11-07-2015, 03:18 PM
#211
Okay so I finally got a chance to measure a 4th gen rear axle hub and a 5th gen's.
Basically, the 4th gen axle is about 106mm all the way to the hub plate. The 5th gen starts around 108mm and tapers to 106mm just after the rotor face (this is why the wheels fit flush and snug, despite the rotors being slightly larger in the hub diameter.)
Bottom line, use either one, the 5th gen units are bored slightly larger than the 4th gen. But the reality is that since Toyota wheels are both lug & hub centric and you should be using lug centric lug nuts anyways, then the lug nuts will center the rotor when you tighten it. If you feel that is too much looseness for your comfort, just use 4th gen rear rotors.
11-07-2015, 11:50 PM
#212
I've been using the 5th front and rear calipers and rotors since July with zero issues. It brakes beautifully smooth and strong. Best money spent so far.
My biggest complaint is not painting the calipers before putting them on. I thought the coating would keep them clean looking but they've become slightly brown. Not sure if it's rust or brake dust.
Either way if you're considering new calipers, order them painted or paint them first.
2008 SR5 v6 4x4 - Galactic Gray, Bilstein 5100, Nitto Terra Grappler G2 265/70/17
11-08-2015, 12:55 AM
#213
Centric 142 series has new piston and is painted . 20 dollars more though. Money well spent . these brakes are awesome
11-08-2015, 01:38 AM
#214
Real Name: Phil Brown
Thanks for following up, BlackWorks. I knew the specs were slightly different, but other than that, I was in over my head.
-Phil
11-15-2015, 08:11 PM
#215
So it's been about 4 months since I installed the new calipers and rotors and when I was under my truck the other day I noticed the calipers were a rust orange color. My old OEM calipers I took off weren't this color and that was with 100k on them. I live in California so rust isn't really something I'm used to seeing on my truck. Is this just cosmetic?
2009 Trail Edition
2006 Sport Edition - SOLD
11-15-2015, 08:38 PM
#216
Real Name: Bill
Real Name: Bill
You should have painted them....Mine are doing the same after a week (I forgot to paint them before install)...there is some rust color showing up now. Will be painting them next weekend.
11-15-2015, 11:33 PM
#217
Taking them off and painting them isn't really an option for me at this point. Is it going to cause any issues down the road?
2009 Trail Edition
11-15-2015, 11:55 PM
#218
Real Name: Bill
Real Name: Bill
I would just cover up the rotor and surrounding stuff and get some caliper paint and paint them on the car. That's what I'm going to end up doing.
11-20-2015, 10:30 PM
#219
will this upgrade work with 16 inch wheels
11-20-2015, 11:17 PM
#220
Real Name: Bill
Real Name: Bill
Nope.
Originally Posted by 084RUNNAH
I would say 17" wheels are minimum size to fit the brakes (Same as 4th generation sport and limited)
My 03 SR5 came stock with 17"...same as sport and limited and it fit. Maybe an extra option when previous owner bought it?
12-04-2015, 07:43 PM
#221
Question: how do you remove the front calipers since they are connected to rigid metallic lines? I am trying to remove them in order to replace the rotors. Thanks.
12-04-2015, 08:47 PM
#222
Maitre, You can disconnect the metal line at the other end where it meets a flexible line. Make sure you then remove & re-use that short metal line on your new caliper. When installing, keep the connections loose until the caliper is bolted on, then tighten the lines.
1999 BMW M3 coupe(E36) & 2005 V8 sport 4X4 black: ARB bull bar with 4 hella 500s,backup camera in spoiler,VSC off, springs:Tacoma w/ toytec(1/2"Fr) & FJ w/ daystar(1.5"R) spacers,Bora .75" front & Spidertrax 1.25" rear spacers,swaybar bushings upgrade,Stoptech rotors,SS brake lines,RCI Metalworks skids (front, trans.,transfer), Volant CAI,DT shorties w/ Dirty Deeds exhaust,fully soundproofed,Rostra seat heaters,HID (lows),HIR (highs),running board lights (added),aux reverse lights,2006+ tail lights,rear fog mod (tail, brake, directional OR rear fogs),Scion T1819,LED int. lights, key reminder diabled, Land cruiser steering wheel,rear window dog barrier, vent visors, Ultraguage, Enkei Deep Six 20" wheels for summer, factory sport wheels with A/Ts, FJ cruiser wheels with winter tires
12-05-2015, 01:47 AM
#223
Yeah keep those lines and keep them from getting bent or kinked.
The fittings on one of mine stripped out and I had to get a new line cut to size and bend it into place.
Also, loosen the fittings while the caliper is bolted on to the vehicle, it makes it much easier to loosen when the caliper isn't flopping around.
One of mine were impossible to remove and ended up stripping. I had to grind it down and hammer a smaller socket onto it in order to get it off. Damn Midwest rustbelt.
12-05-2015, 12:06 PM
#224
SST4r, would I need to clamp the flexible line before the disconnect in order to prevent any brake fluid leaking?
12-05-2015, 06:05 PM
#225
I wouldn't clamp the line; I'd be worried about damaging it. Someone who knows can chime in if it's OK.
If you have the new caliper ready, don't worry about it leaking. It'll just drip....
drip.....
........drip.
If you're going to keep it disconnected for a period of time, they do sell little plugs for the lines.
Thread |
Thread Starter |
Forum |
Replies |
Last Post |
Wtb 3rd gen calipers
K9guy |
Want to Buy/Trade |
2 |
11-28-2014 11:20 PM |
Calipers
skiwindjunkie |
4th Gen T4Rs |
4 |
04-19-2010 12:55 AM |
r&r calipers 97 t4r
crowbar |
3rd gen T4Rs |
1 |
02-11-2010 08:39 PM |
4th Gen Calipers
mid9pitstop |
Problems & Warranty Issues |
12 |
06-27-2009 09:48 PM |
