Old 10-24-2015, 11:02 PM #1
xxaarraa xxaarraa is offline
xxaarraa is on a distinguished road
CV binding slightly on passenger side on full droop
I pinged the 4th gen jedi knight aha2988 about this, and figured I should post here also.
Here's my current setup: OME 885s + Toytec top out spacers = ~3.5 inches of lift up front. Toytec diff drop, LR ucas. With the truck jacked up all the way in the front and front wheels in full droop, if we rotate the wheels by hand, my passenger front wheel's CV binds just a tiny bit in one spot. We can roll right past the binding without much effort, but it does bind. The driver's wheel doesn't. We also noticed that even though I have the aftermarket LR UCAs, the UCAs make contact with my sturuts on full droop.
Question - Should I be worried about wheeling as is? The light binding can't be normal for lifted 4th gens, right? If so, what options do we have for aftermarket CVs? I searched the forums and only saw one company that makes them and they were $565 per side (!) If upgraded CVs aren't an option, should I take out the top out spacer and just drop the front back down by half to one inch or so?
Here are pics showing CV angle while just parked on level ground.
Here's the 1/2" Toytec top out spacer + OME 885.
GONE - 08 T4R - 4" Lift with OME 885/895 & Bilstein 5100s, Toytec top-out spacer, Daystar 2" spacer, 1.5" Body Lift, 275x65x20 Duratracs (34.1"), Light Racing UCAs, Spidertrax, Toytec Diff Drop, 5th gen brake upgrade, SS brake lines, Budbuilt 5 piece skid kit, CBI sliders, Avid light bar, Hella 500ff with HID conversion, Curt front hitch receiver, ARB Awning, Uniden/Comet CB, Rostra seat heaters, Dynamatted interior
Corvette C7 Z51 | Ford Raptor | Aprilia RS250 | Aprilia RSV4 | Ducati 848 Corse
xxaarraa is offline   Reply With QuoteReply With Quote
Old 10-24-2015, 11:08 PM #2
wyanrard's Avatar
wyanrard wyanrard is offline
Real Name: Ryan
wyanrard is on a distinguished road
wyanrard's Avatar
Real Name: Ryan
Here's my current setup: OME 885s + Toytec top out spacers = ~3.5 inches of lift up front. With the truck jacked up all the way in the front and front wheels in full droop, if we rotate the wheels by hand, my passenger front wheel's CV binds just a tiny bit in one spot. We can roll right past the binding without much effort, but it does bind. The driver's wheel doesn't. We also noticed that even though I have the aftermarket LR UCAs, the UCAs make contact with my sturuts on full droop.
I'm at around 3.5", order a diff drop. Solved my issue.
2003 SR5 4WD V6
wyanrard build/picture thread
-Bilstein 5100s w/OME 884 Coils Replica Camburg UCAs
-Procomp ES9000 extended rear shocks with Toytec SuperFlex Coils.
-2012 FJ Wheels (17s) wrapped in 275/70-17 Cooper Discoverer AT3 Load Range C. SpiderTrax 1.25 up front
wyanrard is offline   Reply With QuoteReply With Quote
Old 10-25-2015, 01:03 AM #3
having fun's Avatar
having fun having fun is offline
Real Name: Leonard
having fun will become famous soon enough having fun will become famous soon enough
having fun's Avatar
Real Name: Leonard
Drop differential, or smaller top spacer or non.
Had same problem with OME and put a 10mm top hat on to cure the driver lean. Went to full bind on all 3 points of CV while turning also.
Having fun's build
having fun is offline   Reply With QuoteReply With Quote
Old 10-25-2015, 07:33 AM #4
I should have clarified. I'm already running a toytec diff drop.
Old 10-25-2015, 09:37 AM #5
having fun's Avatar
Real Name: Leonard
having fun's Avatar
Real Name: Leonard
I don't have a drop in mine, so if you wish not to have the bind due to of roadding and want to have the max lift height. I would crank the toytec's down just a little.
Having fun's build
Old 10-25-2015, 10:17 AM #6
I am thinking the same. I added photos to show my setup and CV angles.
Aha2988 also responded to my PMs, I will post up his thoughts once I check with him to make sure he's OK with it.
Old 10-25-2015, 02:28 PM #7
blackoutt's Avatar
blackoutt blackoutt is offline
blackoutt has a spectacular aura about blackoutt has a spectacular aura about
blackoutt's Avatar
I had a similar issue when I tried to put 1/2" spacer on top of my 885's + the 1/4" spacer on the driver side to fix the lean. I ended up pulling the 1/2" spacers out because my drivers side CV was binding at full droop. I did see one thread where someone milled a bit off the end of the inner CV cup to allow more angle if you're dead set on going that high. I'm not sure how others get away with it all the time but it didn't work for me either.
blackoutt is offline   Reply With QuoteReply With Quote
Old 10-25-2015, 07:40 PM #8
Nyc-Runner's Avatar
Nyc-Runner Nyc-Runner is offline
Nyc-Runner is on a distinguished road
Nyc-Runner's Avatar
Are you running OEM CV's or aftermarket? Both my OEM CV's bind the same way when on the lift also at full droop, it is common for our trucks when lifted 3"+ That's why it's really not recommended to lift the front more than 3"-3 1/2"
A few months ago i tore my driver side boot so i ordered a aftermarket Cardone select CV to replace it so i could have that one re packed and booted to be used as a spare. It turns out i can't run aftermarket CV's with the amount of lift i have about 3.25" because after i installed the aftermarket Cardone CV while on the lift at full droop it wouldn't even spin it just locked up, tried doing a test drive and it started binding just while making a simple left hand turn.So i had to swap it back to the OEM one after it got re built. When spinning the passenger side OEM CV it just blinded a little while spinning.
Some have said they'v run the aftermarket ones with no issues but after that experience i wouldn't risk it when lifted that much, especially if you plan on wheeling it. So i picked up a extra used OEM CV off ebay for $50 to keep as a spare.
You'll be fine wheeling like that, I've been wheeling mine set up like this for over a year now. It's all about how you wheel, just be easy on the skinny if you get bouncing on rocks with your wheels spinning like crazy cause when the catch that's when CV's snap, Most common way!
[/SIZE]08 Urban Runner Dipped-Satoshi Grill,Icons,M LT,BAMF,RCI,Addicted Off Road Front bumper,4x4 Labs rear bumper,Warn M8000 w Spydura synth,FN Five Stars with 34" Goodyear kevlar Mtr's,4:56 Re gear with Rear FJ Elocker,Flow Master,Afe,and much much more..........
My Build >http://www.toyota-4runner.org/4th-ge...ld-thread.html
Nyc-Runner is offline   Reply With QuoteReply With Quote
noticed its slightly slanted toward driver side bapsdds 5th gen T4Rs 3 07-20-2014 05:33 PM
Sway A Way CO's are loose at full droop xcmountain80 Engines / Suspension / Wheels / Tires / Audio / Accessories 1 03-17-2014 02:18 PM
Rear diff "clicking" with full droop? Fochps 3rd gen T4Rs 4 04-17-2013 12:00 PM
Water build up in my passenger side floor and behind passenger seat a4runner97 3rd gen T4Rs 12 03-23-2013 01:48 PM
