Originally Posted by CXS
Did you add a resistor to eliminate hyperflash?
No resistor - I had the wiring wrong... I did a straight update with the latest version that Shrockworks is installing. So these are not leds.
It went ok - however, the o-ring is very loose, and fell out of the new units. I had to search the area to find them.
I soldered the connections, didn't connect the third wire, and it's working great.
The previous units were completely finished, basically the housing was breaking apart as I removed them.
One other thing - I put the screws in the bumper sticking inward, so the head of the screw is set inside the housing. That made it super easy to put the nuts on and hand tighten. Putting the washer behind the metal housing / support for the turn signal is a nightmare to install/uninstall.
I also removed the headlights (20 second job) to work from above which was way nicer.
JG
