Originally Posted by CookieRoe
Would be nice to have a defeat button.
I think the gas pedal defeats it.
There's no tow/haul mode on the transmission because apparently it can sense the additional load. When you tow it should downshift like this more readily than if you are not towing, but I haven't tried it.
The 8th gen civic was great, but it worked even better (most of the time) if you used cruise control. You had to set the cruise 5-10mph below your target speed, but then once you reached that speed it would shift between 5, 4, and 3 as needed to maintain a constant speed down hills with non-constant grades. Except that sometimes it wouldn't do it and just kept accelerating. It's too bad it didn't have a shifter with direct access to 4th like we have.
Honda calls it Grade Logic, and Toyota calls it "with intelligence" (ECT-i).
