Thread Tools Rating: Thread Rating: 5 votes, 5.00 average. Display Modes
Old 05-24-2020, 08:18 PM #901
Inv4drZm's Avatar
Inv4drZm Inv4drZm is offline
Inv4drZm's Avatar
Been working on my brother's FJ this weekend helping install Dirt King heimed long travel, Marlin LCA gussets, spindle gussets, new bearings, RCV axles, and the cam tab delete kit.
He's pulling 12.5" of travel with his 37's, limited by the RCV axle shaft angle on full droop.
Like I mentioned I'm pulling 10" of travel with the shorter +2" Kit.
Inv4drZm is offline   Reply With QuoteReply With Quote
Old 05-28-2020, 09:45 PM #902
Inv4drZm's Avatar
Inv4drZm's Avatar
Success I think. On the way home I about broke my new subwoofer with a sliding aluminum panel. Everything slotted together fairly easily with minimal hammering, but I think I can enlarge a few clearances to make it easier. This drawer setup gets me 20% more cubic area than the single drawer I currently have, which I will be getting rid of.
However, broke my new drawer slider, I think. This piece and a bunch of ball bearings fell out when sliding back in my drawer.
Other than that, the next challenge is to get it to ride quietly with gear inside. I think rubber adhesive-backed liner in the drawers, or something similar, will do the trick.
Old 05-28-2020, 10:47 PM #903
Inv4drZm's Avatar
Inv4drZm's Avatar
LOL a little nicer than my old setup?
Old 05-30-2020, 09:39 PM #904
Inv4drZm's Avatar
Inv4drZm's Avatar
Another weekend of working on the trucks. I did some trimming on my fenders with an angle grinder and flap wheel.
Really close to the slider, it actually rubs when I turn further. I'll grind down the slider and reweld the cap if I have to.
The (mostly) finished product. The 37s will fit and turn well after I space the bumpstops down probably 3/4" in the front and 1/2" in the rear. Didn't even trim my body mount any further than what I did for my 35's, and didn't even cut into the firewall. Really not much more work than it was to fit 35's. LT kit with heims makes it easy.
Dirt King LT, 14" rear shocks, 37s, hydro bumps front/rear. Sweet setup.
I'll be doing a finished alignment on it tomorrow, and he'll be installing a legit rear sway bar.
Old 06-02-2020, 11:18 AM #905
Inv4drZm's Avatar
Inv4drZm's Avatar
McMaster is sending me a new set of drawer slides to replace the broken piece, so that's nice. Love the drawers so far, can fit a bunch in them.
Had to order longer metric socket cap screw bolts for my 3/4" bumpstop spacers so once those are in we can go wheeling with my new tires and start to iron things out.
Only 30 more days until we leave for Moab/Rubicon...
Still need to build a cargo platform, relocate my air compressor and tank, figure out a cover for my subwoofer, mount my refrigerator, and a bunch of other smaller things. This year I'm not in too bad of shape. I hope.
Old 06-02-2020, 11:44 AM #906
Broke_Runner's Avatar
Broke_Runner Broke_Runner is offline
Broke_Runner is on a distinguished road
So in the end which kit ends up being better the +3.5 or +2? living in Utah it’s a lot of rocks and some desert so tighter kit may be better but as you said you can squeeze a little more with wheel offset
Broke_Runner is offline   Reply With QuoteReply With Quote
Old 06-02-2020, 12:26 PM #907
Inv4drZm's Avatar
Inv4drZm's Avatar
Comparing the Total Chaos standard kits, I would steer clear from what I have (+2) unless you where solely wheeling in the desert, and if you were, the +3.5 standard kit is probably better in every way. With the standard kit you loose at least 2" of ground clearance at the end of the arm compared to their race series with their integrated lower uniball. Not to mention weight savings, picking up the Dirt King LCA its light as a feather compared to mine.
So now comparing +2 to +3.5 I would lean towards the +3.5. There are tight trails in Kansas too, but I doubt there will be something I can do with a +2 that I can't with a +3.5, and the +3.5 gives an inch or two more downtravel. The only reason I see going with the +2 is if you also went with the right wheels you could tuck it into the stock fender just barely, or ease of install, my kit I installed easily by myself in my driveway wheras my brother's +3.5 had enough downtravel with the shock installed you had to compress it to connect the UCA to the spindle, etc. Just a little trickier.
If I were shopping for another kit, I would be looking at Dirt King or +3.5 Total Chaos Race/Expedition kits. Or JD Fabrication +2.25" when they get produced. I might eventually swap to the JD kit.
Old 06-02-2020, 12:42 PM #908
SumoRerun SumoRerun is offline
SumoRerun is on a distinguished road
Would a cover like this help from messing up your sub again? Amazon.com: Universal 12 Inch (12") Subwoofer Speaker Metal Grill Waffle Cover Guard Pack of 2 (Pair): Electronics
SumoRerun is offline   Reply With QuoteReply With Quote
Old 06-02-2020, 12:47 PM #909
Inv4drZm's Avatar
Inv4drZm's Avatar
Originally Posted by SumoRerun View Post
Yes I just bought the JL one. I've seen where people cut the plastic panel and add a grill to it which I will attempt. If it doesn't work for some reason I can make an entire new panel out of aluminum and rivnut it on. Another option I think is to find an OEM subwoofer panel but that can get pricey.
Old 06-02-2020, 03:38 PM #910
JuniorPigeon's Avatar
JuniorPigeon JuniorPigeon is offline
Real Name: Aaron
JuniorPigeon has a spectacular aura about JuniorPigeon has a spectacular aura about
Real Name: Aaron
Pretty off-topic, but what CB antenna mount are you using? And 3' length? I'm having trouble figuring out where to put mine.
2007 4Runner Limited V8
| 2.5 Fox 3" lift w/ remotes & DSC | Dobinson 677V rear | SPC UCAs | 1" BL | SCS F5 | 315/70 DuraTracs | Prinsu full rack | RLC rear bumper/swingout | C4 front bumper | Warn VR8-S | F55 fairlead/Flatlink-E | Rocksteady skids | ARB 2500 awning | Dometic CFX 40W | Partner Steel 22" stove | Adventure Index drawer/sleeping platform | ARB twin compressor | Odyssey 34R dual batteries | Blue Sea SI ACR/fuse panel/USB | Renogy 100W Eclipse | Baja Designs Squadron R & S2 | G5R retrofits | Doug Thorley headers/Y pipe | weBoost OTR |
JuniorPigeon is offline   Reply With QuoteReply With Quote
Old 06-02-2020, 03:52 PM #911
Inv4drZm's Avatar
Inv4drZm's Avatar
Its a Diamond K400 mount w/ 2ft Firestik.
It's worked well and I would recommend it though I don't use it much. I'll be looking into mounting it on my bumper with a longer antenna and a quick disconnect, or at least routing the CB cable through the hatch better. Its kinda hard to route from that location and has been dangling from the door jamb for years now. Minimum effort, you can see it in the cargo drawer pics above.
Old 06-02-2020, 04:35 PM #912
Good info to know I will be keeping this in mind because your truck is like a goal for my 4th gen lol funny how your old ucas are on it. I also am wanting to see the marlin kit but have been seeing the realization I probably will have to go with a normal long travel kit just for ease of getting one.
Old 06-04-2020, 11:25 AM #913
Real Name: Aaron
Real Name: Aaron
I've heard a lot of good things about the Diamond mounts but I'm considering going the same route. Bumper mount w/ a 5' Firestik. Strictly for routing the cable, would be completely sealed without running through any jambs.
At that point though I'm sure the hatch will hit it when opening, so a QD may be the way to go. Probably overthinking it in all reality haha.
Old 06-06-2020, 07:25 PM #914
Inv4drZm's Avatar
Inv4drZm's Avatar
Its 100 degrees outside but the mods must continue.
The gameplan:
Partway through:
Old 06-06-2020, 08:12 PM #915
4RunnerAquasport's Avatar
4RunnerAquasport 4RunnerAquasport is offline
Real Name: Brett
4RunnerAquasport has much to be proud of 4RunnerAquasport has much to be proud of 4RunnerAquasport has much to be proud of 4RunnerAquasport has much to be proud of 4RunnerAquasport has much to be proud of 4RunnerAquasport has much to be proud of 4RunnerAquasport has much to be proud of 4RunnerAquasport has much to be proud of
Real Name: Brett
Between the suspension work, the metal fab/welding/exhaust work, and the woodworking, you should just open up a custom mod shop my friend.
I wish I lived in your area just so I could come over to help out and learn some stuff lol. I'm 57 yrs old, but I've always said I can learn from a 4 year old or an 80 year old. Always look forward to your posts. Keep em coming.
1988 DLX 22RE AUTO BLACK-"Granny" - SOLD
2003 SR5 SPORT V8- Build- "Pearl" You Tube 2UZ 120
2012 LIMITED V6 "LE Mae" 5TH GEN BUILD THREAD
4RunnerAquasport is offline   Reply With QuoteReply With Quote
DHPham's 1997 4runner Build Thread (also 4wd swap thread) dhphamqc 3rd gen T4Rs 15 03-02-2019 03:08 PM
>BUILD THREAD< The4kbeast's 3rd-Gen 2000 T4R SR5 (Highlander Edition) 4x4 Build The4kbeast 3rd gen T4Rs 285 07-25-2018 09:37 PM
STRRAYNGE Build Thread! Or, I should say, After Build Thread?! Pic Heavy STRRAYNGE 3rd gen T4Rs 24 02-11-2016 10:46 AM
1998 T4R Build Thread/Rear bumper build 4running11191 4running11191 3rd gen T4Rs 3 09-19-2014 07:07 PM
