Old 11-08-2015, 04:29 PM #1
Drunner97's Avatar
Drunner97 Drunner97 is offline
Real Name: Danny
Drunner97 will become famous soon enough Drunner97 will become famous soon enough
Drunner97's Avatar
Real Name: Danny
RCI Transfer case skid plate
Installing my skids today, but I'm having an issue with the cross member for the transfer case skid. Looks like I'm hitting the OEM gas tank skid and it's not allowing enough room to get the bolt in. Anyone else have this problem and how was it resolved? Bending the gas skid or removing it altogether? Last piece of the puzzle and I'll have everything on. I'll likely remove the gas skid and hit up RCI tomorrow if nobody has an answer.
build thread: https://independentoffroading.com/in...xit-thread.30/
IG: @4runner_doa
Drunner97 is offline   Reply With QuoteReply With Quote
Old 11-08-2015, 05:05 PM #2
ARunner's Avatar
ARunner ARunner is offline
Real Name: Kyle
ARunner is on a distinguished road
ARunner's Avatar
Real Name: Kyle
I have the RCI skids, but including the gas tank, so I didn't face this issue. Went outside and checked my clearances and I can see why your having an issue. It appears there is enough space around the gas tank to pound the factory skid a little if its just a small amount of space you need. I would call RCI and get their input.
03 Limited V8 4WD
ARunner is offline   Reply With QuoteReply With Quote
Old 11-08-2015, 05:15 PM #3
Drunner97's Avatar
Real Name: Danny
Drunner97's Avatar
Real Name: Danny
Thanks, that's what I thought. I only like a 1mm. it's just barely off so if there's room behind the stock skid I might try just smacking it with a mallet a couple times and see if that's enough to force it. Really don't feel like spending the money on a gas skid right now.
IG: @4runner_doa
Old 11-08-2015, 07:13 PM #4
Drunner97's Avatar
Real Name: Danny
Drunner97's Avatar
Real Name: Danny
That was a royal pain in the ass. What I ended up doing was loosening the gas tank skid bolts, then wedged the bottle jack between the exhaust and the cross member and forced it over enough to get the bolt in. Pretty sure I cross threaded because that thing was a ***** to crank in.
IG: @4runner_doa
Old 11-08-2015, 07:33 PM #5
having fun's Avatar
having fun having fun is offline
Real Name: Leonard
having fun will become famous soon enough having fun will become famous soon enough
having fun's Avatar
Real Name: Leonard
If I remember right, I had a bracket in them spots. I grinded the lips flat. Then again, I was one of the first ginnie pigs when his products was just coming out.
Had the same problem with the bolt, file the tip of the bolt smaller, and applied pressure while re bolting.
Having fun's build
having fun is offline   Reply With QuoteReply With Quote
Old 11-08-2015, 08:35 PM #6
Diamond_D's Avatar
Diamond_D Diamond_D is offline
Diamond_D is on a distinguished road
Diamond_D's Avatar
I had the same exact problem. Since I was nearby, I went back to Josh's shop and let him take a look, and in the end it just took a few well-placed hits with a hammer on the lip of the factory gas tank skid to get it to fit up just fine. There's a good amount of space behind that lip so no risk of hurting anything as long as you don't go nuts hitting it.
Diamond_D is offline   Reply With QuoteReply With Quote
Old 11-08-2015, 08:42 PM #7
Drunner97's Avatar
Real Name: Danny
Drunner97's Avatar
Real Name: Danny
Yeah, it's in there solid now. God forbid I ever need to remove that cross member, I'm not sure that bolt is coming out without snapping the head off.
This is good for anyone else that has the problem as I didn't really find anything on Google about it. I did see that there are tabs holding the gas tank skid in place and if those are ground down it would probably allow for more play to make everything squeeze in.
IG: @4runner_doa
Old 11-09-2015, 09:54 AM #8
Yota_Noob's Avatar
Yota_Noob Yota_Noob is offline
Yota_Noob is on a distinguished road
Yota_Noob's Avatar
Do you have all the skid plates except for the gas tank one? I have just the engine skid that's awaiting install. I guess my question is do I need the rest (trans and transfer case) for the engine to fit properly? If so, looks like I'll end up where you were on your install
Just another silver 4th gen - Sold
Yota_Noob is offline   Reply With QuoteReply With Quote
Old 11-09-2015, 12:51 PM #9
Drunner97's Avatar
Real Name: Danny
Drunner97's Avatar
Real Name: Danny
I have the filler, front skid, trans skid, and transfer skid. You don't need the rest just for the front skid, all the hardware is there to fit it.
IG: @4runner_doa
Old 11-09-2015, 01:42 PM #10
Yota_Noob's Avatar
Yota_Noob's Avatar
Okay cool. Eventually I'd like to get the rest but I got the filler plate and engine skid for cheap and wanted to get them mounted before winter
Old 11-12-2015, 03:42 PM #11
sigepbiker's Avatar
sigepbiker sigepbiker is offline
sigepbiker is on a distinguished road
sigepbiker's Avatar
All I have mounted up right now is the engine skid. Got some help from a buddy who has a Jeep.
@joshp767 He was so impressed with the skid quality and easy of install that he looked up if RCI sold skids for his Jeep TJ's...no dice.
2016 Trail Premium Tires and sliders and some interior mods...
2005 SR5 Silver mod list
FOR SALE: Rear Diff Breather Fitting; 4th Gen Center Diff Switch w/ pigtails
sigepbiker is offline   Reply With QuoteReply With Quote
Old 03-27-2017, 05:41 PM #12
Wigglepuppy Wigglepuppy is offline
Wigglepuppy is on a distinguished road
Aloha @Drunner97 . . . do you (or anyone reading this post) happen to have the installation instructions/parts list for the RCI T-case skid? Cleaned out the garage a couple weeks ago and think that the instructions and bolts were tossed. . . really just wanna make sure I get the right hardware. . .
Thanks in advance!!!
2014 TEP, BFG 275/70/R17 AT T/A KO2, Front: Fox 2.5 Coilover w/Resi and DSC (883-06-130), Dirt King UCA's (boxed/heim), Dirt King LCA's; Rear: Fox 2.5 w/Resi and DSC (883-26-006 - Tundra Shock Mod'd for 4Runner) w/Icon 2" coils, RCI Alum Skids, Pelfreybilt Sliders, Frontrunner Slimline 3/4 . . . Rear bumper valence removal mod for better exit angle (okay. . . it actually ripped off while wheeling )
Wigglepuppy is offline   Reply With QuoteReply With Quote
Old 03-27-2017, 07:22 PM #13
Drunner97's Avatar
Real Name: Danny
Drunner97's Avatar
Real Name: Danny
I can look but I doubt it.
IG: @4runner_doa
Old 03-27-2017, 09:54 PM #14
Offcamber's Avatar
Offcamber Offcamber is offline
Offcamber is on a distinguished road
Offcamber's Avatar
Offcamber is offline   Reply With QuoteReply With Quote
Old 03-27-2017, 09:58 PM #15
Originally Posted by Offcamber View Post
You da man!!!! And local!!! I owe you a beer!!!!!!!!
96-02 Transfer case skid plate NEW - $200 - Colorado rocket76 For Sale: T4R Items 3 11-04-2014 09:24 PM
Transfer Case Skid Plate missing?? Preto789 3rd gen T4Rs 5 01-25-2013 07:31 PM
4+ Plus Transfer Case Skid plate for 4th Gen V6 GG Beast Off-Roading 0 08-06-2011 10:49 PM
Transfer Case Skid Plate Almost Done! teotwaki Off-Roading 29 07-06-2006 11:04 AM
removing transfer case skid plate Michigan_t4r 4th Gen T4Rs 0 10-19-2004 07:40 AM
