Thread Tools Rating: Thread Rating: 5 votes, 5.00 average. Display Modes
Old 04-17-2024, 04:36 PM #1366
Inv4drZm's Avatar
Inv4drZm Inv4drZm is offline
Inv4drZm's Avatar
Pondering the best way to add cats to my long tube headers without losing rock clearance, and quiet my exhaust. Tired of the fumes and noise.
I'm pretty sure the only way is to add the cats after the X pipe, though I'm not sure how efficient they will be that far from the headers.
The other option is going back to a single muffler setup (removing my X pipe), and adding a cat after a Y pipe. This would reduce muffler weight and increase rock clearance and I could run my oem tailpipe to move the exhaust fumes out.
Inv4drZm is offline   Reply With QuoteReply With Quote
Old 04-26-2024, 03:34 PM #1367
FoundedSine14's Avatar
FoundedSine14 FoundedSine14 is offline
FoundedSine14 will become famous soon enough
All 92 pages (so far) of this thread are incredible - thank you for sharing so much with us! You've given me a lot of ideas and added many things to my shopping list lol
2008 SR5 | Build Thread
2006 AutoX Camry | Build Thread
FoundedSine14 is offline   Reply With QuoteReply With Quote
Old 04-29-2024, 09:16 AM #1368
Inv4drZm's Avatar
Inv4drZm's Avatar
Swapped rear diff cover to a stronger one that hopefully doesn't leak, replaced front, mid, and rear diff fluids. And did engine oil changes in both trucks.
Lucas 85w-140 in front and rear, lucas 75-90 in center diff, mobil 1 in engines.
5 gallon bucket fit great under the 4runner in all but the rear diff lol.
Picked up a new torque wrench from Harbor Freight after getting tired of the cheap old torque wrench from Harbor Freight not clicking strong enough for me to feel.
Old 05-15-2024, 06:58 PM #1369
Inv4drZm's Avatar
Inv4drZm's Avatar
For my future reference, existing mangled skids weigh:
Front: 42.5
Mid: 35
Rear: 30
Total: 107.5
Hoping to make some lighter ones out of 1/8" AR.
Old 05-21-2024, 06:50 PM #1370
Inv4drZm's Avatar
Inv4drZm's Avatar
Took 3 days off for my birthday and to catchup on the Celica and 4Runner project list.
Something I didn't take pics of, I added .25" fender washers to my 1.5" body lift so my rear doors don't contact my bent sliders. I'll work on beefing up the rear of the sliders later. For now this was an easier fix than cutting off the sliders and rewelding.
I beefed up the passenger side front diff mount with some 1/4" AR plate.
Replaced my stock style one-way rear diff breather with an ARB breather which is 2-way.
Welded the edges of my aluminum switch pro water and dust shield. I made this cover years ago but never got around to welding it. Wasn't really necessary but looks better and seals better.
Old Today, 11:31 AM #1371
Inv4drZm's Avatar
Inv4drZm's Avatar
Might start selling these for 4Runners, made from 1/8" aluminum. Uses factory tie-down points to keep cost and installation time down, as well as easy removal. Can bolt to a plywood base though if you want to make one. Can run either module separately or together, and each side can mount a molle or blank panel for an air compressor and tank setup. If you want 4 drawers or 2 fridges (lol), go for it. I've kept the height minimal so it won't impede rearward visibility at all, but plan to make a taller set that incorporates another drawer on both sides.
DHPham's 1997 4runner Build Thread (also 4wd swap thread) dhphamqc 3rd gen T4Rs 15 03-02-2019 03:08 PM
>BUILD THREAD< The4kbeast's 3rd-Gen 2000 T4R SR5 (Highlander Edition) 4x4 Build The4kbeast 3rd gen T4Rs 285 07-25-2018 09:37 PM
STRRAYNGE Build Thread! Or, I should say, After Build Thread?! Pic Heavy STRRAYNGE 3rd gen T4Rs 24 02-11-2016 10:46 AM
1998 T4R Build Thread/Rear bumper build 4running11191 4running11191 3rd gen T4Rs 3 09-19-2014 07:07 PM
