Old 09-01-2022, 08:53 PM #1
akhero akhero is offline
akhero is on a distinguished road
Rear differential fluid change took more oil.
So today i replaced my rear diff fluid in my 07 4Runner 4x4. I parked in my garage which is pretty flat drained the old fluid out which was very dirty.
I refilled it to the point where the oil just started to come out it took almost 4qt of oil.
I thought only takes 3+ qt
I turned the car around and put it back in the garage took the fill plug off but the oil slowly was coming out so the level was pretty good.
The old oil that came out I poured into a 1gal but it was less than a gal.
Wonder why it took more oil.
PS : I don't know if this has anything to do with it but my suspension on the 4runner will be replaced with new the front is 3" lower than the back
Could that cause the car to tilt forward and that is why the oil level changed?
akhero is offline   Reply With QuoteReply With Quote
Old 09-02-2022, 08:22 AM #2
rdruss's Avatar
rdruss rdruss is offline
Real Name: Ron
rdruss's Avatar
Real Name: Ron
3+ quarts is 4- quarts, less than a gallon is 3+ quarts. What's your concern?
2003 Limited, V8, AWD. 4600 Bils/FJ springs, 1/2" spacer, SPC UCA, Super Pro bushings in front LCA and in all rear control arms, Michelin 265/65R17 LTX/Defenders, stock wheels with homemade center caps, Stop Tech slotted rotors w/Posi Quiet pads all around.
Old 09-02-2022, 08:32 AM #3
aemravan aemravan is offline
aemravan has a reputation beyond repute aemravan has a reputation beyond repute aemravan has a reputation beyond repute aemravan has a reputation beyond repute aemravan has a reputation beyond repute aemravan has a reputation beyond repute aemravan has a reputation beyond repute aemravan has a reputation beyond repute aemravan has a reputation beyond repute aemravan has a reputation beyond repute aemravan has a reputation beyond repute
yea.. everything sounds pretty on-point.. don't see anything to be concerned over..
2003 Limited V8 4runner - 37's, Tacoma Front End swap, ARB locked front and rear , LC200 rack swap
aemravan is offline   Reply With QuoteReply With Quote
Old 09-06-2022, 11:57 AM #4
NCHornet NCHornet is offline
Real Name: Kevin
NCHornet is on a distinguished road
Real Name: Kevin
If it's sitting fairly level you have the correct amount of fluid in it. The fact that you drain less out than what you put in simply means it was low on diff oil. Whether that was from a past leak, prior maintenance not performed correctly or......................, doesn't matter much now. What is important is that it is at the right level now. I hope that you inspected the diff breather and replaced it if it was needed.
NCH
2007 Limited 4wd 140k
NCHornet is offline   Reply With QuoteReply With Quote
Old 09-06-2022, 12:02 PM #5
Reinout's Avatar
Reinout Reinout is offline
Real Name: Reinout
Reinout will become famous soon enough Reinout will become famous soon enough
Reinout's Avatar
Real Name: Reinout
I wouldn't lose sleep over the differences in fluids: it could have been over-filled to start (filled on a decline).
I'd only worry if I found a bunch of glitter in the oil.
1997 4Runner SR5- ~376k Miles and counting - 5 Speed E-Locker
2007 4Runner Limited V6- 165k Miles - Automatic - Brake Controller
2011 VW JSW TDI- 130k Miles - 6 Speed - Air Lift 1000
2006 Scamp trailer 16'
Reinout is offline   Reply With QuoteReply With Quote
back , car , fluid , level , oil
Differential fluid change toybox Maintenance/Detailing 166 08-02-2014 11:19 AM
Rear differential fluid change, now grinding sound ntrail 4th Gen T4Rs 3 01-12-2014 03:29 PM
Front/rear differential fluid, trans fluid and transfer case fluid change 88 Kel Varnsen Classic T4Rs 1 05-20-2012 03:26 AM
rear differential fluid change marcel 3rd gen T4Rs 21 11-23-2011 06:05 PM
Differential fluid change 007Runner 4th Gen T4Rs 18 02-15-2007 10:31 AM
