Old 07-22-2015, 12:34 PM #1
nasdamus's Avatar
nasdamus nasdamus is offline
nasdamus is on a distinguished road
nasdamus's Avatar
P0171 - System Too Lean (Bank 1)
Looking for some thoughts. 2003 V6. Keep getting a P0171 code. I pulled the MAF and cleaned it, same with the TB. Came back on after 10 miles. I checked all the vacuum hoses, all seems fine. I replaced the MAF with a known working extra i had, came back after 15 miles. Replaced the air filter (had to anyways), ran some Techron Fuel System Cleaner through a full tank of Shell gasoline. Took a little while to come back on but eventually did (maybe 45 miles).
5,000 miles ago I did replace all spark plugs as well as the PCV valve.
2.5 years ago (20,000 miles ago) i replaced the B1S1 o2 sensor (was getting a P2238 code) with a Denso 234-9047.
Any thoughts on what i should try next? Been searching around and checked most suggestions. I'm currently getting a real rough idle at stop, not stalling out but close.
2003 Black V6 4WD SR5
nasdamus is offline   Reply With QuoteReply With Quote
Old 07-22-2015, 12:45 PM #2
paperchasin paperchasin is offline
paperchasin is on a distinguished road
Need more information, but I'm leaning towards a fuel system problem. Are you able to get fuel trim (both short and long term) info? Preferably for both idle and 2500RPM conditions.
07 V6 Limited 4WD; FJ Springs + Bilstein 5100's
16 Lexus GX460
paperchasin is offline   Reply With QuoteReply With Quote
Old 07-22-2015, 01:32 PM #3
fullboogie fullboogie is offline
Real Name: David
fullboogie is on a distinguished road
Real Name: David
Bad O2 sensor - change it.
fullboogie is offline   Reply With QuoteReply With Quote
Old 03-29-2016, 07:03 AM #4
Hyfyer1 Hyfyer1 is offline
Hyfyer1 is on a distinguished road
I have the same 4Runner, and I'm currently getting P0171 & P0174....checked Vacuum hoses for leaks...all good. All O2 sensor were replaced 3000 miles ago, MAF & TB are fine....The vehicle intermediately bogged on upon acceleration.....Saw A video on this saying it could possibly be a clogged cat, putting excessive exhaust pressure on the engine. So I pulled my cats and noticed one was clogged, I cleaned it and now it got worse. The vehicle just has no pick up when pressing the gas. (Yes I replaced the Fuel Pump a few months ago) I'm going to drill out my cat to see if it remedy's the situation...I'll let you know.
Hyfyer1 is offline   Reply With QuoteReply With Quote
Old 04-28-2016, 10:08 AM #5
celicaben celicaben is offline
Real Name: Ben Bromberg
celicaben is on a distinguished road
Angry
i'm having the same issues along with a misfire on cylinders 2-6, also getting "system too lean", and engine sounds like it's running on half the cylinders and bucks when starting out from a stop. i've replaced:
1. plugs
2. wires
3. coil packs and boots
4. pcv valve and gasket
5. mass air flow sensor
6. air filter (k&n cold air intake already installed, engine ran flawless on this for 10 years now)
7. put injector cleaner via fuel tank 4 times now each on a full tank of reliable gas.
8. o2 sensors (both done 10 k miles ago no issues yet there or codes)
what should i do next? i'm thinking its in the throttle body sensor and the idle air control unit. am i right or is it the injectors at this point? PLEASE HELP I NEED TO GET THIS FIXED ASAP
01 sr5 4runner auto, AEM cold air intake, flowmaster exhaust, viking 3gal air tank with compressor, much more to come.....
celicaben is offline   Reply With QuoteReply With Quote
Old 04-02-2017, 10:51 AM #6
pjku79 pjku79 is offline
pjku79 is on a distinguished road
Anyone resolve this? I'm having the same problem on a v8. Figure it might carry over.
pjku79 is offline   Reply With QuoteReply With Quote
Old 10-16-2018, 01:45 AM #7
djpope09 djpope09 is offline
djpope09 will become famous soon enough
1. plugs
2. wires
Did you ever solve this? I'm getting the fault and misfire on cylinder 1. I don't want to start throwing parts at it if I can help it.
djpope09 is offline   Reply With QuoteReply With Quote
Old 10-16-2018, 07:44 AM #8
UrbanRunner651's Avatar
UrbanRunner651 UrbanRunner651 is offline
Real Name: Newell
UrbanRunner651 will become famous soon enough
Real Name: Newell
Was getting the code off and on for a couple months. Tracked it down to a crack in the header manifold. Replaced both sides with some JBA shorties and haven't had a problem since.
UrbanRunner651 is offline   Reply With QuoteReply With Quote
Old 10-22-2018, 07:27 PM #9
How did you find the leak in the manifold? Was it pretty obvious?
Could you provide a link for the headers you bought?
Old 10-23-2018, 08:23 AM #10
Real Name: Newell
Real Name: Newell
Originally Posted by djpope09 View Post
link?
On sale at URD, probably cheaper elsewhere or if you wait until black friday. Different coating options available.
https://www.urdusa.com/jba-headers-2...ilver-ceramic/
I could hear a ticking/exhaust sound that wasn't normal inside the bay and eventually the crack grew large enough I could see it just from looking. It was a shitty weld on an aftermarket header for me but the codes are a pretty good indicator of a leak. You can use a cheap stethoscope without the end on it to listen to areas of the manifold and identify the leak. Or just bring it in to a shop for a quote and they'll find it for you.
Old 10-23-2018, 08:47 AM #11
Jan777 Jan777 is offline
Jan777 is on a distinguished road
to summarize, the causes can be:
1. cracked header manifold
2. defect O2 sensor
Anything I miss?
I have the same symptoms and guess its the manifold, but before starting works I collect all the possible causes!
Jan777 is offline   Reply With QuoteReply With Quote
Old 10-24-2018, 12:03 PM #12
2. defect O2 sensor
Anything I miss?
I don't want to muddy the waters, but I'll add that I got this code after having a misfire on cylinder 1. It was misfiring bad enough to cause the too lean code. If you don't have a misfire I think your list is correct.
Old 05-02-2019, 03:49 PM #13
earthrealm earthrealm is offline
earthrealm will become famous soon enough earthrealm will become famous soon enough
hmmm, lemme examine my manifold, as mine is only bank 2 , p0174
2005 v6, galactic grey 4wd auto : pioneer avh 4400bh dvd hu, pyle reverse cam
2003 rav4 titanuim silver 4wd auto......sold
2004 rav4 titanuim silver 4wd auto : pionneer avhx 5500bt hu, pyle reverse cam
earthrealm is offline   Reply With QuoteReply With Quote
Old 05-03-2019, 11:49 AM #14
81runner's Avatar
81runner 81runner is offline
Real Name: Elliott
81runner has a spectacular aura about 81runner has a spectacular aura about
81runner's Avatar
Real Name: Elliott
A lean bank on only one side can be down stream sensors, or it could be fouling injectors.
2007 SR5 V6 4WD 205k, Titanium Metallic. 5100s, OME 885/895, extended rear links, ST Maxx 255/75 R17 on 17x8s, mud flap delete,TB spacer, Spectre CAI, DRL delete, HCF delete, DAC delete, K&N cabin filter, TPMS bypass, Fog light mod, USB galore, dash cam, LED lights all over, rear bumper lights, cbi ditch light brackets w/lights, atrac off, OBA w/2 gallon tank/hidden hook up, Trailgear welded sliders, Rocksteady skids, custom swing-out, 3⁰, SE hood w/working vent, Sprint booster, JET MAF, Kenwood TM-V71a w/motorized antenna, custom dual battery, custom roof rack/lights, custom TRED mount, external 12v, rear diff breather, pck, Freedom UCAs, custom stereo, Aluminum rad, trans cooler, 240A alternator...for now...
81runner is offline   Reply With QuoteReply With Quote
Old 05-03-2019, 02:46 PM #15
I THINK A CRACK IN THE MANIFOLD of that bank could also throw the CEL. lemme look at my oxygen sensor readings again , last time i checked, they looked fairly normal/within range
P0171 Lean bank 1 Question jhueter 3rd gen T4Rs 43 08-21-2023 09:48 PM
How to Fix P0171 System to Lean Code speedgoat 3rd gen T4Rs 13 04-10-2022 04:33 PM
P0171 Code - Lean Bank 1... Help? jpontius 3rd gen T4Rs 5 02-23-2013 11:00 AM
Check engine:P0171 system lean jmnral 3rd gen T4Rs 4 03-06-2011 10:33 PM
P0171 (B1 System Too Lean) Rescue84 Problems & Warranty Issues 2 09-27-2006 03:47 PM
