Old 10-03-2015, 07:10 PM #1
Erkelbot's Avatar
Erkelbot Erkelbot is offline
Erkelbot is on a distinguished road
Erkelbot's Avatar
Broken Skid Plate Bolt
Well, here I am again with a broken bolt. I was installing an RCI skid plate on my 08 4Runner SR5, and I broke the front right skid plate bolt when I was taking off the OEM. Literally the first one... PB blaster and all...
My question is, what options do I have?... I'm guessing it's going to need to be drilled out, which is super super (SUPER) irritating. Other ideas? Would everyone recommend I bring it to a body shop and have them do it? I would consider myself a novice when it comes to drilling out bolts.
I hate broken bolts.
Current: 05 GX470
Past: 2002 SR5 Sport, 2007 SE V6, 2015 TEP, 2008 SR5
Erkelbot is offline   Reply With QuoteReply With Quote
Old 10-03-2015, 07:25 PM #2
NJshadow93's Avatar
NJshadow93 NJshadow93 is offline
NJshadow93 is on a distinguished road
NJshadow93's Avatar
Just drill it through and use a nut and bolt if you don't want to retap the hole. Or at least temporarily until you retap the hole.
2006 Toyota 4Runner SR5 V8 4x4-Nautical Blue Metallic
1986 Toyota MR2 AW11 NA 5 Speed
NJshadow93's 2006 SR5 Build
NJshadow93 is offline   Reply With QuoteReply With Quote
Old 10-03-2015, 07:41 PM #3
CXS CXS is offline
Real Name: Chris
CXS will become famous soon enough
CXS CXS is offline
Real Name: Chris
I found out I had a broken bolt the other day and went with the nut & bolt fix. Mine was on the front skid where it mounts to a crossmember, pretty hard spot to add a nut but doable. I now have a couple spare nuts inside the crossmember now. Oops!
Chris - '07 SR5
‘05 Limited - sold
CXS is offline   Reply With QuoteReply With Quote
Old 10-03-2015, 08:21 PM #4
Erkelbot's Avatar
Erkelbot's Avatar
Thanks. I should add, it's not so much the broken bolt...it's the abandonment of the little project fir the night. That's the frustration. I'll get some nuts and bolts tomorrow and get the house in order... Bugger.
Current: 05 GX470
Old 10-03-2015, 09:40 PM #5
CXS CXS is offline
Real Name: Chris
CXS CXS is offline
Real Name: Chris
Mine wasn't a broken bolt now that I think about it for a minute, mine was stripped threads. End result is the same.
Chris - '07 SR5
‘05 Limited - sold
Old 10-04-2015, 09:04 AM #6
BusinessHippieRH's Avatar
BusinessHippieRH BusinessHippieRH is offline
BusinessHippieRH is on a distinguished road
Drill, baby, drill! I'd recommend a cobalt bit. Try and drill right through the center. If you're good and can get all the way through, it helps a lot (and the OEM bolts will typically shatter in half and just kinda fall out at that point). Otherwise, stick a phillips head on the end after getting a ways down, push hard and run the drill slow in reverse.. If you're lucky, it'll back out with it.
Don't bother with Speed Outs or any other special broken bolt remover. They're a waste of money
I always run a tap through after a bolt breaks... better safe than sorry. And: if all else fails, drill the hole bigger and tap it. Ask me how I know: Thanks to some clowns removing my skid to change the oil (despite the quick release valve) and stripping the s#%$ out of it, I know have a 1/2" bolt on one of mine... talk about overkill!
2004 Sport Edition 4x4 V8.
Suspension/Lift: ICON 2.5 Extended Travel coilovers and 2.0 Shocks, Total Chaos UCAs, Metal Tech 3" Springs, RB 1.5 BL;
Axle Upgrades: Currie RockJock 60 rear with Ox Locker, CVJ CVs, 4.88 gears; Armor: 4x4Labs Rear Bumper, Stubbs Welding HD-SKO sliders, RCI Skids;
Wheels/Tires: SCS SR-8 wheels, 295/70r17 Nitto Terra Grappler G2s; Other: LED Interior and Reverse Lights, McNeil Racing Fiberglass Fenders;
More mods on the way...
BusinessHippieRH is offline   Reply With QuoteReply With Quote
Old 10-04-2015, 09:36 AM #7
Erkelbot's Avatar
Erkelbot's Avatar
Thanks for the advice. I probably should've known not all drill bits are created equal -- just like all other tools. I'll get it done right, with some help from my local Home Depot. I'm sure another bolt will break along the way, so it's probably best to be prepared.
Current: 05 GX470
Old 10-04-2015, 10:33 AM #8
brianhuntRVA's Avatar
brianhuntRVA brianhuntRVA is offline
brianhuntRVA is on a distinguished road
Careful not to drill into your radiator once you get through the bolt. Put something above the support. Preferably metal.
03 Sport v8, HCF delete, K&N air filter, Front: FJ KYB StrutPlus w/ 1" spacer, Rear: KYB w/ 1.5" spacer, Cooper Adventurer AT 265/70/17, black headlights/taillights
brianhuntRVA is offline   Reply With QuoteReply With Quote
Old 10-04-2015, 10:49 AM #9
Wavesport Wavesport is offline
Wavesport is on a distinguished road
Left handed drill bits, some fluid and easy outs are ok but they break often. You need to drill all the way through the bolt to relieve some of the tension. Square easy outs are better than 5sides. Use a punch to start your drill on the centre of the bolt, so you don't drift when starting the hole. Smallest bit first, (less than 1/16" usually breaks pretty easy).
If you can drill all the way through and it still won't budge, you could always hit it with a torch. If you can isolate the bolt with the hole in it, and heat it preferentially, it will expand slightly, the shrink a lot when it cools, typically enough to break the adhesion / tension, and you can back it right out. This usually doesn't work very well unless there is somewhere for the bolt to shrink (ie the hole in the centre of the bolt allows the material to shrink into that space)
Others use the same technique but tack weld a smaller bolt to the inside of the larger bolt. The expansion / compression during cooling is still enough that you might just turn it out.
Wavesport is offline   Reply With QuoteReply With Quote
Old 10-04-2015, 02:54 PM #10
jow jow is offline
jow is on a distinguished road
jow jow is offline
1. Use some good goggles to protect your eyes from shavings in the close working area.
2. I have found some self taping bolts to drill and tap hard steel better (two jobs in one).
3. 3/16” bits are fairly good about not breaking if you let it take it’s time using oil vs forcing it.
Good Luck!
jow is offline   Reply With QuoteReply With Quote
Old 10-05-2015, 10:46 PM #11
Atlanta_man's Avatar
Atlanta_man Atlanta_man is offline
Atlanta_man is on a distinguished road
I'm feeling lucky after reading about other folks troubles with the bolts, mine are all OK after at least two dozen oil changes. Always do my own oil changes and never lived where they salt the roads...maybe that's the key.
was: 2005 2wd V8 Limited, one owner (me), 155K miles
now: 2019 Kia Sorento SXL V6
Atlanta_man is offline   Reply With QuoteReply With Quote
Old 10-05-2015, 11:00 PM #12
Erkelbot's Avatar
Erkelbot's Avatar
Yeah, salt is definitely the key...
I drilled out the broken bolt without problem. I then ran into two others that wouldn't budge. One went from a hex head to a football shape and didn't move. The other I laid off because it wasn't moving at all and I didn't want to footballize it. Any thoughts on how to move em? I sprayed them with PB Blaster, banged on them with a hammer and screw driver, but nothing... This is the second time I had to put it back together after attempting it. What a crappy feeling...
Current: 05 GX470
Old 01-02-2016, 06:41 PM #13
Morphyne Morphyne is offline
Morphyne will become famous soon enough
I feel you. It sucks when you have your day all planned out and then stuff breaks. But I am glad you have this post here and so many helpful people with good posts. I have 3-4 broken skid plate bolts that need attention. Not sure when I will get to it, but soon...
Morphyne is offline   Reply With QuoteReply With Quote
Old 01-04-2016, 01:35 PM #14
duffdog duffdog is offline
duffdog is a jewel in the rough duffdog is a jewel in the rough duffdog is a jewel in the rough
I broke a couple of those as well. I just busted off the nut and bolt and welded on a new nut on the outside of the frame where I could get to it easier.
duffdog is offline   Reply With QuoteReply With Quote
Old 01-04-2016, 09:24 PM #15
bvc's Avatar
bvc bvc is offline
bvc is on a distinguished road
bvc bvc is offline
bvc's Avatar
Are you using an impact? Impacts can usually break the stubborn ones loose. Make sure you are using a nice socket with 6 sides, not 12.
-Ben
2006 Sr5 V6 4x4. DS 2.5/1.5, Waag brush & rear bumper guards, Vsc off mod, fog light mod, key & seat belt reminder disabled, weather techs.
bvc is offline   Reply With QuoteReply With Quote
Broken license plate bolt sts00 5th gen T4Rs 14 11-02-2014 10:34 AM
'03 Skid Plate Bolt bradentyrer 4th Gen T4Rs 7 01-14-2013 01:43 PM
Can't get a broken bolt out of chasis from skid.. knightsfs4 4th Gen T4Rs 2 03-06-2012 09:48 PM
Broken/seized skid plate bolts Orion 3rd gen T4Rs 8 03-14-2011 12:26 PM
Had to Tap & Die a Skid Plate Bolt Bluto Problems & Warranty Issues 20 03-04-2005 11:39 AM
