Old 06-19-2015, 11:58 AM #1
fdbyrne fdbyrne is offline
fdbyrne is on a distinguished road
Steering Wheel Vibration
I have an odd question.
Is there any way to dampen steering wheel vibrations? All kinds of vibrations get transmitted up through the steering column and into my hands. It's not just your typical engine, suspension, and wheel vibrations. There are times when a different car's exhaust hits just the right frequency and I can feel it in my steering wheel as it drives by.
Is there some sort of rubber bushing that might be shot or a bolt that may need to be tightened? My rack bushings seem to be in fine shape with very little deflection.
It's not a huge deal, it's just moderately annoying. The steering column itself seems to be acting like a large tuning fork.
2004 SR5 4x4 V6 - With New Head Gaskets
fdbyrne is offline   Reply With QuoteReply With Quote
Old 06-19-2015, 03:39 PM #2
Sungod Sungod is offline
Sungod is on a distinguished road
I think there was a Lexus TSB that addressed the issue. I know what you are talking about. It feels like you are holding on to a aluminum bat that someone keeps hitting repeatedly with a steel hammer.
Sungod is offline   Reply With QuoteReply With Quote
Old 06-19-2015, 03:48 PM #3
Yes. Pretty much. I'll do a search for that TSB.
Old 06-20-2015, 07:18 PM #4
earthrealm earthrealm is offline
earthrealm will become famous soon enough earthrealm will become famous soon enough
seen?
2005 v6, galactic grey 4wd auto : pioneer avh 4400bh dvd hu, pyle reverse cam
2003 rav4 titanuim silver 4wd auto......sold
2004 rav4 titanuim silver 4wd auto : pionneer avhx 5500bt hu, pyle reverse cam
earthrealm is offline   Reply With QuoteReply With Quote
Old 06-20-2015, 07:46 PM #5
Originally Posted by earthrealm View Post
seen?
What?
Old 06-21-2015, 09:47 AM #6
scw1991 scw1991 is offline
scw1991 is on a distinguished road
Front wheel alignment issue perhaps?
scw1991 is offline   Reply With QuoteReply With Quote
Old 06-21-2015, 10:50 AM #7
Thank you for the suggestion. The truck was just aligned so I don't think that's my problem.
I'm certain that it's something with my steering column. It's acting like a tuning fork and passing any vibration of a certain frequency right into my hands. Even music and exhaust sounds from other vehicles get picked up and directed right into my hands.
It's really strange. I need to crawl under there and see if much exhaust is touching anything. That might be possible.
Old 07-26-2015, 06:30 PM #8
4by4th's Avatar
4by4th 4by4th is offline
4by4th is on a distinguished road
4by4th's Avatar
I found this thread in a search for "steering wheel vibration" or "steering wheel shake" not sure what I actually typed now.
I went off road today, first time on rough gravel roads and 2 track dirt in quite a while. I felt like I could feel every large piece of gravel on the road through the steering wheel. I think I could even hear the steering column at times.
Last week had the front axles replaced due to bad boots, steering sway bar bushings replaced, ball joints inspected that they said looked good and asked if I'd had them replaced already since they looked so good, new brake pads and rotors, and front end alignment. Had the wheels balanced a couple weeks ago and everything's smooth on the road.
I think it's in the steering somewhere. I went through all the 4WD settings today, 4 high, 4 low, VSC off, Downhill assist on, everything seems to be working good as new except the steering wheel vibration./shake. Feels like something's loose in the steering column.
These things don't have a sideways mounted shock absorber type steering stabilizer do they? Every other 4x4 I've owned did, Nissan P/U, Cherokee, F150. While driving today, the 4Runner felt like it needed one. Can they be added?
My 4th 4x4: 2004 V6 4Runner 4x4 (dealer replaced engine at 70,000 miles 2006 - http://www.toyota-4runner.org/showth...ight=nightmare), Mich. Cross Terrains, Nitto T/G, now BFG AT KO's 265/70/17, Leather, Husky mats, Escort, iPhone (phone, GPS, iPod), USA Spec Bluetooth Interface, Fumoto Valve
Current daily driver: 2008 Honda Accord EX-L w/Navi
4by4th is offline   Reply With QuoteReply With Quote
Old 07-26-2015, 06:34 PM #9
LOBO79's Avatar
LOBO79 LOBO79 is offline
Real Name: Matt
LOBO79 is on a distinguished road
LOBO79's Avatar
Real Name: Matt
Did you check the hub bearings?
LOBO79 is offline   Reply With QuoteReply With Quote
Old 07-26-2015, 06:36 PM #10
LTDSC's Avatar
LTDSC LTDSC is offline
Real Name: Sam
LTDSC will become famous soon enough LTDSC will become famous soon enough
LTDSC's Avatar
Real Name: Sam
wheel balance/alignment/tie rod shape and condition/hub failure
Steering wheels dont just vibrate, they do it because something is right.
LTDSC is offline   Reply With QuoteReply With Quote
Old 07-26-2015, 07:51 PM #11
4by4th's Avatar
4by4th's Avatar
I took it in last week due to steering wheel shake while braking at highway speeds and hub bearings is one thing they mentioned checking before finding warped rotors. I will call them tomorrow to confirm and tell them what it was like today off road. I also think they looked over the entire front suspension, since they did find the sway bar bushings when I told them to look at the axle boots and ball joints and they found the sway bar bushings bad. I trust this shop as much as I can trust any place since they helped me through the whole "Worst Nightmare" experience when the dealer didn't put oil in during an oil change. That dealer actually refused to sell them parts after that ordeal.
Old 07-27-2015, 09:32 PM #12
4by4th's Avatar
4by4th's Avatar
I might have found the problem tonight with more web searching and a few times under the front end. Drivers side LCA bushing is starting to deteriorate, passenger side appears to be completely missing. Seems like that would make it feel loose in the steering wheel over bumps.
Old 07-27-2015, 10:11 PM #13
That's not an easy job (doable, just not easy). I'd make sure that's the problem first. Do you have a Go Pro? If they are flexing enough to cause your problem then you should be able to clearly see them flex in the video footage.
Old 07-27-2015, 10:15 PM #14
LTDSC's Avatar
Real Name: Sam
LTDSC's Avatar
Real Name: Sam
one side is open ended so make sure its just not that side you're viewing.
My LCA bushings would really pivot when i had the wheel cranked and someone was driving and backing up and tapping the brakes. You could see it move a lot.
I had them pressed out, new ones in and new lower arm BJs while it was out. The shop hated it and it was tough, but its done and rides like new. I used DayStar energy suspension bushings and Moog BJs.
Old 07-27-2015, 10:55 PM #15
4by4th's Avatar
4by4th's Avatar
Checked and double checked, thanks. Taking it back to the shop tomorrow to have them look at it.
steering wheel vibration from 40-60...sometimes Climber 3rd gen T4Rs 26 08-22-2020 10:17 PM
Steering Wheel Vibration NDZ 3rd gen T4Rs 11 08-21-2014 11:13 PM
Steering Wheel Vibration blkrnnr Engines / Suspension / Wheels / Tires / Audio / Accessories 8 10-02-2008 08:23 PM
Steering Wheel Vibration mtngoat 4th Gen T4Rs 3 08-29-2007 01:06 AM
Vibration in steering wheel danieladrian 3rd gen T4Rs 1 08-26-2007 12:59 PM
