Old 07-11-2006, 01:03 AM #1
smoa1980 smoa1980 is offline
smoa1980 is an unknown quantity at this point
shift lock
I have a 1997 4runner. I just got back last night, from a long trip where I towed a 1500lbs boat about 600 miles. all seemed well when I got home, but today I went to move it and It was stuck in park. I was able to push the shift lock and get it in drive, but it now I have to push it everytime i want to shift out of park. What would cause this. I know there is a little solenoid that controls it, but what would cause the solenoid not to activate the shift lock. Could the solenoid be bad or is the computer tell it not to activate.
smoa1980 is offline   Reply With QuoteReply With Quote
Old 07-11-2006, 01:04 PM #2
David D David D is offline
David D is an unknown quantity at this point
Are your brake lights working? I'm fairly new to T4R ownership, but most vehicles use the brake light switch to activate the park shift lock solenoid. Previous experience dictates that that's the first place to look.
David
David D is offline   Reply With QuoteReply With Quote
Old 07-11-2006, 02:11 PM #3
xUSNavy xUSNavy is offline
xUSNavy is an unknown quantity at this point
Agree. My father's 97 Tacoma wouldn't shift out of park. I found out the fuse to the brake lights and one of the bulbs was blown. Once I replaced the fuse and the light bulb, the problem was gone.
For some reason, if the brake lights or fuses are not functioning, the transmission will not let you shift out of park. So I would check those items first.
xUSNavy is offline   Reply With QuoteReply With Quote
Old 07-11-2006, 02:51 PM #4
SKO450ES SKO450ES is offline
SKO450ES is an unknown quantity at this point
I had the same thing happen last year, for me it was the small ECU in the back for the trailer lights that got fubared.
SKO450ES is offline   Reply With QuoteReply With Quote
Old 04-14-2024, 03:07 PM #5
iceman1wayne iceman1wayne is offline
iceman1wayne is on a distinguished road
09 tacoma with shifter lockup after towing.
where is the ECU in the back for the trailer lights located?
iceman1wayne is offline   Reply With QuoteReply With Quote
Old 04-14-2024, 04:47 PM #6
need help here! 2009 tacoma shifter locked
trying to solve the issue after towing utility trailer. shifter locked after parking. lost all crusie ,air,srs, turn signals also. got truck home and went through a few sites. no fuses blown and also changed out the brake control switch. no luck after that. called dealer and says could be wiring fault somewhere. anyone else have any ideas before i get into wiring checks???
Old 04-16-2024, 05:47 PM #7
SurferUK's Avatar
SurferUK SurferUK is offline
SurferUK has a spectacular aura about SurferUK has a spectacular aura about SurferUK has a spectacular aura about
SurferUK's Avatar
Could it be damaged tow bar wiring/socket? I can't see how a trailer can damage internal wiring etc.
2008 2.7 2WD 4 speed (Tacoma-Runner?)
SurferUK is offline   Reply With QuoteReply With Quote
Old 04-24-2024, 06:25 PM #8
bendover717 bendover717 is offline
bendover717 is on a distinguished road
Maybe its the shift lock solenoid itsself. Pulling the trim around the shifter is pretty easy... maybe look into that after confirming your brake lights work properly.
bendover717 is offline   Reply With QuoteReply With Quote
gear shift lock on 4Runner gsnake 4th Gen T4Rs 4 02-12-2010 01:10 AM
Shift lock trim cover espressoman Engines / Suspension / Wheels / Tires / Audio / Accessories 1 03-27-2009 11:02 AM
Part # for Shift Lock Release Cover DavidAlexander 3rd gen T4Rs 0 12-14-2008 06:58 PM
Shift Lock Override JP4RNR 4th Gen T4Rs 4 12-24-2006 01:36 PM
Shift lock override cover makakio 4th Gen T4Rs 5 11-16-2004 04:19 PM
