Old 05-14-2015, 10:43 PM #1
LTDSC's Avatar
LTDSC LTDSC is offline
Real Name: Sam
LTDSC will become famous soon enough LTDSC will become famous soon enough
LTDSC's Avatar
Real Name: Sam
Grinding noise when hard braking
Brake pads are good, rotors are good and everything else checks out.
Randomly when I stop fast whether I'm doing it on purpose or coming down an incline. Right about when I am completely stopped I feel and hear a grinding/gurgle/scrape noise. It comes from the rear or below the rear seats.
If I had to describe it. It sounds like maybe the brakes are slipping. I know that's not the case but what the hell is it?
Driveline noise? I'm confused.
LTDSC is offline   Reply With QuoteReply With Quote
Old 05-15-2015, 09:30 AM #2
swapmeet's Avatar
swapmeet swapmeet is offline
swapmeet is on a distinguished road
swapmeet's Avatar
ABS/ ATRAC kicking in when it shouldn't? IDK how familiar you are with those sounds but thats my first thought. I don't know what sensors it would be. Do you get any lights on the dash?
Barry White 2007 SR5 V8 Black, Toytec Boss, 17x8 Level 8 MK6, 265/70 Terra Grapplers, Mortar Can Storage, CB, LED's scattered about, Ditch Lights, 4x Sliders, RCI full skid package Flowmaster 50 SUV, XD HIDs, lots of trail rash.
swapmeet is offline   Reply With QuoteReply With Quote
Old 05-15-2015, 09:39 AM #3
NOVA46's Avatar
NOVA46 NOVA46 is offline
Real Name: Scott
NOVA46 is on a distinguished road
NOVA46's Avatar
Real Name: Scott
Maybe the slip on your driveshaft is grinding while compressing? Trying to think outside the box, it's right under the rear seats
2007 V6 4X4Runner SR5, 170K
NOVA46 Build Thread
NOVA46 is offline   Reply With QuoteReply With Quote
Old 05-15-2015, 09:49 AM #4
LTDSC's Avatar
Real Name: Sam
LTDSC's Avatar
Real Name: Sam
That's what I thought it would be too. Either one of your suggestions. No lights on the dash when it happens either. It doesn't stop me in any way from slowing down besides making the noise. And it's not consistent.
Old 05-15-2015, 10:11 AM #5
NOVA46's Avatar
Real Name: Scott
NOVA46's Avatar
Real Name: Scott
Yeah just throw some grease in there and see if that solves it. The other culprits may be axle seals or the hubs
NOVA46 Build Thread
Old 05-15-2015, 10:13 AM #6
LTDSC's Avatar
Real Name: Sam
LTDSC's Avatar
Real Name: Sam
I've worried about the hubs for awhile. 128k miles and im assuming they're OEM like everything else has been. I believe i've driven it a lot harder than the previous owners.
Ill check those and load the driveshaft up on some grease and see what happens. its been awhile since i've greased it.
Old 05-15-2015, 10:22 AM #7
m85476585 m85476585 is offline
Real Name: Matt
m85476585 will become famous soon enough
Real Name: Matt
Our 4runners have Electronic Brakeforce Distribution, so rather than have a proportioning valve they will use the ABS to balance brake force between the wheels. As a result the ABS might kick in sometimes even when it's not needed. If you have no load in the rear it's more likely to reduce rear brake force since those wheels have less traction. With a heavy load in the rear, ABS might come on in the front. I think it senses traction, not load, so it's more likely to happen on loose or uneven surfaces (some grit on the road could do it), just like normal mode ABS.
There's also Brake Assist which "helps" you apply the brakes if it thinks you need to stop hard. It seems to automatically apply maximum braking force, which activates ABS on all surfaces. To me it's annoying because it makes the brakes grab harder and more suddenly than they should.
2007 V8 Limited 4WD
m85476585 is offline   Reply With QuoteReply With Quote
Old 05-15-2015, 11:33 AM #8
LTDSC's Avatar
Real Name: Sam
LTDSC's Avatar
Real Name: Sam
thats some good knowledge right there.
Thanks
Old 05-15-2015, 09:47 PM #9
emoore924 emoore924 is offline
emoore924 is on a distinguished road
Not to thread hijack but that brake assist is a HUGE PITA, especially if you're towing a trailer. Ugh! Let ME put on the brakes please.
emoore924 is offline   Reply With QuoteReply With Quote
Old 12-06-2019, 04:23 PM #10
SeanWN86 SeanWN86 is offline
SeanWN86 is on a distinguished road
Did you ever solve?
SeanWN86 is offline   Reply With QuoteReply With Quote
Old 12-08-2019, 09:38 AM #11
earthrealm earthrealm is offline
earthrealm will become famous soon enough earthrealm will become famous soon enough
similar grinding noise on my 04 rav4, none on the runner
2005 v6, galactic grey 4wd auto : pioneer avh 4400bh dvd hu, pyle reverse cam
2003 rav4 titanuim silver 4wd auto......sold
2004 rav4 titanuim silver 4wd auto : pionneer avhx 5500bt hu, pyle reverse cam
earthrealm is offline   Reply With QuoteReply With Quote
Old 12-08-2019, 10:42 AM #12
Ross4runner's Avatar
Ross4runner Ross4runner is offline
Real Name: MIchael
Ross4runner is on a distinguished road
Real Name: MIchael
Had a grinding noise on my front left when stopping hard it turned out to be a sticking caliper. Wouldnt really call it grinding tho it was more like a really loud moan that you could feel in the floor.
Ross4runner is offline   Reply With QuoteReply With Quote
Old 12-09-2019, 03:01 PM #13
HIMILESV8SPORT's Avatar
HIMILESV8SPORT HIMILESV8SPORT is offline
HIMILESV8SPORT is on a distinguished road
anyone figure it out yet??
Think I have the same noise. Get worse as it gets warmer. 1st stop is quiet, 4-5 stops later and it's much worse with in city stop and go traffic. Pads are OEM and good, rotors are aftermarket, calipers are reman 2010+ and not locked up. I'm thinking it has to be axle/bearing related. Any other ideas?
Eibach pro truck with WOR springs on 1st notch in front. 5100's in rear w/ FJ OEM takeoff coils. 255/70R18 on 18" Limited wheels. 1.5" spacers on rear(one trimmed a bit to correct lean). Gibson catback, 06+Headlamps, auxito 16K bulbs in high, low, and fogs!
HIMILESV8SPORT is offline   Reply With QuoteReply With Quote
Old 12-10-2019, 07:47 PM #14
LTDSC's Avatar
Real Name: Sam
LTDSC's Avatar
Real Name: Sam
ended up being the cheaper toyota brand pads that they stopped making.
Clunk after semi hard/hard braking NCrunner2012 3rd gen T4Rs 18 07-10-2012 12:04 PM
Driver Side Grinding noise under hard braking Sherwood4Runner 3rd gen T4Rs 10 04-27-2012 09:43 AM
hard rocking noise in braking & pedal wobbling 08 Hilux Surf 4th Gen T4Rs 2 07-28-2011 03:02 PM
grinding when braking, locks up at stops, cold start won't go forward zanylany 3rd gen T4Rs 6 03-29-2011 01:29 PM
Creaking noise when braking hard MurrayTheCat 4th Gen T4Rs 4 08-17-2006 07:00 PM
