06-04-2015, 08:57 PM
Coolant flush
I'm about to go over 100k miles and need to change some of these fluids out. I've never done a coolant flush, so does anyone have a write up (w/ pics preferably) or a youtube video on how to do this? TIA
06-04-2015, 09:31 PM
https://www.youtube.com/watch?v=WOu_Si3gdbs
Planning on doing the same thing this weekend.
2017 TRD Offroad Premium: Fox 2.5" Coilovers, Total Chaos UCAs, 2" Icon rear lift springs, Fox 2.0" rear shocks, Nitto 285/70r17 Trail Grapplers, Xenon Depot Philips 4300k HIDs, Philips Yellow LED Fogs, full LED interior, puddle, and reverse lights, 20% tint on front and sides, 5% tint on rear and back hatch.
SOLD:2006 Sport 4wd
06-04-2015, 09:43 PM
Make sure you're using either Genuine Toyota SLLC (Super Long Life Coolant, aka "Toyota Pink") or one that is compatible (so far in my research only the Amsoil Coolant and Zerex Asian Formula match up to SLLC.)
06-04-2015, 09:49 PM
I had the dealer do it. After the cost of the Toyota fluid it wasn't much more to just have them do the service.
2009 Trail Edition
2006 Sport Edition - SOLD
06-04-2015, 10:14 PM
Real Name: Danny
Real Name: Danny
How much did that run you? I need to do it on my Tacoma (same engine) and the 4runner in another 12k. Debating on whether I want to do it myself, or just pay the extra and have them do it.
06-04-2015, 10:53 PM
06-05-2015, 08:06 AM
Another good thing about the V8. . . sort of. Never have to personally flush the coolant as when it is time to do it it is also time to change the timing belt. that job with a new water pump is an automatic coolant flush.
06-05-2015, 12:14 PM
Dealership quoted me $153. I think a jug of coolant runs around $25-$30 from Toyota.
06-05-2015, 02:47 PM
Real Name: Danny
Real Name: Danny
Originally Posted by unclebeansie
Good writeup and I know I can handle it, but personally for me, between the mess, the disposal, and the time involved for it, 150 at the stealership isn't too bad.
06-05-2015, 03:52 PM
Registered User
Registered User
trust me, it's very easy. all you have to do is buy the coolant from Toyota and open the drain from the driverside bottom of the radiator, get a vacuum cleaner that has a blowing capability, blow some air into the radiator cap to push the remaining liquids out thru the drain and refill with the SLLC from Toyota. you should be all set after that.
there's no need to flush but you can clean the white coolant tank.
06-05-2015, 04:11 PM
Real Name: Brian
Real Name: Brian
Its easy to do, it just takes time having to let the engine warm up to start circulation so everything mixes well and goes through the engine/heater core, then letting it cool of to drain. A piece of tubing on the radiator drain to direct flow into whatever container your using makes things a lot cleaner. I plan on switching to AMSOIL coolant when I flush mine again, I have a dealer account and would be happy to help out.
I did it by the book, draining the petcock at the bottom of the radiator as well as on each side of the block. It wasn't difficult other than getting to those side petcocks through the wheel wells. Do yourself a big favor and get a two or three foot ratchet extension. I went ghetto and put several one foot and six inchers together and that was tedious to mate up to the drain bolt.
2023 4Runner TRD Off Road Premium, Magnetic Gray Metallic
2021 Tacoma TRD Pro, Lunar Rock
2006 4Runner SR5 V6, Natural White
06-05-2015, 10:12 PM
For a flush its easier to pull the thermostat. To remove and flush fluid from the block. Empty radiator, reinstall thermostat (I always put a new one in), then put half the systems capacity of pure undiluted Toyota antifreeze in and top off with water. Run engine untill thermostat opens and add more water if needed. When done fill reservoir to high mark with 50/50.
06-06-2015, 11:07 PM
Originally Posted by radlynx
trust me, it's very easy. ... open the drain from the driverside bottom of the radiator....
Nothing every goes quite right for me. The plastic drain broke while I was turning it with my fingers to loosen it. It was not too hard to remove it in several pieces with tools after that.
Took a few days for the Toyota dealer to get me one on back order...
be extra careful with it
was: 2005 2wd V8 Limited, one owner (me), 155K miles
now: 2019 Kia Sorento SXL V6
06-06-2015, 11:47 PM
This is actually slightly misleading as Toyota SLLC only comes in pre-mixed 50/50 (and I believe 60/40 for climates such as Canada.) There is no need to dilute the coolant; additionally Toyota LLC (or Toyota Red) is a different, older spec of coolant and diluting it does not equal "Toyota Pink" coolant.
Other than that, the information is correct and a good way to do it.
On a side note, first service is at 10yr/100k, following services for coolant are 5yr/50k after the first fluid service.
