09-05-2015, 07:26 AM
Snorkel for 2004 Toyota 4Runner 4.7
hello everybody. I need help. which snorkel will you advice for my 2004 4runner, 4.7? please, share the links, what can I buy. I prefer ebay links. thank you in advance.
09-05-2015, 11:23 AM
Real Name: Tony
Real Name: Tony
There isn't one available yet. It's still being designed. If you look around you can see that some people retrofitted another snorkel kit to fit in their 4Runner.
2005 Toyota 4Runner, Sport Edition, V8, K&N filter, Doug Thorley headers, custom dual exhaust, Bilstein 5100 W/ Tacoma TRD coils in front, FJ Cruiser coils, Daystar 1.5" spacer W/ Doetsch Tech 8000 10" shocks in rear, 2.5" 4crawler Body Lift, removed Sway-Bars, removed mud flaps, removed running boards, chopped body mount, 315/70-R17 Hankook Dynapro MT
Build thread: http://www.toyota-4runner.org/4th-ge...ld-thread.html
09-06-2015, 12:42 AM
I did hear Safari was finally making a unit for the 4th Gen 4Runners, but I haven't heard any news on it in a while.
Most people are using Tacoma or Prado units if I remember right.
09-06-2015, 02:19 AM
Can you tell me, which snorkel kits they use exactly?
09-06-2015, 09:38 AM
Real Name: Tony
Real Name: Tony
I've read about land cruiser kits which you need to heat and bend slightly to make it line up I guess, and another had an FJ 80 snorkel. I haven't read up on it much as I don't need it yet and I'm waiting until after the one made for our trucks comes out.
09-06-2015, 05:46 PM
Thank you very much!
02-08-2017, 03:34 AM
Safari Snorkel SS171HP
I just finished mine. I used the Safari Snorkel SS171HP intended for an '05-15 Tacoma. I preferred the chunkier look and the improved airflow of the ARMAX design. I cut the flare to fit around the snorkel and used stick-on rubber gasketing between snorkel and body to hide the small gap (3/16"). I did use a heat gun to form the snorkel to the body.
2007 Limited V8 FT-4WD
4x4Labs front and rear bumpers, 4.56 Gears with Harrop E-Locker Front & Rear, Icon CVDC w/ 700lbs spring Ext C/Os & Icon MetalTech Long Travel rear CVDC with HD springs, SCS Ray10s with GY MTRs 305/70R17, Prinsu Rack, Rago MSP and ditch light brackets, Wheeler's Super bumpstops
2007 Toyota 4Runner Limited V8 160,000miles
http://www.toyota-4runner.org/4th-ge...-thread-2.html
02-08-2017, 07:20 AM
Looks good!
I used the $70 knockoff on amazon for an 80 series LC. Details are at the end of my 4th gen build thread.
2014 Super White Trail Premium My build thread: http://www.toyota-4runner.org/5th-ge...ld-thread.html
2008 SR5 4X4 V6 Better late than never build thread: http://www.toyota-4runner.org/4th-ge...ld-thread.html
02-08-2017, 11:47 AM
I have the same one... been great so far.. you have to wing it a bit.. but it works!
02-08-2017, 02:13 PM
Originally Posted by gm350reratliff
Looks good!
Nice, yours looks nice and tight to the body and your snorkel intake is nice & straight! I noticed some had to change the angle of the pipe to get the snorkel to fit the Pillar which causes the snorkel intake to be crooked. That was the major reason that I wanted to try the SS171HP, instead.
My fender was mint as well. And even though, I knew the snorkel would cover up the holes, I was still seriously sick to my stomach drilling two 4.5" holes and a bunch smaller smaller holes.
02-08-2017, 09:56 PM
Thanks. It fits pretty good but I did have to heat and re-shape it to get it there. I've drilled, cut, welded other vehicles and I didn't really think twice about it but I really had to think it over before drilling in this fender. I guess you could say I'm a little attached to this 4runner, lol.
