Real Name: Kyle
Real Name: Kyle
I have never experienced this and I wouldn't think it normal. To me it sounds like something in your suspension. Could be any number of tbings. Spring. Shock. Sway bar. Panhard bar. Basically as you unload ( lose traction) and then suddenly reload (gain traction) something back there is banging together. I don't suspect the driveline as much because you have relatively constant pressure on that. But as your tire suddenly regains traction, it is as though that torque is being transfered back to the vehicle and there is a loose bushing or something that is allowing metal-on-metal contact as the sudden acceleration force is transmitted through. Perhaps when in 4wd, with half the torque being put through the front drivetrain, or possibly you don't lose traction at all, this noise isn't created, as the abrupt forces at the rear aren't near as strong.
03 Limited V8 4WD
