08-04-2015, 09:22 AM
Strut Replacement
Good morning. I've searched around a bit for what I'm looking for on various boards but can't find exactly what I'm looking for. Hoping someone here with a little more strut replacement experience than me can help out.
I replaced the OEM struts on my 2008 4Runner with a pair Bilstein 4600's and something isn't quite right. The driver's side went on pretty easy but the passenger side was a bit of a pain. Everything is assembled, and the wheels are back on...BUT...the passenger side seems to be about 2 inches taller than the driver's side.
I realize these are SUPPOSED to put about an inch lift per side but I'm wondering why the passenger side is riding higher, at a list. Could I have mis-seated the spring and the compression is misbalanced?
Dave
08-04-2015, 09:26 AM
Real Name: Jeremy
Real Name: Jeremy
Can you post some pics? Might be easier to trouble shoot.
Previous: 2013 and 2007 JKU/JK....1970 FJ40 w/ Cummins 4bt.
Current:
'03 Titanium Metallic (Need to sell) SR5 4X4 V8 4Runner; DO bumper. King 2.5 Adjustable C/Os. JBA UCAs. MetalTech LT rear setup. MetalTech OPOR sliders. BFG KM2 35/70/17. Prinsuroof rack. Smitybilt X20 winch. OrangeBoxxFab PSD.
'12 Limited 4Runner; OME 3 in. lift. JBA UCAs. BFG KM2 285/70/17. Some other stuff...
08-04-2015, 09:50 AM
The springs are different sizes, the drivers side is a little taller than the passenger. I bet you have them reversed.
08-04-2015, 09:56 AM
Here's a few pictures. I'm not exactly sure which angle would be best to capture what you might be looking for.
08-04-2015, 09:57 AM
I removed/replaced one at a time so the springs were replaced to the side removed.
08-04-2015, 10:05 AM
In the pic of the strut and coil, I'm not for sure , but it looks like the coil bucket is upside down.. Someone else chime in but I think that's what I'm looking at..
04 4runner Sport Edition V8 4WD // X-REAS removed // Bilstein 5100s // Fj Cruiser coils // Interior LEDs // gshadow325 12V charger mod // Undercarriage LEDs // Back-up lighting // onboard 12v air compressor // 255/75/17 Duratracs // Homemade load bars // Smittybilt roof rack(when needed)
2016 T4R Trail Edition
2017 Civic Si
08-04-2015, 10:08 AM
Real Name: Rob
Real Name: Rob
how far have you driven it since you replaced them?
2006 4Runner SR5 V6 Galactic Grey
Bilstein 5100's with Moog V8 springs all around * BF Goodrich All-Terrain T/A KO2 285/70-17 * 1.5" Hubcentric Wheel Spacers Front and Back * WeatherTech Mats and Cargo Liner * Pioneer AVH-X3600BHS with JVC CSV Series Speakers All Around * Satoshi Grille * LED Interior Lighting * Lots of PlastiDip * RCI Front Skid Plate * Custom Front Bumper by HotMetalFabs * Silver Suicide UCA's * Next up - Custom Rock Sliders * Roof Rack!
08-04-2015, 10:13 AM
I've probably put 100 miles or so on it since I replaced them, so I figured the suspension would have settled by now.
Does the coil tension increase/decrease with rotation...should I try to rotate/reseat the spring?
08-04-2015, 11:08 AM
Real Name: Gary
Real Name: Gary
Compare the area in red on both sides? Not sure how 4600s go together, but 5100s have a spring perch there that is removable, and many people have put them on wrong?
I like my droop droopy
Front: Swayaway 2.5s + TC UCAs--Rear: Swayaway 2.5s + Icon 3.0 springs + Light Racing Jounce Shocks — 285/70R17 BFG KO2s
My build: http://www.toyota-4runner.org/4th-ge...ld-thread.html
08-04-2015, 11:14 AM
Real Name: John
Real Name: John
28. and gfluff are correct, if the side you are higher on is the one in your picture, see the other 2 I have attached.
2004 V6 2wd Sport - BFG Mud T/A KM 255/75/17, Bilstein 5100’s: front FJ coils, 4" lift spindles set @ .85, rear Metal Tech LT MD coils, SS brake lines, Uniball UCAs, Spidertrax; K&N air filter w/ HCF delete, WeatherTech Liners, dual batteries w/ isolator, inverter w/ 110v outlets, on-board air, satellite radio, custom grill emblem and roof rack; Mods: auto headlights, aux remote reverse LED pods and GY6.35 50w reverse bulbs, rear camera, interior LEDs, VSC, 12v w/ added outlets and windows always on, DRL on/off w/ always on mode, fog/map light, key reminder, TPMS bypass, front wheel liner relocate; de-badged, mud flaps, running boards, resonator, Xreas, front/rear sway bar removed
08-04-2015, 11:43 AM
I remember the spring perch. The spring plate slid down and sat on top of it...wasn't able to go any further.
The only difference I can tell between the two sides is where the bottom of the coil terminates. On the lower side, I can see the end of the coil...as seen in your photo. The end of the coil on the higher side is facing inward, towards the engine. That's why I was wondering if the spring compressed at a different tension at different rotations.
08-04-2015, 11:46 AM
After looking at your pictures again, you might just be right. The strut sleeve might be on upside down.
08-04-2015, 11:59 AM
Real Name: John
Real Name: John
See Pic:
08-04-2015, 02:09 PM
That was it! I looked at the driver's side and it's done 'correctly'. I'll sort this out tonight!
Thanks for the input...I really appreciate the help!
08-04-2015, 02:11 PM
Real Name: Gary
Real Name: Gary
How about this: if the lowest coil can touch yellow shock body, that perch is upside down. The perch also helps center the coil and keeps it off the shock body.
Edit: just saw your last post, looks like that was it...
