09-06-2015, 05:38 PM
DIY: Rear shocks and Sway Bar Links
Black 2004 Toyota 4Runner SR5 V8 (born again Aug 2014)
DIY: spark plugs, servos for vent and airmix, fender splash shield, seafoam, rear axle seal & parking brake, exhaust muffler tailpipe, rear brakes, hood struts, a/c recharge, front brakes, front struts, rear shocks, ATF exchange, smartphone holder.
09-06-2015, 05:42 PM
DIY Shocks and End Links continued...
09-06-2015, 08:47 PM
Real Name: Danny
Real Name: Danny
Just got done installing 5100s in the rear today and I had to cut off the shocks too. There isn't a whole lot of room to install the new nut on top so I just tightened them down until I had some threads showing on top and the bushing started to squeeze.
09-06-2015, 09:04 PM
I installed 4600's and I squeezed the rubber a bit more than you have in your picture.
I didn't have a crow's foot available during the install to use a torque wrench so I just went off how much the OEM shock bushing was compressed.
03 SR5 Galactic grey, 17" XD Addicts, nj636 wheel bearings, Bilstien 4600's.
09-06-2015, 09:47 PM
I don't have anything constructive to add other than to say that this is the best, most detailed writeup that I've seen in a long time. Thank you.
2004 SR5 4x4 V6 - With New Head Gaskets
09-06-2015, 10:35 PM
fdbyrne is right. This is a very well done post with good pics and explanations. As a non-mechanic I rely on good posts and pics to keep me on the right path.
09-06-2015, 11:09 PM
Hey drunner97 and strathcona. Did your shock also come with just two discs, to sandwich the two rubber pieces? I'm asking because the OEM shock had three of these metal discs. Thanks.
Thanks!
09-06-2015, 11:24 PM
Real Name: Danny
Real Name: Danny
One washer for the bottom, and one for the top.
01-25-2016, 03:12 PM
Thanks!
Awesome write up man. Appreciate the time you took. I just did my rears yesterday as well but I didn't torque anything to spec. Is that a huge deal?
01-31-2016, 01:30 PM
While I didn't really need this guide, this is still an amazing guide I wish I had the first time. Same with your front install. Both are some of the best I've seen.
01-31-2016, 05:36 PM
One piece of equipment that makes this process easier is a set of these.
http://c.shld.net/rpx/i/s/i/spin/ima...4&op_sharpen=1
Ratcheting end wrenches are awesome for the top nut.
01-31-2016, 06:18 PM
Originally Posted by Morphyne
That is flipp'n brilliant. I need a set now. That would've made it easier for sure.
