Originally Posted by NorthernRyan
Sooo my parking brake has never really worked. I'm ok with that, I live where its mostly flat so meh. However I showed my buddy how laughable my parking brake is in actually holding me back by rolling backwards down a slight slope for maybe 5 feet and then driving back up the 5 feet with it on. This was in my back alley next to my garage so I was parking right after and heard some brake creaking.
After messing around it sounds like the parking brake is on slightly on both sides. When starting to move under idle you can hear the brakes creak as the car starts to move. My fear is that they are touching a bit and will heat up and do some damage if I drive with them like this.
What does not make sense is if they don't hold the car back when the parking brake is full on why the hell would they be slightly on when it's off? Did I stretch something slightly? But then shouldn't they just hold the thing back even less, not engage when off?
Since I can hear it on both sides do I...
A) Loosen them off even more at the pads using the star wheel on each side?
B) Loosen them off both at once using the cable locking nut under the console?
C) Just drive it and stop hearing noises as if it is barely touching they will just wear away a bit anyways and be fine?
Still, having to "loosen" (At the pad side I'm pretty sure I'm technically tightening something to bring the pads into the center and not touching the drum") them is odd when they don't hold the thing back at flat idle in the first place.
Thoughts?
I had the same issue, I actually had my car on jacks for 3 weeks while I figured out the issue. brushing noise after adjusting or fixing parking brake.
The only way you can adjust the parking brake is if both rotors are on and both wheels are in the air.
depending on how tech savy you and if you have the time, try taking apart the brakes clean up the rust and spray brake clean with everything. there is a parking brake kit that comes with all replacement parts use them as you need. I'm warning you this is a awfully difficult task as there is limited space. you will need to use string. Please refer to this thread on some tricks. while this is not necessary, it may slightly beef up the parking brake. Its also possible that one side is engaging and the other isn't. I had to replace some springs before the system started to work correctly. If you can take the rotor off (remember to disengage the star adjuster all the way before removing the rotor) and verify both sides of the shoes push out, then at least hardware wise nothing needs adjusting at the wheels. you may need to replace the shoe hold down pins and the springs to get it working again. the C looking shoe down pin in the link below can easily get bent if someone improperly removes the rotor the system can easy build up rust or gunk that will cause the drum system to fail, over time it does need a little touch to bring it back to working order. It is a huge pain in the ass.
the way you adjust the parking brake is the following. make sure the parking brake is not engaged. you adjust the star adjuster up (both sides) as much you can until you cant spin the wheel anymore. then you dial back 8 clicks. While doing this I still had a bit of touching noise as i spin the wheel, in fact I had noise even with the star adjuster all the way down. it probably isn't centered and most people here said its normal. When i engaged the parking brake I couldn't turn the wheel. (make sure you turn both directions).
When I put everything back together I still heard brushing while driving the first half mile. To get rid of the noise, I engaged the parking brake a 3-5 times. Then I found a steep hill with no one around. put the car in neutral and have the car hold itself. Did that a few times, the car held held itself from slightly moving. eventually we heard a slight click and bam the noise went away. I'm not sure if this was the main cause, but we also brought the car to 10mph and applied the parking brake. slowly it brought the car to a stop. I would not advise this unless nothing else works, but it was one of the things we did. not sure exactly what caused the brushing noise to go away.
if it still doesn't hold the car, there is probably nothing you can do at the wheels there is the slack on the cable.
also read this thread, I think I asked every possible question =P
Parking Brake Repair Procedure Question
Please feel free to ask anything, I spent a lot of time on this parking brake.
