Thread Tools Rating: Thread Rating: 5 votes, 5.00 average. Display Modes
Old 08-07-2020, 10:48 PM #1006
JBend JBend is offline
JBend will become famous soon enough
Originally Posted by Inv4drZm View Post
Wow I now have 1,000 posts in my build thread.
Here's to 1,000 more.
To 1,000 more!
I saw you're using stoptech pads and rotors which I'm looking into as an alternative to the power stop z36 kit but was wondering which calipers you're using and If you're running the 319mm or 338mm rotors. Thanks!
JBend is offline   Reply With QuoteReply With Quote
Old 08-08-2020, 10:14 AM #1007
Inv4drZm's Avatar
Inv4drZm Inv4drZm is online now
Inv4drZm's Avatar
Originally Posted by JBend View Post
To 1,000 more!
I'm just using the stock calipers my truck came with and the 338mm rotors. Can still lock up my 37s so I saw no real reason to swap to 5th gen parts.
Inv4drZm is online now   Reply With QuoteReply With Quote
Old 08-08-2020, 01:55 PM #1008
Not had many problems with the calipers? I know I've seen you post something about calipers but I can't seem to recall what or where it was. 😔
Old 08-08-2020, 01:56 PM #1009
Sorry for the double post but just thought of this, you could still use the stoptech parts and upgrade to the 5th gen calipers right?
Old 08-08-2020, 04:26 PM #1010
Inv4drZm's Avatar
Inv4drZm's Avatar
Not had many problems with the calipers? I know I've seen you post something about calipers but I can't seem to recall what or where it was. ��
One side was seized but I used a clamp to free it up and it's been working ever since, around 4,000 miles now.
The 4th gen rotors are thinner, but I guess I probably could still swap to 5th gen calipers. I just don't have the need to right now, and like I said braking performance is fine even with how heavy my truck is.
Old 08-11-2020, 07:55 PM #1011
Inv4drZm's Avatar
Inv4drZm's Avatar
Part 1 of our Rubicon vid is out. Grab some popcorn.
Old 08-12-2020, 10:10 AM #1012
gfxcruncher's Avatar
gfxcruncher gfxcruncher is offline
gfxcruncher has a spectacular aura about gfxcruncher has a spectacular aura about gfxcruncher has a spectacular aura about
Nice build, great driving too! You know the trail is crazy when it looks insane on video.
2007 SR5 4WD Nautical Blue -- Build Thread
gfxcruncher is offline   Reply With QuoteReply With Quote
Old 08-13-2020, 07:37 PM #1013
Inv4drZm's Avatar
Inv4drZm's Avatar
Part II is out.
Old 08-17-2020, 07:11 PM #1014
Inv4drZm's Avatar
Inv4drZm's Avatar
This is going to require a lot of work some day.
Tall enough to fit 14" coilovers flush with the axle tube once I chop into the body a little. Won't interfere with the rear seats if I weld them behind the axle and cut into the rear of the wheel well. Anyone want to donate me some coilovers?
Old 08-17-2020, 08:23 PM #1015
4RunnerAquasport's Avatar
4RunnerAquasport 4RunnerAquasport is offline
Real Name: Brett
4RunnerAquasport has much to be proud of 4RunnerAquasport has much to be proud of 4RunnerAquasport has much to be proud of 4RunnerAquasport has much to be proud of 4RunnerAquasport has much to be proud of 4RunnerAquasport has much to be proud of 4RunnerAquasport has much to be proud of 4RunnerAquasport has much to be proud of
Real Name: Brett
You could start a Go Fund Me account.
I thought about starting a - Brett needs a Trophy Truck - account.
But then I figured I wouldn't have enough money to tow it any where, or the money to fill it up with fuel, so I gave up on that one.
I know Kevin Berthelot's Mega Lex has the rear seats removed for his rig with COs and Bypasses, but it's not a daily like yours. Curious how your gonna do your geometry. The Sherpa Motorsports crew welded support hoops inside the wheel well which I'm curious about as well. Love my truck the way it is, but you know, you always want more travel.
Inv4drZm's Build Thread-69672785_2894751850536425_5667107586411855872_n-jpg  Inv4drZm's Build Thread-69749697_2894751943869749_6014107357284401152_n-jpg
1988 DLX 22RE AUTO BLACK-"Granny" - SOLD
2003 SR5 SPORT V8- Build- "Pearl" You Tube 2UZ 120
2012 LIMITED V6 "LE Mae" 5TH GEN BUILD THREAD
4RunnerAquasport is offline   Reply With QuoteReply With Quote
Old 08-18-2020, 05:03 PM #1016
Inv4drZm's Avatar
Inv4drZm's Avatar
It'll be fun, I'll need to chop into the body a little and re-plate the wheel wells around the towers to re-seal everything. 14" of shock travel will be nice, but I'm betting the main benefit will be from raising the lower mounts to flush with the axle tube. I swear I hit those things on every rock.
The Sherpa truck has an identical rear setup to my brother's FJ which is pretty nice too.
Old 08-18-2020, 06:25 PM #1017
Real Name: Brett
Real Name: Brett
Which coil springs is your brother using? Does he have a thread somewhere? Curiouser and Curiouser...
Old 08-18-2020, 06:56 PM #1018
Inv4drZm's Avatar
Inv4drZm's Avatar
He's got Metaltech 3" Heavy coils like me.
He tells me he's got a rear suspension thread. LOL fancy.
Iconic's Rear "Super" Long Travel | Toyota FJ Cruiser Forum
Build thread:
Iconic's Partial To Blue Build | Toyota FJ Cruiser Forum
Old 08-18-2020, 07:39 PM #1019
montijo505's Avatar
montijo505's Avatar
Don't do it man.......
Jk it's about time you match that wicked front end!
Sent from my SM-G986U using Tapatalk
Old 08-18-2020, 08:16 PM #1020
Real Name: Brett
Real Name: Brett
I'm already itching to go +3.5" in the front and go full insanity in the rear lol. Actually I have close to the same wheel travel front and rear. My rear smoothies are custom length at 28.25" but the standard lower mount only gives it 9" stroke. Looking at moving the upper mounts up higher and adding some bump cans. I want more up travel for my speed addiction. No real rock crawling here in swamp land, so droop is not as crucial.
I still need 4:56s and a locker before any of this suspension gets worked on. Damndemic screwed my plans this year.
DHPham's 1997 4runner Build Thread (also 4wd swap thread) dhphamqc 3rd gen T4Rs 15 03-02-2019 03:08 PM
>BUILD THREAD< The4kbeast's 3rd-Gen 2000 T4R SR5 (Highlander Edition) 4x4 Build The4kbeast 3rd gen T4Rs 285 07-25-2018 09:37 PM
STRRAYNGE Build Thread! Or, I should say, After Build Thread?! Pic Heavy STRRAYNGE 3rd gen T4Rs 24 02-11-2016 10:46 AM
1998 T4R Build Thread/Rear bumper build 4running11191 4running11191 3rd gen T4Rs 3 09-19-2014 07:07 PM
