03-26-2020, 04:31 PM
#766
Originally Posted by Inv4drZm
I discovered water leaked in the top windshield seam. I taped the paint just under the trim, and laid a bead of sealant in the gap under the trim. Its a cheap aftermarket windshield so somebody must have screwed up the install and didn't use enough sealant around the top of the windshield. We'll see if my fix works and if not, getting the windshield reinstalled is probably the next step. The plastic trim isn't a seal itself it gets glued in with the windshield, I'm just adding more glue basically.
Any issues with water leaking since then? I think I may have same issue but can't quite figure it out just yet where it's coming from. Sunroof drains are all clear.
2004 Limited AWD V8, Icon Stage 2 w/DJ UCA, Nitto Terra Grappler 285/70/17, SCS SR8, Apex Front Recovery Points, Prinsu Roof Rack
03-26-2020, 08:16 PM
#767
Yes, but more on the driver's side now whereas before it was on the passenger's side. So I think I'm getting closer, I'll lay another bead in there when the weather cooperates.
Got one jig pretty close, almost ready for welding.
If I had to design it again I might have used blind threaded/bottomed out studs vs the countersunk bolts. But you've got to admit the countersunk bolts look nice.
03-26-2020, 10:46 PM
#768
Real Name: Ed
Real Name: Ed
You can drill holes in each port later on so you can back purge
03-26-2020, 10:49 PM
#769
Ed knows all about hole drillin'!
2006 4Runner Sport Edition V8 4WD
03-26-2020, 10:53 PM
#770
Real Name: Ed
Real Name: Ed
03-27-2020, 01:47 PM
#771
I probably should have made it out of a thicker plate of aluminum so I could drill holes in the side of the jig and install fittings on the edge. That way the bottom is still smooth. Might still be able to fit them on the side. I'll be honest, didn't get that far yet.
03-27-2020, 06:28 PM
#772
Well dangit, can't form a puddle in the 3/8 aluminum with 120v/150a machine setting. Need 220v to get the full 200a. Will have to bring my welder and Argon to my grandpa's shop where he has 220v to finish up the jigs.
03-27-2020, 09:21 PM
#773
Real Name: Brett
Real Name: Brett
No dryer circuit at your house? or is that not enough amperage either? or maybe the outlet isn't close enough to your work space.
1988 DLX 22RE AUTO BLACK- "Granny" - SOLD
2003 SR5 SPORT V8- Build- "Pearl" You Tube 2UZ 120
2012 LIMITED V6 "LE Mae" 5TH GEN BUILD THREAD
03-27-2020, 09:56 PM
#774
Long story on that.
I do have a 220 dryer outlet, its about 30ft from the garage, down the stairs. My grandpa has an extension cord too, which is pretty long. I grabbed it today but different plug, I guess welders use a different style plug than dryers. To buy a 50ft extension cord and adapter from Amazon is $200. I'll try the freebie option first to see if it works out. I shouldn't need 220v again after welding these jigs.
Kind of a weird difference between mig and tig that I didn't realize. With mig welding low voltage it still basically works, just low penetration. With tig you can't join anything, you need to form a concentrated molten puddle to add filler wire to, and with low amps the aluminum just absorbs the heat, no puddle, can't add filler.
03-27-2020, 10:34 PM
#775
Real Name: Brett
Real Name: Brett
Long story on that.
I picked up a used Hobart 175 mig last summer and found that out. I had some heavy 12/3 cable about 20' long sitting here for an old project, and bought this Leviton 50A universal at lowes or the depot for less than $20. Might be an option in the future if you can find some cable cheap enough. At 30' you might have to go to 10 guage to be safe though. Might be more trouble than it's worth or just run a new circuit down to the garage if it gets to be a necessity.
03-27-2020, 10:40 PM
#776
Real Name: Brett
Real Name: Brett
Your work is looking pretty damn good by the way!!
03-28-2020, 01:14 AM
#777
Probably less than $200 to have an electrician just add an outlet in garage
Sent from my SM-G986U using Tapatalk
03-28-2020, 06:15 AM
#778
Real Name: Skip
Real Name: Skip
That's only if the electric panel can handled one more 220V circuit, you can only have so much load in a electric panel, if it's already at max capacity you can't add another circuit.
2004 Limited V8
03-28-2020, 07:28 AM
#779
Real Name: Brett
Real Name: Brett
That's true, I forgot about that. Even if there is space in the panel for a 220 breaker, the main might not be rated high enough to handle the load. You could make sure your HVAC, oven and dryer aren't running while your welding, but it still wouldn't be ideal or up to code. And then you might have the problem of old panel equipment that is discontinued and breakers would be hard to find, really expensive, or both. The old Federal Pacific panels here in Florida are one example.
04-01-2020, 10:06 PM
#780
great build
This is really dense with info for your build. If I do start from zero, I'll be taking queues here.
Great build
