Originally Posted by Cdevs67
Whats up sqaud? So I know this subject is beaten to death but I need help with a rubbing issue I have on my '09 Sport. Put a 2" Bilstein 5100 lift on with Wildpeak 275/70R17's. The tires are rubbing my UCA's like crazy and I don't know what to do to make it stop. So far from what I've gathered, I need wheels with a 0 or negative offset. Right now I'm looking to pull the trigger on some Black Rhino Baker's that have a -12 offset. I can picture the tire sticking out and I think I like that aggressive look but also hope that the $1000 I spend on them will fix my rubbing problem. Any suggestions would be greatly appreciated.
-12 should be more than enough to fix the issue, plus it gives a great stance as you mentioned. I will say though that black rhino wheels are heavy as sh*t. If you care about your unsprung weight, then I would checkout other options.
Sent from my Pixel 5 using Tapatalk
