Old 10-12-2015, 04:52 PM #1
Nicki04runner Nicki04runner is offline
Real Name: Nicki Jobst
Nicki04runner is on a distinguished road
Leaking Front differential
Hey guys I am having some trouble with my 2004 4runner front differential.
I just replaced the CV axels on both sides and after driving it for about 100 miles there seems to be differential fluid leaking on the passenger side from where the CV enters the front differential. Any one have any Ideas on how I should go about fixing it? I am assuming that it is being caused by a broken seal inside the differential where the shaft is inserted but I am no expert so some help would be much appreciated!
Nicki04runner is offline   Reply With QuoteReply With Quote
Old 10-12-2015, 04:58 PM #2
fdbyrne fdbyrne is offline
fdbyrne is on a distinguished road
Your probably right. There is an axle seal that the CV shaft goes through. It's not hard to replace and it's generally recommended that it be replaced if you replace the CV shaft because it often gets damaged and leaks shortly afterwards... like you are finding out.
You have to pull the CV shaft back out, pull out the old seal, install the new seal, then put everything back together. It's not hard, but it takes the same amount of labor to do it than the CV axle which is why it's usually done at the same time.
My only recommendation is to use an OEM seal. They're only about $10 and I've found that they fit much better than aftermarket.
Did you replace the CV shafts yourself or did a shop do it?
2004 SR5 4x4 V6 - With New Head Gaskets
fdbyrne is offline   Reply With QuoteReply With Quote
Old 10-12-2015, 05:08 PM #3
Wavesport Wavesport is offline
Wavesport is on a distinguished road
Indeed I think you are correct. The seal on the differential likely needs to be replaced. They are about 15 bucks a piece and are different on each side. Toyota part numbers: 41311b for RH and LH (which are different part numbers)
2004 4x4 V6 Sport - Wavesport's Build Thread
shit quality Toytec Boss 2.5 Series Coiloversgarbage, 1" Diff Drop, 2" Hyperflex Lift Coils, 2" Extended Rear shocks, Total Chaos Fab UCA's, Shrockworks three hoop, Warn 12xp
FN Wheels f(x)PRO 17x8" Wheels in Dark Gunmetal, BFG AT T/A KO2's @ 285/70/17
Wavesport is offline   Reply With QuoteReply With Quote
Old 10-12-2015, 05:08 PM #4
Thanks man! I did the CV shafts myself, where should I get the OEM seal? Should I try a dealership or is there a website or shop that would sell them?
Old 10-12-2015, 06:03 PM #5
For something as cheap as a seal I'd just go to the dealership. It's not worth waiting and shipping. If it were a more expensive part I'd look online.
You can use a 2" PVC coupler (like you would use to connect 2 pieces of 2" PVC pipe) to drive the seal into place. It fits perfectly.
Old 10-13-2015, 07:38 PM #6
How am I supposed to remove the seal I can't seem to get it free? Any ideas?
Old 10-13-2015, 08:24 PM #7
Morphyne Morphyne is offline
Morphyne will become famous soon enough
Dig it out with a screwdriver? Since you are replacing it it shouldn't matter?
You might have to run to the autoparts store and get one of those bent need nose pliers?
Morphyne is offline   Reply With QuoteReply With Quote
Old 10-13-2015, 08:28 PM #8
Here you go. I see why you go stuck. Would not have thought this.
https://youtu.be/H97Vh6woJ68
Old 10-13-2015, 08:34 PM #9
I always use the claw end of a standard carpenter's hammer for better leverage. Just be sure to tape up the end of the hammer so that you don't scratch up the inside of your differential housing.
Old 10-13-2015, 08:51 PM #10
paraordnance's Avatar
paraordnance paraordnance is offline
paraordnance is on a distinguished road
To pull old seal out get yourself a seal remover (is that a proper word?) it looks like screwdriver but has pointed hook at the end. Works great to get stubborn seals out. Make sure you get yourself new OEM seal and then install it on the shaft and carefully slide the CV shaft back in place. You can see below what I mean.
When I was replacing my CV axles, after first time my seal was leaking due to the fact that I must have not installed it properly. I used socket to set it in place and probably drove it too far or bent it somewhere. You need to be really careful how far you push it in and not damage it at the same time. Simply lube your new seal, slide it on the axle until it sits against dust shield and carefully!! install the axle back. It worked for me!
2004 4Runner Limited V8 4WD
Toytec Ultimate 3" (X-REAS & RAS - delete). LS460 + STi retrofit, Switchback Halos, LEDs in/out, Fog light mod.
CBI front bumper. 285/70/17 Duratracs.
JVC KW-V50BT with Hertz HCP4D & Hertz HCP1D, Hertz ESK-165 components and JL 10TW3 in custom stealth enclosure. Backup camera and steering wheel controls.
paraordnance is offline   Reply With QuoteReply With Quote
Old 07-03-2020, 10:19 PM #11
Limited1996's Avatar
Limited1996 Limited1996 is offline
Limited1996 is on a distinguished road
Hmm
Almost 5 years old but dang never thought about sliding the seal over my axle and putting it in 🤔
Limited1996 is offline   Reply With QuoteReply With Quote
2004 , 4runner , cv axle , front differential , leaking diff fluid
Center differential + rear differential + front differential = confusion! badburro 5th gen T4Rs 37 01-29-2019 12:40 PM
Rear differential leaking housing leaking? Schwooby Classic T4Rs 5 07-01-2014 06:43 PM
Rear Differential Leaking cck655 New Members 3 08-26-2013 09:53 PM
Leaking Rear Differential Tedward 3rd gen T4Rs 1 03-07-2010 03:26 PM
Leaking front differential (1998) Jenn Problems & Warranty Issues 1 12-08-2003 08:35 PM
