Old 05-16-2015, 12:18 PM #1
waxyboarder09's Avatar
waxyboarder09 waxyboarder09 is offline
waxyboarder09 is on a distinguished road
OME med or heavy duty?
quick question. (searched and could not find a clear answer)
08 v8 limited
I want to lift it and put a bumper on it. I can't afford both at the same time.
Should I get heavy duty springs (front and rear or just front and med rear)? How harsh will the ride be with out the bumper.
or should I get the med duty springs (front and rear)? and will those be enough for a bumper and winch later?
Thanks for the help!
waxyboarder09 is offline   Reply With QuoteReply With Quote
Old 05-16-2015, 01:06 PM #2
CXS CXS is offline
Real Name: Chris
CXS will become famous soon enough
CXS CXS is offline
Real Name: Chris
If you go medium now and then get a bumper you'll end up losing the lift in front. I had medium when I bought mine, added a SW bumper and winch and ended up at stock height after a while. I just replaced my OME with heavy front and medium rear and it rides nice.
Chris - '07 SR5
‘05 Limited - sold
CXS is offline   Reply With QuoteReply With Quote
Old 05-16-2015, 01:38 PM #3
Range Range is offline
Range is on a distinguished road
I have exactly what CXS does and its works perfectly. I don't plan on getting a rear bumper ever so I have no need for Heavy duty in the rear. To be honest the medium is strong enough.
2004 Limited V8 w/ Factory Nav- OME Front Heavy Coils, OME Rear Medium Coils [] ProComp ES9000 shocks all around [] Shrockworks Single Hoop Bumper w/ PIAA Super White Driving Fog Lights [] Shrockworks Sliders [] KC 4" x 6" Gravity LED Driving Light [] Clazzio Black Seat Covers - Front and Rear [] Spidertrax 1.25" spacers [] Pro Comp MT2 285x70x17 [] 2006 Headlight Mod [] Satoshi Grille [] Black Canvas Back Canvas Jackets [] Black Husky Liners Front and Back [] Gobi Stealth Rack & Ladder
Range is offline   Reply With QuoteReply With Quote
Old 05-16-2015, 01:38 PM #4
Thanks! I am going to get a shockworks also. do you think the ride will be harsh if i just get the heavy duty springs now?
Old 05-16-2015, 02:01 PM #5
without the bumper yes. No question. My truck rides a bit more stiff with nothing in back but when I put at least 50lbs back there its noticeably different. I don't really care because I knew once I modded it the soft ride was out the window.
Old 05-16-2015, 04:25 PM #6
Awesome. Thanks!
Do you guys have any pictures?
I do have a Thule t4 bike rack that is like 100+ pounds with out any bikes on it I have that on in the summer. Should I get the heavy duty rears for that?
Old 05-16-2015, 04:45 PM #7
ebg18t ebg18t is offline
ebg18t is on a distinguished road
Yep. This is the way to go.
'14 VW Touareg & '15 Porsche Cayenne
Sold -- 2004 4Runner SR5 4WD V6 | Properly built & prepared for overland use!
ebg18t is offline   Reply With QuoteReply With Quote
Old 05-16-2015, 06:16 PM #8
CXS CXS is offline
Real Name: Chris
CXS CXS is offline
Real Name: Chris
Originally Posted by waxyboarder09 View Post
Awesome. Thanks!
My picture signature pic shows what it looks like when using mediums with the bumper/winch. It now sits 2" higher than that in the front and is level front to rear. I'll try to get a pic for you if it stops raining.
I'm guessing the bike rack is mounted on the rear bumper but really don't think it calls for heavy springs. With heavies and no load on the rear the ride tends to be pretty harsh.
Chris - '07 SR5
‘05 Limited - sold
Old 05-16-2015, 06:38 PM #9
Dirtluver's Avatar
Dirtluver Dirtluver is offline
Dirtluver is on a distinguished road
Dirtluver's Avatar
crappy pics but its high even after 6years. this is on 32s without any coil spacer in the rear, heavy 886 front and medium 895 rear.
03 4Runner 4.7 LTD 305/70r17 WKO sliders OME heavy+1.5BL Full RCI skid
84 4Runner 22R SAS 35s spool f/r 5.29 highsteer (Part out)
Dirtluver is offline   Reply With QuoteReply With Quote
Old 05-16-2015, 07:25 PM #10
Cool. That's what I was wondering. I was thinking that's really low and was hoping for more lift. Good to know that's with the mediums. I will go with heavy duty and deal with a stuff ride for a little bit.
Old 05-16-2015, 07:26 PM #11
Did you have to do any brake lines? And how is the ride?
Old 05-17-2015, 02:09 PM #12
CruzadoBlanco's Avatar
CruzadoBlanco CruzadoBlanco is offline
CruzadoBlanco is on a distinguished road
for just a normal lift with stock or just over stock travel you dont need brake lines. Its once you get setups like mine you need them. however it never hurts to do them since they are relatively easy to do.
2004 white Limited v8 NOW WITH 35s Build Thread -toytec BOSS front set at 1.5" with 2" spacer and Metaltech LT rear -1" 4crawler BL. -Nitro 4.56 gears. -35x12.50r17 treadwright Guarddog MTs. -swaybars removed. -Ebay uniball UCAs. -RCI skids. -E-locker retrofit with 12voltguy panel and harness. -Shrockworks sliders. - body damage and the such
1989 DLX 4runner SAS BUILD
CruzadoBlanco is offline   Reply With QuoteReply With Quote
Old 05-17-2015, 02:12 PM #13
CXS CXS is offline
Real Name: Chris
CXS CXS is offline
Real Name: Chris
Yep, no modification needed to your brake lines with OME.
Chris - '07 SR5
‘05 Limited - sold
Old 05-23-2015, 08:02 AM #14
Dirtluver's Avatar
Dirtluver's Avatar
Guys are right. And for OME886 Its pretty ruff on potholes but Its not that bad with the weight of the V8 and it can be ride without sway bar and stay stiff on corners. But without the weight of skid plates and sliders I would try 885.
TJM Heavy Duty Recovery Kit - Never Used -FL ebg18t For Sale: Non-T4R Items 2 02-22-2015 09:54 PM
Heavy Duty Tie Rod Ends talonjade 4th Gen T4Rs 38 08-22-2012 08:25 PM
Best heavy-duty bumper? adventureman73 Engines / Suspension / Wheels / Tires / Audio / Accessories 1 04-10-2009 12:34 AM
Need HEAVY DUTY clutch scrollmaster Classic T4Rs 1 06-02-2008 04:15 AM
Looking For Heavy Duty Cv Boots spcn 4th Gen T4Rs 1 09-01-2007 10:16 AM
