Old 08-20-2015, 12:44 PM #1
Natter Natter is offline
Natter is on a distinguished road
Trailer wiring not working
So the other day I went and tried to pull a trailer, and the electrical did not work on my truck. I had the 4 pin adapter for the truck and trailer. Thought maybe it was the trailer and tried with a different car and trailer worked fine. The trailer fuse is not blown, any ideas what the issue could be.
Natter is offline   Reply With QuoteReply With Quote
Old 08-20-2015, 02:01 PM #2
nevada's Avatar
nevada nevada is offline
nevada has a spectacular aura about nevada has a spectacular aura about nevada has a spectacular aura about
nevada's Avatar
I know you said the fuse isn't blown, but replace it anyway.
sometimes they break in such a way that it is very hard to see. just put in a new one to verify.
I have also seen fuses pass a DVOM test, but at soon as an actual LOAD is applied, they create an open circuit.
if a circuit is in question at all, replace the fuse.
1985 pickup: EFI 331/4r70W-Dana 300-42 TSL SXII's/raceline beadlocks-30spl longs-5.29's-spools-sky Hi steer-OBA/4g tank-10.5k RR winch-dual blue tops-200 amp alt-flatbed.
1985 4runner sr5: 22RE/5spd-6" pro-comp suspension-37 BFG at's-5.29 gears-Badlands Basher bumper-8.5k RR winch.
2006 4runner v8 limited: stock. Build Thread YouTube Channel
nevada is offline   Reply With QuoteReply With Quote
Old 08-20-2015, 02:51 PM #3
dta1984 dta1984 is offline
dta1984 is on a distinguished road
This happened to me as well. All fuses good, and could not figure out what the issue was. Finally after some advice I cleaned all of the connections where the wiring harness from the truck goes into the multi pin (6 or 7...can't remember) bracket. Put some good electrical grease on there, and it was good to go. I also got a new 4flat connector that plugs into the multi pin socket. Living in the snowbelt, lots of things corrode easily in the back end.
dta1984 is offline   Reply With QuoteReply With Quote
Old 08-21-2015, 01:10 AM #4
ARunner's Avatar
ARunner ARunner is offline
Real Name: Kyle
ARunner is on a distinguished road
ARunner's Avatar
Real Name: Kyle
Check your relay too. Id probably start at the plug at the rear with a test light first though.
03 Limited V8 4WD
ARunner is offline   Reply With QuoteReply With Quote
Old 08-21-2015, 08:10 AM #5
wnelax04sr5's Avatar
wnelax04sr5 wnelax04sr5 is offline
Real Name: Ethan
wnelax04sr5 is on a distinguished road
Real Name: Ethan
I have issues with the connection to the trailer and experience this all the time. cleaning the contacts helps as noted earlier
A lot of stuff I didn't need...
My Build
Originally Posted by kfitz77555 View Post
oh my god the erection I have from this thread is unreal.
wnelax04sr5 is offline   Reply With QuoteReply With Quote
Trailer wiring? Super-G General Discussions 16 01-15-2020 10:15 PM
trailer wiring Lil Red Yarder Classic T4Rs 5 05-03-2011 12:29 AM
Help with trailer wiring trd_4runnin 3rd gen T4Rs 5 11-29-2008 07:37 PM
New Trailer Wiring, Need Help deadduckky Classic T4Rs 1 03-30-2008 08:07 PM
Trailer wiring jsukey 3rd gen T4Rs 1 02-11-2008 02:39 PM
