11-21-2016, 02:01 AM
#151
Real Name: Addison
Real Name: Addison
Nice mod list incoming... I just picked up a pro dry AFE filter and some synthetic PS fluid. Samies.
11-25-2016, 02:54 AM
#152
could u tell me what (and where) i need to buy to make sure my rci skidplate doesnt rub against the differential after a diff drop kit?
'06 limited 4x4
11-25-2016, 03:42 PM
#153
Your CV angles in your other thread look completely fine, mine are quite a bit higher, even with the diff drop. (Are you sure you're at 3" lift? Maybe mine is more like 3.5"?)
The RCI skid plate should have came with 1/4" spacers for the back bolts and the Wheeler's diff drop kit I used came with 4 similiar spacers for the skid plates. I actually had to add a couple washers for each bolt to space it even further down. I couldn't have a Toyota tech take my skid plate off and expect it to go back on the same way with all those spacers stacked on there.
It has held up alright but I'm still seeking a more permanent solution. (I would take pictures but the skid plate isn't on my truck currently) I might need to machine a single solid spacer for each of the bolts .5" long. Or two solid bars .5" thick that run across the skid plate along each crossmember for more strength. Maybe machine down the diff spacers to .5" and find a compromise between skid plate spacing and CV angles.
Sorry for the paragraph, I just don't like spacing my skid plate down. I've actually though about selling my RCI skid and making my own skid plate .5" lower so at least I don't have to worry about stacking spacers.
11-25-2016, 04:57 PM
#154
Real Name: Tony
Real Name: Tony
I think I'd add a bar across the bolt holes, weld it on for strength and so it isn't falling when you remove the plate for any reason. It would stronger, no parts to loosen and fall out, and generally better overall. Making one would work, but why? All that extra time and material when you already have a plate that just needs a small modification.
Sent from the drivers seat of my 05 4runner.
2005 Toyota 4Runner, Sport Edition, V8, K&N filter, Doug Thorley headers, custom dual exhaust, Bilstein 5100 W/ Tacoma TRD coils in front, FJ Cruiser coils, Daystar 1.5" spacer W/ Doetsch Tech 8000 10" shocks in rear, 2.5" 4crawler Body Lift, removed Sway-Bars, removed mud flaps, removed running boards, chopped body mount, 315/70-R17 Hankook Dynapro MT
Build thread: http://www.toyota-4runner.org/4th-ge...ld-thread.html
11-28-2016, 01:16 AM
#155
Instead of doing my Calc. 2 hw I decided to work on the 4Runner.
- Changed out the PS fluid and swapped that leaky lower line. I only used 2qts before it started looking clean. I bought 4qts so I guess we can do the FJ with the leftovers.
- Changed out the transfer and rear diff fluids.
- Installed the AIP bypass kit. Full set of instructions with color pictures made it super easy. Hopefully I don't get another code from the pump again.
The FJ got fixed as well finally. ECGS's 3rd member came in:
The old gears look horrible. They drug the FJ halfway across the park to get it to the parking lot on a trailer. Every tooth had at least a chip in it. You can even see where it chewed up right below the ring gear. ("I think we found your problem!"):
Hooray for the internet! Without it I would have no idea how to do this stuff.
11-29-2016, 11:18 AM
#156
Real Name: Blake Salce
Damn. Writeup for flushing/refilling power steering fluid PLEASE
Heard something that it's tied in with the power stop brakes or something.
And how about a transmission fluid flush/refill write up. I want to change all my fluids so lemme know what I should do. Don't think they have ever been swapped
11-29-2016, 11:45 AM
#157
What PS fluid do you use?
2007 V8 Sport Edition: Definitely Not Stock
2014 LX 570: Stock
11-29-2016, 11:49 AM
#158
Mobil 1 synthetic ATF.
11-29-2016, 01:01 PM
#159
12-01-2016, 02:37 PM
#160
It was easy except I had to replace a leaky lower hose and those barb fittings are so annoying! Maybe the hose I used was smaller.
As for writeups, I just followed the ones on the forums:
Writeup to replace PS pump, but a flush is after step 11:
https://www.4runners.com/threads/how...luid-flush.18/
3rd Gen but same process:
DIY: Power Steering Flush
1 more just in case:
Power Steering flush? - Toyota 120 Platforms Forum
12-06-2016, 12:34 AM
#161
Real Name: Cody
Real Name: Cody
Got the spindle in and will be finalizing the design. It can hold x2 2 gallon Rotopax. Will hopefully have a buddy at work cut this out along with my skids on the plasma table once I get those designed.
Please let me know asap if you could send me exact plans for this tire holder.... i can pay... i can build it.... but if you could send me the exact plans id absolutely love it!! You can pm me or whatever... but seriously... in love with this...
12-06-2016, 12:39 AM
#162
Real Name: Cody
Real Name: Cody
Nvm.... kept reading!! Thanks!
I do have one question tho... i need my hitch for small trailors and dirt bike carriers... how could you change this to still allow a hitch? Im assuming it would just have to be out a coupple inches extra right?
Reason: More questions
12-06-2016, 12:54 AM
#163
@ Inv4drZm
Do you remember the angle from edge of the frame to the crossmember? I'm finally getting around to doodling the design up and I can't for the life of me seem to figure that angle out (I'd go and take the bumper skin off and make more measurements; but at the moment I'm not supposed to do much hard work since I got a cortisone shot in my shoulder).
Was referencing this diagram and looking at my old notes from when I measured the frame a while back:
Between your measurements and mine there's an uncomfortable discrepancy that I need to account for before buying stock. (i.e. you got 4" for the height of the frame rail and I got 110mm, which is roughly 4.3")
I'm thinking I'll go with a bracket that bolts around frame ends and then use dual heim joints for the hinge (saw it online looking for hinges and I really liked the simplicity of the idea) so I can utilize a 4x2"section of tubing for the main swing out arm to provide better rigidity.
12-06-2016, 01:53 PM
#164
Originally Posted by BlackWorksInc
@ Inv4drZm
From my drawing, 86° or 4° for each of the angles. The 4" height discrepancy is because I measured the frame rail from the backside where the spare tire mounts. I missed the weld seam underneath the crossmember.
The larger swing arm tubing will be good. At least make the hinge and latch taller than my 2"; that should add some strength. I would like to do a revision 2.0 on mine but I'm probably going to make a full bumper anyway, so at least I've learned a thing or two (or so I feel) about the swing-out portion of the bumper.
12-06-2016, 02:03 PM
#165
Yeah that's why I am thinking of a double heim joint, so I can just go 4" Tall like the cross member and make the swingout arm a 4x2" square stock.
