Old 10-10-2015, 07:26 PM #1
planeboy95 planeboy95 is offline
planeboy95 is on a distinguished road
Stuck Diff Drain Plug
Took my truck into Super-Lube for a diff fluid replacement (They were awesome, strait forward and let me watch the whole time) but the front plug just would not budge, even using the largest breaker bar they had. I'm in a temporary apartment and dont have any tools so I have to take it some where or buy the needed tool. Dealership wants $65 just to look at it. Any other options?
planeboy95 is offline   Reply With QuoteReply With Quote
Old 10-10-2015, 08:56 PM #2
brianhuntRVA's Avatar
brianhuntRVA brianhuntRVA is offline
brianhuntRVA is on a distinguished road
Remove the fill plug and pump out as much as possible. Then refill. You'll never get it all but it's better than nothing.
03 Sport v8, HCF delete, K&N air filter, Front: FJ KYB StrutPlus w/ 1" spacer, Rear: KYB w/ 1.5" spacer, Cooper Adventurer AT 265/70/17, black headlights/taillights
brianhuntRVA is offline   Reply With QuoteReply With Quote
Old 10-11-2015, 12:00 AM #3
pearlj10 pearlj10 is offline
pearlj10 is on a distinguished road
What about adding a gentle amount of heat to that stuck drain plug to encourage it to break free? Or add liquid wrench or the like and let it soak for a day and then go back to Jiffy? I know you don't have any tools but maybe a shop could heat that bolt for you. Or suck it up, take it to a dealer for the diff service, and make them fix it? Bummer. Good luck.
pearlj10 is offline   Reply With QuoteReply With Quote
Old 10-11-2015, 12:20 AM #4
V8Man's Avatar
V8Man V8Man is offline
V8Man will become famous soon enough V8Man will become famous soon enough
V8Man's Avatar
This works !!
transmission drip plug stuck
I currently own 4 T4R 4th Gen
#1) 2003 Sport V8 2WD purchased new, totaled @ 175,000.
#2) 2003 SR5 V8 2WD running w/engine from #1(Son#3 is Driving)
#3) 2003 Sport V8 4WD
#4) 2004 Sport V8 Supercharged 4WD
V8Man is offline   Reply With QuoteReply With Quote
Old 10-11-2015, 12:21 AM #5
DREW840 DREW840 is offline
DREW840 is on a distinguished road
I had the same issue with the rear diff today at Valvoline. Even with penetrating oil they had no luck.
I'm thinking I better take it to Toyota now as it may likely need a new plug when they get the old one off. Hoping there is no damage.
DREW840 is offline   Reply With QuoteReply With Quote
Old 10-11-2015, 12:30 AM #6
The diff service from Toyota is going to cost around 140 (ouch) but for them to even take a look at the plug its 65. I know its trivial but it'd really bother me having different services done to the front and rear as well haha. BUT, I might just take it into toyota for the diff service at let them deal with it
Old 10-11-2015, 12:59 AM #7
strathcona strathcona is offline
strathcona is on a distinguished road
At this point it might be the best route taking it to the dealer to have it done and the plug changed out unless you find a reliable mechanic in your area. Obviously it's overdue.
Pricey, but at least in the future you can do it yourself or have another mechanic do it without the heartache you're dealing with now.
03 SR5 Galactic grey, 17" XD Addicts, nj636 wheel bearings, Bilstien 4600's.
strathcona is offline   Reply With QuoteReply With Quote
Old 10-11-2015, 11:55 AM #8
BOSMECH's Avatar
BOSMECH BOSMECH is offline
Location: Stockbridge GA. ( formerly Kent WA. ) & ( formerly Grafton MA. )
BOSMECH is on a distinguished road
BOSMECH's Avatar
Just give it a smal couple of hits with a impact gun and it will come free or hit it with a brass hammer acouple times to free it up.
2003 SR5 V6 4WD Stock (totaled)
2005 Sport Edition SR5 V6 4WD
BOSMECH is offline   Reply With QuoteReply With Quote
Old 10-11-2015, 02:35 PM #9
RPS13 RPS13 is offline
RPS13 is on a distinguished road
My rear diff plug was stuck to the point that it was never going to come loose with just torque or impact. I took my 600 ft-lb IR impact to it, and it just smeared the material around the hex after blaring on it for a while.
I welded a full size nut to it, then it zipped right off with the impact. Probably from the heat of welding to it. I never bothered to replace it, because the nut gives way more surface area for a socket to grab onto.
'92 Nissan 240SX - 400 HP/2500 lbs
'07 4Runner Sport Edition V6 RWD
RPS13 is offline   Reply With QuoteReply With Quote
Old 10-11-2015, 02:49 PM #10
heiser heiser is offline
heiser is on a distinguished road
I've read threads of people using a ball peen hammer (?) to hit the plug and then taking it off which works for some reason. My plug is stuck and that's what I plan on trying when I get around to it.
heiser is offline   Reply With QuoteReply With Quote
Old 10-11-2015, 07:59 PM #11
Atlanta_man's Avatar
Atlanta_man Atlanta_man is offline
Atlanta_man is on a distinguished road
I've found hitting a hammer (not too hard) near the plug while applying loosening force to the plug works. Same thing for Crouse Hines electrical boxes that will lose their ears from direct hammering on the part that needs to come off.
was: 2005 2wd V8 Limited, one owner (me), 155K miles
now: 2019 Kia Sorento SXL V6
Atlanta_man is offline   Reply With QuoteReply With Quote
Old 10-11-2015, 09:01 PM #12
Gatafly Gatafly is offline
Gatafly is on a distinguished road
Originally Posted by V8Man View Post
Yes it sure does. I had the same stuck plug and broke a ratchet and then stripped out the plug. Went to the Toyota dealer and talked to their 4wd mechanic and he told me what to do. Went home and gave it a try. Could not believe how easy it was. Seemed like a miracle compared to trying it the normal way. Guaranteed to work OP.
Gatafly is offline   Reply With QuoteReply With Quote
Old 10-11-2015, 10:11 PM #13
Ill have to look into doing that and when I get a new plug I'm welding a nut onto the end!
Front diff replacement drain plug PN? bugman-74 3rd gen T4Rs 4 05-14-2015 04:37 PM
Front Diff drain plug is a pain in the a s20004runner 3rd gen T4Rs 8 03-23-2015 11:31 AM
front diff drain bolt stuck jgue467 Maintenance/Detailing 4 05-04-2014 04:00 PM
Front Diff Drain Plug Part Number xcmtb83 3rd gen T4Rs 4 12-02-2013 02:35 PM
Stuck Rear Diff Fill and Drain Plugs bike 3rd gen T4Rs 7 10-23-2010 10:22 PM
