Old 11-21-2015, 12:17 AM #1
BOFFROAD's Avatar
BOFFROAD BOFFROAD is offline
Real Name: Brad
BOFFROAD is an unknown quantity at this point
BOFFROAD's Avatar
Real Name: Brad
Airbag Light On
Today as I was driving with my 1700lb friend in the passenger seat. He was impersonating the guy in this video. https://www.youtube.com/watch?v=DmBp4yr-8a0
Then the airbag light in the gauge cluster came on. And over near the passenger side, it said Passenger Airbag off. I have tried unplugging the battery and unbolted the seat to unplug each wiring harness under there. After plugging everything in nothing changed. Lights were still on. Does anyone have any suggestions of things I should try?
2005 Sport V8 4WD Gray
Icon Stage 2 | 285/70/17 BFG KM2 | MB 352 17x9" wheels | 42" led light bar | Side Flood/Camp Lights | Uniball UCA's | K&N CAI | Kicker Sub and Amp | Custom DIY Full Length Roof Rack | Trail Gear 67"
Rock Sliders
Build Thread
BOFFROAD is offline   Reply With QuoteReply With Quote
Old 11-21-2015, 01:31 AM #2
BlackWorksInc's Avatar
BlackWorksInc BlackWorksInc is offline
BlackWorksInc is a splendid one to behold BlackWorksInc is a splendid one to behold BlackWorksInc is a splendid one to behold BlackWorksInc is a splendid one to behold BlackWorksInc is a splendid one to behold BlackWorksInc is a splendid one to behold BlackWorksInc is a splendid one to behold BlackWorksInc is a splendid one to behold
Gonna guess the passenger side seat pad and/or detector is damaged/failed now (Forget if the 4th gens use a seat pad or a funky deal on the frame of the seat.)
I'd get the SRS DTCs pulled if you could to get a better idea.
BlackWorksInc is offline   Reply With QuoteReply With Quote
Old 11-21-2015, 01:45 AM #3
BOFFROAD's Avatar
Real Name: Brad
BOFFROAD's Avatar
Real Name: Brad
I know Pepboys will read check engine light for free, do you think they can read the SRS code?
Rock Sliders
Build Thread
Old 11-21-2015, 03:22 AM #4
Don't know... SRS is not mandated by ODBII regulations, so generic scanners typically do not communicate with SRS. It's worth a shot to see if they have an SRS capable tool.
Old 03-11-2016, 11:38 PM #5
BOFFROAD's Avatar
Real Name: Brad
BOFFROAD's Avatar
Real Name: Brad
Got the code.
B1150
Which the internet says is Occupant Classification System Malfunction. Could it be a bad sensor? I looked under the seat and it looks like there are 4 sensors under there. One on each corner. Do you think one of those are bad? I would like it if I could fix this myself because Iv'e been told that service involving the SRS typically costs a minimum of $300 and there are countless aftermarket parts I would rather put that towards.
Rock Sliders
Build Thread
Old 03-12-2016, 12:09 AM #6
CXS CXS is offline
Real Name: Chris
CXS will become famous soon enough
CXS CXS is offline
Real Name: Chris
I had that happen after a passenger slid something under the seat. I just moved the seat back and forth and eventually it turned off. Maybe I just got lucky with a loose connection but what the heck, give it a try.
Chris - '07 SR5
‘05 Limited - sold
CXS is offline   Reply With QuoteReply With Quote
Old 03-12-2016, 01:04 AM #7
Gdmeadors Gdmeadors is offline
Real Name: Greg
Gdmeadors is on a distinguished road
Real Name: Greg
Did the passenger recline the seat? That will turn that seats airbag off. Just return the seat to it's upright position and the passenger side light will go back on.
Gdmeadors is offline   Reply With QuoteReply With Quote
Old 03-12-2016, 02:38 AM #8
We had one that had an issue, I think we were able to recalibrate it with specified weight and the scantool.
Additionally, make sure all the plugs are plugged in under the seat and no wires are broken.
Old 03-12-2016, 02:39 AM #9
ghs215 ghs215 is offline
ghs215 is on a distinguished road
Yep, that's what I had to do. Quick and easy fix (if you got the tool)
2006 4Runner SR5 4x4 V6 Shadow Mica => Mrs
2006 4Runner SR5 4x4 V6 Titanium Metallic => Mr
2012 Sequoia SR5 RWD 5.7L Magnetic Gray Metallic => "I get to drive it! (says hubby) No! I get to drive it! (says wife) Happy Wife - Happy Life
ghs215 is offline   Reply With QuoteReply With Quote
Old 03-12-2016, 02:42 AM #10
Just make sure you're using the specified weight when calibrating it, there is some variance allowed but it is needed for the dual stage airbags.
Old 03-12-2016, 03:30 AM #11
BOFFROAD's Avatar
Real Name: Brad
BOFFROAD's Avatar
Real Name: Brad
I have tried everything from checking connections to putting the seat in different positions to unplugging battery for a night and nothing.
Rock Sliders
Build Thread
Old 03-12-2016, 03:35 AM #12
BOFFROAD's Avatar
Real Name: Brad
BOFFROAD's Avatar
Real Name: Brad
I read some things online about calibrating the weight sensor which I really hope is all it needs. I don't have a scanner to access the OBD. I see ones online ranging from $150-$700 that say they access the SRS. Will the cheaper ones do the job and are they vehicle specific?
Rock Sliders
Build Thread
Old 04-26-2016, 11:28 AM #13
BOFFROAD's Avatar
Real Name: Brad
BOFFROAD's Avatar
Real Name: Brad
What Scan tool is a good one to get for this? I see ones that say they do SRS but does that mean it can only get codes? Do I have to get a certain one that can recalibrate it or can all of them do it?
Rock Sliders
Build Thread
Old 04-26-2016, 11:35 AM #14
BOFFROAD's Avatar
Real Name: Brad
BOFFROAD's Avatar
Real Name: Brad
Any idea on a scan tool that will do the job? Preferably one on Amazon. I want to do this myself but am about ready to take it somewhere. I called a local shop and he said to recalibrate it I would have to take it to the dealer but he will still take a look at it.
Rock Sliders
Build Thread
Old 04-26-2016, 03:15 PM #15
Might be able to do it with one of those Chinese TIS Techstreams.
airbag , passenger , sensor , srs
Airbag light/ Passenger light "off" SR_5runner 4th Gen T4Rs 5 11-24-2015 09:33 PM
Airbag light + passenger OFF ghs215 4th Gen T4Rs 5 03-10-2015 02:38 AM
Front passenger airbag LandCruiser 5th gen T4Rs 10 09-06-2013 07:19 PM
Passenger Airbag Light shows Off when there is a passenger kenm09 4th Gen T4Rs 3 09-10-2012 07:36 PM
passenger airbag light motion732 4th Gen T4Rs 7 03-24-2009 01:33 PM
