Old 11-20-2017, 03:07 AM #31
JB.'s Avatar
JB. JB. is offline
JB. will become famous soon enough
JB. JB. is offline
JB.'s Avatar
Originally Posted by PrivateParts View Post
Thanks for confirming what I thought it should be, BUT I screwed up and didn't paste the air pressure for either. The SL has an inflation pressure of 51. The LT C version has an inflation pressure of 50. I checked two sites to confirm. What am I missing?
SpecificationsGOODYEARWRANGLER DURATRACSize: 265/70R17Service Description:115S Load Range: SLUTQG: 500 B BMax Load: 2679 lbs.Max Inflation Pressure:51 psiTread Depth:16/32"Tire Weight: 44 lbs.Rim Width Range:7-9"Measured Rim Width:
To quote from the LT tires thread: "The horizontal lines on the P-metric tires (referencing the chart) represent the ability to add pressure for special conditions (like high speed) but the extra psi assigns no additional load capacity."
In other words, the load capacity of the SL tire at 51psi is the same as it is at 36psi.
2005 Limited V8
Bilstein 5100 at .85
5th gen SR5 springs
BFG AT KO2 LT265/70/17 Load C (Replaced Revo 2 LT265/70/17 Load E)
Hanna sliders
JB. is offline   Reply With QuoteReply With Quote
Old 11-20-2017, 09:28 AM #32
kcdehart's Avatar
kcdehart kcdehart is offline
Real Name: Kevin
kcdehart is a jewel in the rough kcdehart is a jewel in the rough kcdehart is a jewel in the rough kcdehart is a jewel in the rough
kcdehart's Avatar
Real Name: Kevin
I don't run Duratracs, but to chime in about load ratings...
I went offroading with a friend of mine who has a Forester with C load rated General Grabber AT2s. I was running E rated Grabber AT2s.
While treating our vehicles similarly over some rather jagged rocks, he popped a tire. I didn't. I run the LTs for puncture protection, rather than for towing or something like that. It's good peace of mine knowing that, I'm probably not ever going to puncture a tire offroad because I'm running tires rated for more abuse than my truck is capable of giving. And if by some chance I do puncture one, my spare is an E rated General Grabber, as well.
'04 4Runner - Build Thread | '05 CBR 600RR & 1000RR - The slow vehicles ;)
kcdehart is offline   Reply With QuoteReply With Quote
Old 11-20-2017, 12:07 PM #33
PrivateParts PrivateParts is offline
PrivateParts is on a distinguished road
Thanks JB! Appreciate you taking time to explain it to me. I thought thee was a chance that it was just marketing, and the two tires were the same. Wrong.
2018 ORP Super White - Trooper in training -
Lamin-X | B&W dip | sliders coming...
PrivateParts is offline   Reply With QuoteReply With Quote
Old 08-05-2019, 01:30 AM #34
MAST4R's Avatar
MAST4R MAST4R is offline
MAST4R's Avatar
No.
Max pressure for the LT is 50psi.
For the Standard Load (which in this case is a metric size -- a very close equivalent of P-metric) its 36psi.
Same size LT tires (in the case of 265/70/17) require an additional about 12psi to match the load capacity of a Standard Load tire. That is why the two tires have similar load capacities at significantly different air pressures.
The thicker, stronger construction of an LT is to accommodate additional air pressure which is what is required to increase load capacity, but the thicker construction, by itself -- with no pressure adjustment, actually decreases load capacity (creates more heat, more prone to long term cracking) leaving the LT tire needing extra air to achieve parity with the SL tire.
LT tires need more presssure
This is old, but for the record, it is wrong. Many SL tires in 4R sizes have maximum pressure of 51 psi and the remaining ones are 44 and not 36. Load ratings between P and C are often identical after adjusting for LT application (which is a discussion in itself, since the 4R is not a pickup).
I have not seen one ounce of evidence that a C tire is necessarily stronger for offroading than a B tire. Of course, if the tire does have a 3-ply sidewall (like many LTCs in 255 75 17) then the C will be stronger.
It is the common perception that E-load tires have stronger sidewalls for offroading because they have stronger construction so as to hold 80 psi and thus higher loads.
But in practice, unless the E load has a 3-ply sidewall, the advantage is likely way smaller offroad than it is when hauling, which is the design parameter.
I could definitely use a tough tire offroad yet I am running SL which is better at everything other than sidewall strength. The trick is to run the SL at or near street pressures. By contrast, the E must be aired down both for traction (terrain compliance) and comfort. On road the only possible advantage of D or E is added cornering stability at proper pressures. The rest is a laundry list of shortcomings.
(6112s/650lb at 2.25" lift, 8100 rear with Bilstein B12 1.5" springs, Mickey Thompson ATZ P3 LTE 265 70 17, RCI set of front 3/16 skids, Shrockworks step sliders and 3/16 steel gas tank skid, C4Fab rear diff skid, Rockmen rear LCAs, Total Chaos rear LCA bracket skids, Diode Dynamics SS3 white fog lights).
Old 08-05-2019, 08:23 AM #35
kcdehart's Avatar
Real Name: Kevin
kcdehart's Avatar
Real Name: Kevin
On Grabbers, at least, the sidewalls are rated at 10-ply. I believe it's a '3-ply rated at 10-ply' (not sure how that's actually measured) but like I said, it's capable of handling more abuse than I can throw at them with something the weight of the 4Runner. The hit in gas mileage was 1 mpg. Oh well. I didn't buy this thing for gas mileage.
I would much rather run an aired down (or even aired up, I've offroaded mine at 40psi and they're bumpy but still grip fine for light offroad) E-load and not worry about sidewall punctures than run an SL and not have to worry about airing down.
Also, that sidewall stability on-road is amazing. I've been in trucks with C-load Grabbers and they handle like complete garbage compared to mine with the E's. It's night and day. Otherwise though, I didn't buy them to be good on-road. I bought them to be good offroad. If your truck sees 90% pavement, yeah, there's 0 reason to get E-load tires. Otherwise, I see no reason not to.
Old 04-08-2021, 11:52 AM #36
Ripper238's Avatar
Ripper238's Avatar
Bumping this thread in hopes of some insight.
Trying to decide between tires, and found something funny that doesn't make sense. WTH is going on?
SL load rated Duratrac:
C load rated Duratrac:
WRANGLER DURATRACSize: LT265/70R17Service Description:112/109Q Load Range: CUTQG: NoneMax Load: 2470 lbs.Max Inflation Pressure:
So the SL's have a higher load rating and the higher inflation pressure. This shouldn't be the case. If you reduce the SL rates tires load by 9% (I've heard you do this) they are almost identical.
Does this mean the SL rated Duratracs have thicker sidewalls?
Such a good question. I just purchased LT265/70R17 C load Duratracs and was puzzled by the same question. I also started to worry they were not rated enough for my 4R.
No.
Fantastic info! The 112/109Q rating made no sense. So if i need the full weight capacity on my C's i can just add a little more (closer to 50) PSI and i am good to go. I'm running 35psi for now.
The C rated Duratracs ar 10 ply too.
Sorry to bump old thread but good info!
Old 04-09-2021, 10:34 AM #37
Ripper238's Avatar
Ripper238's Avatar
@JB.
Max PSI is 50 and max weight capacity is attained at that PSI. Wouldn't it be pushing the tire at 50 PSI?
Going to bring my PSI to 40 today.
I have a 5 Gen BTW.
Old 05-15-2021, 06:50 PM #38
Cory15000 Cory15000 is offline
Cory15000 is on a distinguished road
Alright let’s beat this dead horse!
Anyone running or know if TRD pro wheels with 255/80/17 Cooper ST Maxx will cause any rubbing? Currently running 5100's all around with the fronts set at 0.85".
Cory15000 is offline   Reply With QuoteReply With Quote
FS Duratrac 265/70/17 tires - $250 - Austin, TX seymore For Sale: Suspension/Wheels/Tires 3 04-06-2014 06:22 PM
DuraTrac tires NorthWestManiac 3rd gen T4Rs 28 10-21-2012 12:38 AM
Lets see 285 Tires on your trucks. Victor Off-Roading 14 01-25-2010 11:05 PM
Mud,Tires,Trucks, And Traction? Camprunner 4th Gen T4Rs 0 04-24-2007 11:45 AM
