Old 10-10-2015, 04:04 PM #1
jediwebdude's Avatar
jediwebdude jediwebdude is offline
jediwebdude is on a distinguished road
transfer case is leaking
Walked out to the garage this morning to find a fluid stream coming from beneath the 4R. Never dealt with this before.
TCT Magazine
2019 TRD Pro Tacoma - Voodoo Blue
2018 Shelby GT350
jediwebdude is offline   Reply With QuoteReply With Quote
Old 10-10-2015, 08:07 PM #2
cpark_12's Avatar
cpark_12 cpark_12 is offline
Real Name: Chris
cpark_12 is on a distinguished road
cpark_12's Avatar
Real Name: Chris
Can you tell where it's coming from? It's not the actuator, so that's good! Mine is leaking from the front seal. And looks similar. I have all the parts to fix it, I just haven't had the time.
2003 Sport Edition V8 4X4
TRD Taco coils Bilstein 5100 fronts,
MetalTech LT stage 2 kit w/ HD coils/Icon 2.0 shocks
2006+ Headlights 6000K HID
Level 8 MK6 LT285/70-17 Cooper ATP. Flowmaster 50 series
cpark_12 is offline   Reply With QuoteReply With Quote
Old 10-11-2015, 12:15 AM #3
I'll use Sunday afternoon to get the skids off and get a closer look. Agreed...probably front seal.
What parts did you obtain for the fix?
TCT Magazine
2018 Shelby GT350
Old 10-11-2015, 12:51 AM #4
Jagerzel's Avatar
Jagerzel Jagerzel is offline
Jagerzel is on a distinguished road
Jagerzel's Avatar
Maybe the fill or drain plug? If they are overtightened they can crack the case and under tightened they can come loose. After taking mine apart for a cracked case (at the threads were the last person over tightened the fill plug) I have difficulty believing the Toyota sealant just started leaking. Like cpark said though at least its not the actuator, that is a real pain - and when that leaks it not the sealant, its the rubber gasket. Keep us up
Jagerzel is offline   Reply With QuoteReply With Quote
Old 10-11-2015, 12:49 PM #5
Leak is dripping here on the front side where it connects to front drive shaft:
TCT Magazine
2018 Shelby GT350
Old 10-11-2015, 04:05 PM #6
cpark_12's Avatar
Real Name: Chris
cpark_12's Avatar
Real Name: Chris
Here's the parts that I bought. 2 seals and a nut.
Old 10-12-2015, 12:28 AM #7
Jagerzel's Avatar
Jagerzel's Avatar
That's a better scenario than than a cracked case fo sho.
Old 10-13-2015, 09:37 AM #8
message's Avatar
message message is offline
message is on a distinguished road
message's Avatar
Couple quick notes for you...
The nut is a bear to get off even with air tools, or at least mine was, but better than paying over $300 for have a shop do the work.
Make sure to note the depth of your seal before removing it and you don't have to change the fluid, just top it off if it still looks good.
Write up here thanks to @BigFishAllDay Replacing Transfer Case Output Shaft Oil Seals, a How-To for DIY'ers
2011 Limited - TerrainContact H/T & Blizzak DM-V2 - aFe Pro DRY S - AMSOIL Fluids - Woolwax Undercoat - Lasfit Lighting
2004 SR5 V8 - BFG KO2 - Bilstein Shocks - FJ Springs - Air Lift Bags - Redarc Controller - K&N filter - AMSOIL Fluids - Woolwax Undercoat - Lasfit Lighting
message is offline   Reply With QuoteReply With Quote
Old 10-15-2015, 03:45 PM #9
Took it to an independent shop where they verified it was the front output seal. They then quoted me $1,300 because they claimed that the tcase needed to be dropped and opened up. I was unpersuasive in convincing them otherwise. So it is going to another shop tomorrow where they quoted me $250 labor + parts because they read the actual Toyota repair manual for how to repair it.
TCT Magazine
2018 Shelby GT350
Old 10-15-2015, 03:54 PM #10
fdbyrne fdbyrne is offline
fdbyrne is on a distinguished road
I did the rear seal on my old Tacoma. It really wasn't that hard. Same design. It was easier than most any of the other things that I had to do to it.
The nut was staked to keep it from backing off. I took a cheap punch from harbor freight and ground some off of the tip into a small half-moon shape to where it would fit into the little gap where the nut was staked. Two or three taps with a hammer later it was unstaked and came right off.
Good luck.
2004 SR5 4x4 V6 - With New Head Gaskets
fdbyrne is offline   Reply With QuoteReply With Quote
Old 10-15-2015, 03:55 PM #11
cpark_12's Avatar
Real Name: Chris
cpark_12's Avatar
Real Name: Chris
You've inspired me to go ahead and tackle mine this Saturday! I've had the parts since June or so, but I just kept adding a 2 pumps of fluid once a month maybe because I was lazy! It looks like it may take an hour or so with the right tools though!
Old 10-15-2015, 03:59 PM #12
It's really not tough. It was easier on the Tacoma just because it was higher and I didn't even have to jack up the truck. On my stock-height 4Runner I'd probably have to lift the front end to give myself some breathing room.
Old 10-16-2015, 09:11 AM #13
Ah...you live in the land of Mexican Villa and Cashew Chicken.
TCT Magazine
2018 Shelby GT350
Old 10-16-2015, 09:33 AM #14
Ah yes. You've obviously been to Springfield before.
Old 10-16-2015, 09:41 AM #15
Born and raised there, went to Glendale H.S., SMSU, then moved to TX. My parents still live there, so I get my dose of Mexican Villa several times a year. Took the 4Runner out to SMORR once...nice off-road park.
TCT Magazine
2018 Shelby GT350
Transfer case leaking oil WallyWest 3rd gen T4Rs 16 12-27-2019 02:18 PM
Transfer case leaking EEEliminator 5th gen T4Rs 7 03-31-2019 10:35 AM
Transfer case leaking, but not sure from where WallyWest 3rd gen T4Rs 7 07-06-2015 10:15 PM
transfer case leaking yotababs86 Problems & Warranty Issues 0 03-25-2012 06:20 PM
Transfer Case Leaking DesertDune4x4 3rd gen T4Rs 7 11-30-2009 02:46 PM
