Thread Tools Rating: Thread Rating: 6 votes, 5.00 average. Display Modes
Old 11-07-2015, 07:25 PM #46
Krayziekid's Avatar
Krayziekid Krayziekid is offline
Real Name: Jake
Krayziekid will become famous soon enough
Krayziekid's Avatar
Real Name: Jake
Originally Posted by Az4runnin View Post
Any Updates Looks really Nice.
Nope. No major updates. The lights and wiring has been working fine. I ended up taking out the bottom (03) DRL bulbs and putting the top (06) DRL bulbs in cause I thought it looked nicer. The bottom ones don't do anything anymore.
Other than that, I am really happy with everything about them. The wiring has stayed strong, the bulbs are still pretty sweet, and I went through some serious muddle puddles and I didn't have a single problem with seals or anything. Now I'm itching to do other mods like this too! Roof rack with even more lights maybe?
"Po" - '18 Super White TRDORP - Build Thread Here
"Sirius Black" - '03 Limited V8 Build (Sold) - Build Thread Here l 03->06 Headlight Swap Guide
My Photography // My Videography
Krayziekid is offline   Reply With QuoteReply With Quote
Old 11-07-2015, 09:17 PM #47
Az4runnin's Avatar
Az4runnin Az4runnin is offline
Az4runnin will become famous soon enough Az4runnin will become famous soon enough
Az4runnin's Avatar
Ya I am Going to get a aftermarket Front Bumper so The Bottom DRL's aren't to Important. Headlights have to Be a Nice Upgrade.
2003 V8 Limited 4x4 Black. JBA UCA's, TRD Pro Wheels. OEM LED Tails, 2012 FJ Springs F/R 5100's F/R 1.75 Cooper AT3 4S 265-70-17. Bye X Reas, Wet Okole Seat Covers Weathertech liners.
Az4runnin is offline   Reply With QuoteReply With Quote
Old 11-07-2015, 10:53 PM #48
Krayziekid's Avatar
Real Name: Jake
Krayziekid's Avatar
Real Name: Jake
Yea I eventually want a front bumper too. The headlights were a huge upgrade. Not only are they better than the older 03 housings, but they are also wayyyyy shinier and cleaner which offers even more light output.
Old 12-01-2015, 06:25 PM #49
Wishbone Wishbone is offline
Wishbone is on a distinguished road
So I just ordered 06 headlights, and have no turns in my bumper currently, (LEDs tapped and taped on) and have never had DRLs. If I get the DRL/flasher relay, and then wire as you have with the exception of tapping into the bumper mounted DRL/turn, I should have full functionality?
Wishbone is offline   Reply With QuoteReply With Quote
Old 12-01-2015, 08:02 PM #50
Krayziekid's Avatar
Real Name: Jake
Krayziekid's Avatar
Real Name: Jake
I'm confused by the question. What year is your current 4Runner? Are you doing the full 06+ swap (as in as you getting rid of the old reflector assemblies for the new projector ones?)
I am confused as to what you mean by you have no turns in your bumper currently. Are you saying you don't have any turn signals at all?...
Old 12-01-2015, 08:16 PM #51
Correct, reflectors out, projectors in, 04. As mentioned above, I have LED strips taped on, steel bumper, getting rid of the LEDs and the turns into the headlights is one of the main goals of the swap as well.
Here is what I am working with.
Old 12-01-2015, 08:26 PM #52
Krayziekid's Avatar
Real Name: Jake
Krayziekid's Avatar
Real Name: Jake
Ah ok that makes way more sense. Didn't realize you had an aftermarket bumper. So you want to get rid of those LED strips and make it so you have your turn signals in the 06+ housings? That should be easy as extending the stock turn signal wiring up to the new 06+ harness and matching the colors. That will give you a turn signal in the 06+ housing. I am honestly not 100% sure how to do the DRLs, so I don't really want to comment. I am sure someone around the forum has added DRLs, so there might be a post about it somewhere. I am not sure if it is as easy as adding the relay/flasher or not.
Old 12-01-2015, 08:34 PM #53
Cool, thanks for the input, I will do some more digging on the DRL flasher, I think that should work though.
Old 01-02-2016, 07:56 AM #54
TRDSilverBulitt's Avatar
TRDSilverBulitt TRDSilverBulitt is offline
TRDSilverBulitt is an unknown quantity at this point
DRLs are mentioned in the swap. What if my 05 didn't come with DRLs? Do I still need to rewire? Thanks.
<CENTER><FONT FACE="Times New Roman" SIZE="+1" COLOR="#FF0000">2005 Titanium Silver Toyota 4Runner Sport Edition 4X4 VVTi V8, Non-JBL, Non-Nav</FONT></CENTER>
Mods: Borla Dual Exhaust, Volant CAI, JDM Black Tails, Xenon Depot Xtreme HID 4300k Philips Lows and 3000K Yellow Fogs, HomeLink Upgrade, 2006 Scion 1806 HU w/ iPod, 10" Pre-Amped Bazooka Tube, Infinity Kappa 63.7I 6.5" three-ways with the tacotunes.com 6.5" Tacoma Double Cab Kit for all four doors, Rear Axle Breather Mod, Broadway 270mm Convex Wide Rear View Mirror, Driver Side Overhead "Oh $h!t Handle", OEM 4Runner All Weather Mats, OEM Spider & Envelope Cargo Nets, 265/70/R17 Bridgestone Dueler H/T REVO's, White LED Dome & Door Lights, Wethertech VentVisor, Cornfed 2"/1" Lift Kit, Spidertrax Wheel Spacers, Schrockworks Rock Sliders - Powder coated gray w/ black RhinoLining on step areas.
Planned: Scion Nav
TRDSilverBulitt is offline   Reply With QuoteReply With Quote
Old 01-02-2016, 04:15 PM #55
Krayziekid's Avatar
Real Name: Jake
Krayziekid's Avatar
Real Name: Jake
Yes. Either way, you need to do the wiring. 03-09 4Runner's DRLs and turn signals are the same. It all depends though.
Do you want to leave you're turn signals in the lower bumper? Or do you want them in the new headlight housings? If its the former, you don't need to do anything. If its the latter, you need to rewire. Let me know if you have any other questions
Old 01-03-2016, 10:03 PM #56
vincentshumai's Avatar
vincentshumai vincentshumai is offline
vincentshumai is on a distinguished road
Is this the trim for underneath the headlights?
https://www.rockauto.com/catalog/mor...nid=511&jpid=0
I would need the Left + Right side. Going to attempt this mod over the weekend after I get all the correct parts. Thanks for the write up!
vincentshumai is offline   Reply With QuoteReply With Quote
Old 01-04-2016, 12:16 AM #57
gtfour43 gtfour43 is offline
gtfour43 is on a distinguished road
Sir please do a build thread. I have seen your builds on other forums
gtfour43 is offline   Reply With QuoteReply With Quote
Old 01-04-2016, 12:31 AM #58
Krayziekid's Avatar
Real Name: Jake
Krayziekid's Avatar
Real Name: Jake
Yup! Those are the two little trim pieces you need. I ordered them from rock auto too, and they come in an off-black kind of color. I don't know what color 4Runner you have, but for me, a couple of coats of primer and gloss black rustoleum worked perfectly and doesn't look out of place.
Old 01-04-2016, 12:57 AM #59
Got my swap done, ended up using the 1157a dual filament bulb. I got an 1157 socket and wired one to the turn, and the other to my fogs, which I run as DRLs basically. Happy with the outcome.
Running 4300k hid kit with them as well, pretty happy with the output, but will be doing a retro for sure at some point.
Old 01-04-2016, 11:33 PM #60
Haha, which cars? This is my first SUV ever so this is all a learning experience for me. Crazy how you recognized my username though
Headlight swap DRVNGENTHUSIAST 4th Gen T4Rs 14 03-04-2014 09:38 PM
WHO is going to try the headlight swap? TOY2G 5th gen T4Rs 13 03-02-2014 11:26 AM
Headlight Swap weifert 4th Gen T4Rs 4 06-13-2013 03:27 PM
'98 to mid-gen Headlight swap Asmara 3rd gen T4Rs 1 02-19-2010 01:23 PM
Headlight swap help mario552k 4th Gen T4Rs 6 02-27-2009 02:32 AM
