were the same size (hence the ability to use the new caliper on the old rotor), but I was told the new ones were not hub-centric and therefore did not mount properly. Simply reused the old rotors with the new calipers and pads... I was not there and did not see with my own eyes so I'm getting this 2nd hand from the tech (he does know his stuff).
Old 09-13-2015, 09:38 PM #158
chjuj chjuj is offline
chjuj is on a distinguished road
What is the size difference in the calipers? Are we gonna be able to fit 16'' wheels or only 17''?
chjuj is offline   Reply With QuoteReply With Quote
Old 09-13-2015, 09:40 PM #159
I believe they require 17s.
Old 09-14-2015, 10:47 AM #160
HaulsBike HaulsBike is offline
HaulsBike is on a distinguished road
Ordering the parts for my rears now. I have a warped rotor for sure and worried it may be the seized caliper issue.
I know the rear has integrated parking break etc. As far as I know my parking brake is fine.
All I need if I want to do my rear calipers is:
1) The calipers listed at the beginning of this thread (#s 14144587 & 14144588)
2) Potentially new lines (since you are in there)
3) 5th gen rear rotors (anyone have part numbers? - Can't find on Rockauto)
4) 5th gen rear pads
Is there anything additional needed? Do I need anything special to have it "hook up" with the parking brake mechanism? DO I need to replace anything in the parking brake while I am in there?
Thanks - I am a noob to this truck.
HaulsBike is offline   Reply With QuoteReply With Quote
Old 09-14-2015, 10:51 AM #161
084RUNNAH's Avatar
084RUNNAH 084RUNNAH is offline
084RUNNAH is on a distinguished road
084RUNNAH's Avatar
I would personally use the 4th gen rotor rather than the 5th gen rotor. I believe the center bore is different which may cause a problem
2008 Toyota 4Runner Limited V6
| Spidertrax | OME 886 and Icon Overland Coils | Kenwood DNX9980HD | JL 8W3| HID | Full LED |
| S2000 headlight retrofit | URD Spec U Long Tube Headers | Borla Cat-Back Dual Exhaust | 5th Gen Brakes |
084RUNNAH is offline   Reply With QuoteReply With Quote
Old 09-14-2015, 11:10 AM #162
paraordnance's Avatar
paraordnance paraordnance is offline
paraordnance is on a distinguished road
Yeah, Speedbleeders highly recommended for the job. Makes it almost too easy
2004 4Runner Limited V8 4WD
Toytec Ultimate 3" (X-REAS & RAS - delete). LS460 + STi retrofit, Switchback Halos, LEDs in/out, Fog light mod.
CBI front bumper. 285/70/17 Duratracs.
JVC KW-V50BT with Hertz HCP4D & Hertz HCP1D, Hertz ESK-165 components and JL 10TW3 in custom stealth enclosure. Backup camera and steering wheel controls.
paraordnance is offline   Reply With QuoteReply With Quote
Old 09-14-2015, 11:59 AM #163
Ahhhh - thanks. That makes sense.
Old 09-14-2015, 08:23 PM #164
^^ this
Old 09-15-2015, 08:57 AM #165
I am definitely getting that annoying pulsing feeling. Is there any way to be sure if it is coming from the front or the rear? I don't feel it through the steering wheel at all, but there is an uneven stopping feeling that feels rotational.
I am assuming that since I am not feeling anything through the steering wheel my problem is likely the rears. Is this a logical assumption?
I don't mind spending money to fix the problem, but I would rather not drop $450 on all new front brakes for no reason. There is decent life left on the front pads and rotors.
Wtb 3rd gen calipers K9guy Want to Buy/Trade 2 11-28-2014 11:20 PM
Calipers skiwindjunkie 4th Gen T4Rs 4 04-19-2010 12:55 AM
r&r calipers 97 t4r crowbar 3rd gen T4Rs 1 02-11-2010 08:39 PM
4th Gen Calipers mid9pitstop Problems & Warranty Issues 12 06-27-2009 09:48 PM
