Old 11-03-2020, 12:42 PM #46
Brentcollins Brentcollins is offline
Brentcollins is on a distinguished road
I rebuilt my lower control arms about 1 month ago at 189K on 06 4runner. 3 out of 4 cam bolts were seized in the bushing requiring a sawzall to cut them out. We tried using heat, pb blaster and a c clamp to get the bushings out of the control arm but it wouldn’t work. The only things that worked was using a hammer and a chisel and just hammering the bushings out. The ball joint press rent a tool from oreilly with a cheater bar and heat got the ball joints out. This took about 16 hours to complete. I went with the moog problem solver ball joints off of rock auto and the pro forged ball joints. No problems so far but it’s only been about 2000 miles.
Brentcollins is offline   Reply With QuoteReply With Quote
Old 11-14-2020, 04:42 PM #47
chompster4runner chompster4runner is offline
chompster4runner will become famous soon enough
Tackling the ball joint right now. Got everything off except the ball joint. Waiting on a friend to drop off his ball joint kit. So I got time to post this. LoL
Update. Mission accomplished including new end links. For folks that want to attempt this, have a spare breaker bar. Although I didn’t need it but my bar is stretched. I’m in Cali so rust is not too bad. Major hung ups are tie rod end and steering stop. One side is easy with the separator but the other was a pain but eventually it gave up. Also one steering stop was giving me a hard time too. I didn’t remove the lca so that helped a lot. You’ll need to muscle that C clamp and it will pop very loudly so take care not to slip and whack your fender. Good luck!
2022 Toyota 4Runner TRD OFF ROAD PREMIUM
chompster4runner is offline   Reply With QuoteReply With Quote
Old 11-14-2020, 06:17 PM #48
Clarkson! Clarkson! is offline
Real Name: Tristan
Clarkson! is on a distinguished road
Real Name: Tristan
Thumbs up
Good deal! An impact wrench and press kit and you should be home free. Good luck
2005 SR5 4WD: V8 - Doug Thorley headers, Bilstein 5100s, Slee offroad steel brake lines, Tundra brake swap, JBA upper control arms, 33s on RockTrix wheels, etc.
Clarkson! is offline   Reply With QuoteReply With Quote
Old 11-14-2020, 09:24 PM #49
ktom3001 ktom3001 is offline
ktom3001 is on a distinguished road
I don't know, why not just go this route and get a better ball joint, new cams, better bushings. Plus way less labor.
SUPER PRO LOWER CONTROL ARM PAIR | 2010+ TOYOTA FJ / 4RUNNER – NON KDSS | Apache Offroad
ktom3001 is offline   Reply With QuoteReply With Quote
Old 01-25-2021, 06:22 AM #50
Kymudder Kymudder is offline
Kymudder is on a distinguished road
Any heads up if the MOOG LCA are still made in Japan since this post originated 5 years ago?
Kymudder is offline   Reply With QuoteReply With Quote
2003 Lower Control Arm/Lower Ball Joint replacement Wahoo96 4th Gen T4Rs 5 01-30-2015 02:16 PM
Another lower ball joint replacement question. Dirtyfingers 3rd gen T4Rs 12 11-19-2013 04:29 PM
Lower Ball Joint Replacement BigSlim 3rd gen T4Rs 11 05-23-2013 07:08 PM
lower ball joint replacement tips Beagle(4)Runner Engines / Suspension / Wheels / Tires / Audio / Accessories 7 11-18-2010 04:35 PM
