Old 10-12-2015, 04:27 PM #1
henduford henduford is offline
henduford is on a distinguished road
Coolant leak 2004 v8, freeze plugs?
I have a 2004 T4R V8. I have been having a random coolant leak that would leave a puddle of coolant near the rear of the motor where it meets the transmission and looks like its dripping right from that spot as well, its not dripping from the front of the motor and running down the skid plates. I took it to a shop today and they are thinking that it is the freeze plugs gone bad. They are stating they have to take of the transmission to get to them in order to replace them. $855 for labor and then any parts on top of that ($20-50 per freeze plug if there is more than one). Does that make sense? Is that what is involved if the freeze plugs go bad, the whole transmission has to be removed to get to them? Any help would be greatly appreciated?
henduford is offline   Reply With QuoteReply With Quote
Old 10-12-2015, 08:52 PM #2
bergs's Avatar
bergs bergs is offline
bergs is on a distinguished road
bergs's Avatar
Coolant might also be running from the top of the engine and down the back.
I have my doubts it's a freeze plug and highly doubt more than one. As a customer I'd want the shop to show me they can trace it back to the source, especially if they're asking for 900+ and showing lack of confidence in their diagnosis.
bergs is offline   Reply With QuoteReply With Quote
Old 10-13-2015, 03:10 PM #3
Thanks for your info. I actually decided to get my runner and have my wife's uncle look at it. He was a mechanic for 26 years. We found it leaking near the front of the motor and it was draining down the center of the motor in the bakery below the intake. It will fill up that valley and then will flow to the back and escape around and between the engine and transmission. We aren't sure where is coming from up front yet but definitely looks to be the source of the leak. If I'm parked on a downhill I don't get the poodle on the ground bit if I'm uphill or level and is leaked enough to seep through the drain holes it will leak.
Old 10-13-2015, 05:09 PM #4
blind squirrel's Avatar
blind squirrel blind squirrel is offline
blind squirrel is on a distinguished road
If I remember right a member had this same leak like a week or two ago. Turned out to be the water pump seal leaking. Did you recently have yours changed? Are you due for the service?
blind squirrel is offline   Reply With QuoteReply With Quote
Old 10-19-2015, 08:21 AM #5
I had the water pump don't last November with the timing belt. I just got my runner back and the shop fixed it for free.
removing 3.4 engine to replace freeze plugs - what else should I do while its out? stinkypoop 3rd gen T4Rs 17 07-16-2021 04:19 AM
2004 V8 coolant leak near back of motor randomly henduford 4th Gen T4Rs 11 10-19-2015 08:29 AM
Coolant Leak 2004 V8 Zona Cat 4th Gen T4Rs 8 02-26-2013 04:18 PM
Coolant Leak- Drivers side coolant manifold? Shibby! 3rd gen T4Rs 19 12-28-2012 09:37 PM
freeze plugs? jdcanadian Problems & Warranty Issues 5 04-04-2010 01:23 PM
