07-09-2015, 03:29 PM
Real Name: Jonathan
Real Name: Jonathan
Hard Pull to the right under braking
So I've noticed for a while that my runner kinda pulls to the right a tad when getting on the brakes really hard but I never slam the brakes so I wasn't too worried about it, well recently I was driving down the intestate at about 70 and noticed the cars in front of me were at a complete standstill, so I had to slam on the brakes. I thought the thing was gonna flip, it turned hard to the right and it took everything I had to stay in my lane and get stopped at the same time. So is this the signs of the infamous frozen caliper? I have the small brakes ( had factory 16 inch wheels) and the left caliper is rusted but it's always worked fine so I've never really bothered fixing it. But if it's pulling to thee right that would mean that the left caliper isn't working, correct? I don't know I'm no expert on brakes just need some opinions..I need to get this fixed probably
08 V6 SR5 4WD Nautical Blue Metallic
My Build- http://www.toyota-4runner.org/4th-ge...ld-thread.html
07-09-2015, 03:40 PM
It's almost certainly a caliper. I'd just go ahead and replace both front calipers, pads, and rotors. None of them are expensive or hard to do by yourself.
2004 SR5 4x4 V6 - With New Head Gaskets
07-09-2015, 04:03 PM
Real Name: Ethan
Real Name: Ethan
almost 100% caliper. take off the wheels and check the front rotors and pads and compare them, you should see some abnormal wear and potentially scoring/gouging on the right rotor
A lot of stuff I didn't need...
My Build
Originally Posted by kfitz77555
oh my god the erection I have from this thread is unreal.
07-09-2015, 06:17 PM
Location: Stockbridge GA. ( formerly Kent WA. ) & ( formerly Grafton MA. )
Brake job !!!!!!!
Takes about 4 to 6 hours to do at the most.
2003 SR5 V6 4WD Stock (totaled)
2005 Sport Edition SR5 V6 4WD
07-09-2015, 11:54 PM
Real Name: Jonathan
Real Name: Jonathan
Originally Posted by BOSMECH
Brake job !!!!!!!
Thanks guys I figured that's what it was but its always good to get a second opinion.
Next question, should I go with 4th gen calipers again or upgrade to the 5th gen ones? I plan on doing calipers, rotors, pads, and then while I'm at in throw in some stainless brake lines just for the heck of it.
07-10-2015, 02:45 AM
If you are replacing everything its almost dumb not to do the 5th gen upgrade. As long as you have the 17 inch or bigger wheels.
2004 SR5 4.7L 4x4, Toytec Ultimate Lift Kit, Total Chaos Upper Control Arms, Spidertrax Wheel Spacers, 265/70R17 Nitto Terra Grappler, Full RCI Skid Plates with fuel tank skid. Limited Front Brake Upgrade. Gibson Cat-Back Exhaust, DT Moto Black Headlights.
To be installed: Doug Thorley headers.
Daily driver and weekend trail blazer.
07-10-2015, 03:16 AM
07-10-2015, 09:17 AM
Registered User
Registered User
it's not worth upgrading it in my opinion. the existing brakes in itself is really good. also the effort of cutting your shield is not worth it.
07-10-2015, 09:33 AM
I agree. If it were me, I'd go with NAPA remanufactured calipers with a good warranty. If they seize again, just swap them out for free.
Change out the brake fluid while you're at it. Old brake fluid contributes to the seizing problem.
07-10-2015, 11:09 AM
As others have said, it is most likely a stuck caliper.
Since you are replacing calipers, pads, and rotors, I would go ahead an upsize to either the larger 4th gen or 5th gen brakes. Yes, you have to bend or cut the dust shield. But the bigger brakes will give you a bit better braking for little, if any, additional cost.
If brute force doesn't work, you're not using enough of it.
Current: 2013 Land Cruiser
Gone: 2003 4Runner V8 Limited 4WD
07-10-2015, 12:26 PM
Why are people saying its not worth it? It would cost you $10 more for the 5th Gen calipers, and the rotors are the same price. So for $10 (and bending the dust shield) you have bigger brakes (always a plus when you need them) and so far (as far as I know) there aren't any issues with the 5th gen calipers. To me that worth the extra $10 it would cost. Those prices were looking at rockauto.
07-10-2015, 12:43 PM
There's certainly no harm in doing it, but the benefits may not be what you think they are. Better braking is great and worth it. I (and many other people) aren't convinced that the seizing caliper problem was solved for the 5th gen trucks. It's too early to tell.
I already had the larger 4th gen brakes and chose to stay with 4th gen brakes. The first set lasted a decade and 125k miles.
07-10-2015, 04:33 PM
I have the smaller 4th gen brakes and have gone through at least 3 sets of calipers.
07-10-2015, 05:25 PM
You could also just un-stick and rebuild your current caliper. Thats what I did, cost about 4 dollars per side. Although I have the larger gen 4 ones.
07-10-2015, 05:35 PM
Which, if you have the time, tools, location, and required skill is a pretty good idea. I, on the other hand, don't have the time, tools, location, or required skill. And working out in my driveway in January when it is 0 degrees out, kneeling in the snow, is not my idea of a good time.
