07-30-2015, 01:57 AM
Instrument Cluster - Center cluster out
Hello all,
On the instrument cluster, the center cluster back lights are out What would cause all the lights to burn out? Are they LEDs or bulbs? I would assume that there should be many led/bulbs on the PCB and maybe one, but not all go bad?
Any info would help.
Thanks!
2006 4Runner SR5 4x4 V6 Shadow Mica => Mrs
2006 4Runner SR5 4x4 V6 Titanium Metallic => Mr
2012 Sequoia SR5 RWD 5.7L Magnetic Gray Metallic => "I get to drive it! (says hubby) No! I get to drive it! (says wife) Happy Wife - Happy Life
07-30-2015, 02:50 AM
Check the dimmer switch next to the cluster and turn it up?
Pioneer DEH-80PRS,Rockford Fosgate T600-2,Hertz ML 1650.3(2 pairs),T400-2,Hertz ML 280.3(2 pairs),T1000-1bdcp,(2)JL Audio 12W6v3, Mechman 240a HO Alternator, Dual Northstar 31m,Borla Dual Exhaust,AFE Magnumforce intake.Enkei WT-4 Michelin Defender LTX 275/55R20. retrofitted S2000 projectors,Philips 85122 White Vision,Morimoto 5Five Ballast.Diode Dynamics SS3 Yellow Fog Sport.2 pairs of Hella Supertones.Full led conversion on interior and exterior.HAWK Talon Rotors and LTS pads F+R,Stoptech stainless steel lines F+R.Bilstein 5100 @0.85, MOOG FJ Springs front,Bilstein B12 36-281824 rear .
07-30-2015, 03:00 AM
Yep tried that, it works on left/right clusters....not center
07-30-2015, 03:38 AM
Led is burnt out, ask yosh2000 to do led color conversion of your choice.
07-30-2015, 10:13 AM
they are in series, so if one goes, they all go! they are SMD LEDs, 1210 or PLCC-2 to be exact. see my sig for a link to purchase new ones if you are going to replace them. they are soldered to the PC board, FYI. Let me know if you need any help.
05 4runner SR5 4x4 v8 : Build thread - Hailed totaled
17 Tundra SR5 crewmax 4x4 v8
07-30-2015, 03:20 PM
Sweet! Thanks for the link and info!
Is this still accurate?
for ease of reference and ordering, here is the required amount of LEDs for each aspect of the cluster:
- Background = 11
- Needles = 7
- Turn Signals = 2 per side
- Additional indicators (ie CEL, Batt, Cruise etc..) = 1 per light
Obviously id buy much more than the minimums.
Just to verify...when you say 1210 or PLCC-2, 1210 is the LED size and the PLCC-2 is the surface mount foot print?
07-30-2015, 03:56 PM
the LEDs are known as 1210 and also as PLCC-2. just giving you info.
the rundown is not accurate for the 4runners!! those qtys are good only for the tacomas (where i came from!). the qty for the 4runners very depending on your year and model.
i am still building my reference, but it appears your 06 SR5 uses the following:
- Background and needles (same LEDs light both) = 12
- Turn Signals = 2
07-30-2015, 04:29 PM
Thanks yosh2000! much appreciated for the info
07-30-2015, 05:06 PM
@ yosh2000
, i should let you hook my steering wheel controls up, just refer you a potential customer
Thread Tools |
Display Modes |
Rate This Thread |
Linear Mode
