05-27-2015, 03:31 PM
Anyone else think this is annoying?
Love my 4Runner, but it drives me crazy how every time I get into the truck the HVAC controls automatically default to air recirculation. I like to always bring in outside fresh air and every time I turn the truck off and get back in it always switchs back to recirculation automatically.
Anyone know a way around it, or how to make it stay on its last setting when it was shut off?
05-27-2015, 03:42 PM
I've only had my runner for a couple of months and noticed this too...It is quite annoying!
05-27-2015, 03:43 PM
it is irritating. but I think mine does the opposite, at least it used to. it resets to fresh air. in the mornings when its freezing cold, I don't want outside air coming in..
not sure what I have done, but the last few months, it has stayed on recirculate...
maybe it has to do with the weather/air temps?
1985 pickup : EFI 331/4r70W-Dana 300-42 TSL SXII's/raceline beadlocks-30spl longs-5.29's-spools-sky Hi steer-OBA/4g tank-10.5k RR winch-dual blue tops-200 amp alt-flatbed.
1985 4runner sr5 : 22RE/5spd-6" pro-comp suspension-37 BFG at's-5.29 gears-Badlands Basher bumper-8.5k RR winch.
2006 4runner v8 limited : stock. Build Thread YouTube Channel
05-27-2015, 05:44 PM
it does have to do with air temps. if it is warmer outside that you have it set at in the info display, it will start in recirc. if it is cooler outside than you have it set at, it will bring outside air.
for example, if i have it set at "LO" in the info display and it is 95* out, it will start in recirc. if it was 30* out, it would start in outside air mode
or at least this is what i have been able to make sense of after owning it through a winter
05 4runner SR5 4x4 v8 : Build thread - Hailed totaled
17 Tundra SR5 crewmax 4x4 v8
05-27-2015, 06:06 PM
That is correct, that is how it works;
2013 Silver Trail (with KDSS)-Nitto TG-G2, Bilstein 5100, Custom lift: front 2.1", rear 1.5" (lift info: [URL=https://www.toyota-4runner.org/2938235-post744.html[/URL] thread #744)
1995 SR5 4x4, 1996 SR5 4x4, 2005 SR5 V8 4x4- All Sold, but not forgotten!
DON'T GET CONFUSED BETWEEN MY PERSONALITY AND MY ATTITUDE. MY PERSONALITY IS WHO I AM...MY ATTITUDE DEPENDS ON WHO YOU ARE
05-27-2015, 06:50 PM
That is not exactly correct, it depends on outside air temp, set temp, and set fan speed from what i can tell. I normally leave mine set at about 68 and fan speed 2 and when i get in after work and the display shows 88 for outside temp it will start on fresh where I left it, if I move it up to speed 3 it will kick over to recirc.
2008 4runner 2wd v6 with FJC springs/5100s set at 0.85, spidertrac 1.25",Pioneer AVIC-7100-NEX, windows tinted wincos 30%front/20%sides and rears, driver seat bracket modified to lower seat
05-27-2015, 07:43 PM
to be honest ive had my 'runner for 5 yrs and never noticed this..i just get in and set whatever settings i want
*it is interesting how far things have come to where these types of things that are aggravating to some.... its a testament to how good these vehicles are where these are the gripes people have with them
05-27-2015, 08:10 PM
Real Name: Chris
Real Name: Chris
Some people appear to see this type of thing as a hardship.
C'mon people - push the button and move on.
Chris - '07 SR5
‘05 Limited - sold
05-28-2015, 07:51 AM
It is simple, but annoying. In the winter you do NOT want recirculation because your windows will fog up. In the summer you want recirculation when the AC is on so it is more effective and efficient. I will watch mine more closely, but I don't think it exactly follows the guidelines as stated above.
05-28-2015, 09:20 AM
Real Name: photoshop god
It would be nice if it only did that when the AC was on. When you roll with the windows down it shouldn't be on recirc.
.: READ IT! :.
Pre-Purchase Info, Modifications, Write-Ups, Quick Links, and FAQ's
Tons of info on 4th gens for new and prospective buyers with links to the best topics.
05-28-2015, 09:33 AM
The problem is that (and Toyota has put out a TSB for this) is that when you use the A/C, you obviously get a lot of moisture build up in the Evaporator area. When the car is off and its set to recirculate, you don't have outside air flowing through the unit to help dry it out and minimize the smell. You tend to get a wet, mildew odor when you turn the system on. Sure it'll go away once you start driving or turn on the A/C, but you'd be surprised how many people come into the dealership and complain about it.
2005 4R V8 4x4 Limited - LEDs, FX-Rs, Gibson exhaust, TRD Red Front/Rear shocks, OME front springs, Toyotec rear springs, BF Goodrich 275/70/17 K02s, 1.25" Spidertrax. Front/Rear Polyurethane sway bar bushings, Total Chaos lower control arm alignment tabs. 150k miles and counting
2005 Prius - DD/Grocery getter. 250k miles and counting.
05-28-2015, 09:56 AM
I did notice the recir is always on now once the temps started getting hotter outside. This totally makes sense. I hate how I have to turn AC off after I hit "Auto" if I want to run in "economy mode" but at least we have option compared to other vehicles.
05-28-2015, 10:17 AM
In the humid south Louisiana climate I'm in I leave the A/C and the recirculate always on, even when I want heat. That way the cabin air stays dry. I would love to live in a climate that is dry enough not to have to do that. Oh well.
Current - 2017 TRD Off Road Premium Classic Silver Metallic
Totaled - 2002 4Runner SR5 Thunder Cloud Metallic (Gone but not forgotten)
Sold - 2007 4Runner Limited, Titanium Metallic, 2WD, V8
Sold - 2007 4Runner Limited, Galactic Gray Mica, 2WD, V8
Sold - 2005 Sequoia, Limited, Arctic Frost Pearl, 2WD, V8
05-28-2015, 10:41 AM
If it's anything like Lexus, the dealer can change that for you. My GS 430 used to do that until my service adviser plugged a computer into the car and unchecked a box on the personal settings screen. I would think our runners are the same. Lexus called those settings "c best" I believe. I don't get to drive my runner so I'm not sure if it's on every time or not.
05-28-2015, 12:53 PM
IIRC you can remedy this by turning off the "auto" feature. Then the HVAC should stay in whatever position it was when the vehicle was turned off.
Martin AKA Zapp Branigan - No longer a 4runner owner!
Thread Tools |
Display Modes |
Rate This Thread |
Linear Mode
