Originally Posted by having fun
Auto zone or another chain store has free loner tools. I can't remember if the kit came with grease. Any lube grease should work, I use lucas red and tacky myself. Stock setups with them boots are self contained anyway.
If you have a Harbor Freight near you, I'd consider buying a puller. They cost less than $10 and are really handy to have around for pulling things apart and since they are so cheap you can grind them down to change their dimensions to fit a pretty broad range of applications.
I use mine to separate the tie rod end almost every time I work on my front end and it works well to separate the upper or lower ball joints too. It may not have the strength to completely pull apart the upper ball joint on it's own but it puts enough pressure on it that it only takes a couple of whacks with a hammer separate things.
All that to say, it's a pretty useful thing to have around and doesn't cost that much.
